Hi i want driver printer hp3920 - Office Equipment & Supplies
    Scholar:
  • 126 Answers
Here is a direct link to HP and your printer, choose the OS you have and download and install.
Hope this helps.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=445442&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20â»
Posted on Dec 01, 2008
  • 1,031 Answers
You can download the driver here http://www.driverstock.com/HP-Deskjet-3920-driver-download/10-26-1644/index.html hope it helps pls do appreciate by rating as fixyaa
My HP3920 Deskjet printer does not print color although I have color ink 22 installed along with the black. How do I fix this?
You need to use only cartrigde original not refill or compatible.If you have original cartridge try to look at the purge unit,is on the rigth,possible is clogged and you need to replace.
Mar 23, 2011 | HP DeskJet 3930 InkJet Printer
I cannot install my HP3920 printer even after I have downloaded the printer driver
run the printer driver before power on the printer after some instakllation it ask to attach the printer then power on the printer it will take some time then it install .
Aug 15, 2010 | HP DeskJet 3930 InkJet Printer
My printer wouldnt accept my new cartridge (not a HP one but a recommended equivilant). We put the old one back in and it was still objecting it. We decided to remove the printer installation and...
Understanding Potential Problems Printers are mechanical devices with lots of moving parts. And any time you have moving parts, you have something that can break or wear out over time.
So when you click the old print button and nothing happens, what are the likely causes?
First, you might have the wrong printer driver installed in Windows. You might have either simply selected the wrong driver for your printer, or Windows might have mistaken your printer for another model, or the driver selected might be out of date. While we're in this area, it's also possible that various aspects of your printer setup might be incorrect, which can cause some highly unusual problems. You should also check your font setup because fonts themselves can cause perplexing problems if they're not installed correctly.
In addition, any new input or output device you've installed since you installed your main printer could have changed your printer's settings. (It's kind of like the last device installed gets dibs on key system settings.) If you've recently added a scanner or a digital camera or fax software or anything like that and then experienced printer problems, try uninstalling your printer (and all printer drivers) and then reinstalling your printer so that your printer is now the last device installed—and thus controls key system settings.
It's also possible that if you're printing large or graphically complex documents, you might not have enough disk space or memory to print. Make sure that you have plenty of both, because Windows needs all the space it can get to complete the printing operation.
Finally, you could have real printer hardware problems. These problems range from the mundane (you're out of paper, you forgot to turn on the printer, a cable came loose) to the fairly serious (your printer is broken!). Check all your cables and connections and make sure that your printer is actually turned on.
The bottom line is there are a lot of things you need to check if you have printer problems, both hardware- and software-related. So if you have printing problems, hunker down and plow through the problems/solutions section, coming up next.
tip
Mar 05, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp3920 not print
check if you print in A4 format in your printer settings.(default is letter)
Jan 24, 2009 | HP DeskJet 3650 InkJet Printer
Hp3920 printer
I don't have a lot of information about what happened to to your printer. But here is a link for your printer about your problem for the power light blinking. If this doesn't work let me know and we will do some troubleshooting.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09744&lc=en&cc=us&dlc=en&product=445442&rule=44368&lang=en
Jan 09, 2008 | HP PSC 1410 All-In-One InkJet Printer
Can u give me a printer driver.
Hi Sinmaya,
Click on below link it will take you to HP driver download page,
Click on the 3900_enu_win2k_xp_exe file , make sure your operating system is XP, file is quite big it wil take time depending upon your internet speed.
After downloading install the driver. !!!!
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=dj-32810-2&lc=en&cc=us&dlc=en&product=445442&os=228&lang=en
Hope this post was usefull, kindly let me know by providing your valuable rating.
Thanks,
Robosoft.
Jan 04, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
209 people viewed this question
jasbo
jasbo
