Code 19 means there is a driver conflict such as two devices trying to use the same resources.
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab - click
Update Drivers (this will likely do nothing) - then RIGHT CLICK the drive - UNINSTALL - REBOOT
this will refresh the default driver stack.
Normally the above will fix that issue if not work your way down through these even if you have done
them before.
Your CD drive or DVD drive is missing or is not recognized by Windows or other programs
http://support.microsoft.com/kb/314060 - a Mr Fixit
The CD drive or the DVD drive does not work as expected on a computer that you upgraded to Windows Vista
http://support.microsoft.com/kb/929461
When you insert a CD or a DVD, Windows Vista may not recognize the disc
http://support.microsoft.com/kb/939052
Your CD or DVD drive cannot read or write media - A Mr Fixit
http://support.microsoft.com/gp/cd_dvd_drive_problems
CD/DVD drive does not appear in Windows Vista, or you receive this error
during Windows Vista setup after booting from the DVD (AHCI)
http://support.microsoft.com/kb/952951
CD-R drive or CD-RW drive is not recognized as a recordable device
http://support.microsoft.com/kb/316529/
Hope these help.
SOURCE: CDDVDW stop responding
Click on the link below to fix the issue.
http://www.windowsguru.org/solutions.html
SOURCE: tsstcorp cddvdw ts-u633a driver needed. help
http://notebooksdrivers.com/tag/pc-laptops-tsstcorp-cddvdw-ts-u633a-driver
SOURCE: code 19 on Tsstcorp Cd DVDw Ts L633a Ata Device
Please use the Microsoft fix it tool to fix the registry vaules it will resolve your issue
SOURCE: not working TSSTcorp CDDVDW TS-L632H ATA Device
hi.. pls remove the CD ROM from the laptop . insert once again.check the bios status ....
SOURCE: my TSSTcorp CDDVDW TS-L632N drive is not reading
To make sure that software settings are not causing the problem, use the following link
http://support.microsoft.com/gp/cd_dvd_drive_problems?EntryPoint=KB
Click Run Now
See if it able to detect any problems.
If it remain same, try to use a lens cleaner disc to clean the drive lens.
