Question about HP (D7580-60003) Motherboard
Error on startup
0242 : CPU fan is not connected properly please switch off your pc and place the connector of cpu fan to the right position
  • fasiladama Dec 01, 2008
    how can we do if the fan is not properly doing
  • 50 Answers
Can u check ur motherboard where u have connected the processor fan. mostly it will be near the processor slot. so see if u have plugged it somewhere else
Posted on Dec 01, 2008
What makes 511-cpu fan not detected and 512-chassis not detected
Are you seeing this error on a system you built or a pre-built system? If it is a pre-built system, check that the fans are running. Next check where the fans are plugged in, the CPU fan must be connected to the CPU fan connector on your motherboard. The chassis (rear case fan) only needs to be connected to the motherboard if you want the monitoring/PWM (modulated fan speed) option. If your CPU fan is powered directly from the power supply, change this.
If this is a system you built or recently updated the case, check your fan power connections, as above. Next check the fan speed. My ASUS board will give the "CPU fan not detected" error if the CPU fan speed is too slow. A different CPU fan will solve the problem. (I got my fan with the CPU; it works fine.)
I hope this helps. Please add a comment with more information about your system for more assistance.
May 12, 2013 | Computers & Internet
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
CPU fan turns for a few seconds and stops, pc will not turn on. Have tried a good PSU, same issue. Removed all connection to motherboard apart from 20 pin, 4 pin power + cpu fan and PW switch: same issue.
1. First of all Remove dust from your CPU fan and try again if issue has been not resolve
2. Second test your SMPS by the help of Green & Red wire. In case fan is turning properly it mines your SMPS is ok
3. Third & last kindly replace your SMPS For the same.
Nov 19, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
Hp pavilion 700 cpu fan error
Does the new fan have 2 wires or 3 wires?
The 3rd wire transmits the speed (RPM -- revolutions per minute) of the fan.
If the HP motherboard does not detect the "status" from the fan, then you get a "fan error".
Are there 2 places on the motherboard, close to the CPU, where the 3 wires COULD connect? If there are 2 places, connect the 3 wires to the OTHER connector, which should be labelled "CPU FAN".
Sep 14, 2009 | E-Machines eMachines T3830 PC Desktop
Cpu fan error
Make sure the cpu fan is plugged in and to the cpu fan connector on the motherboard.
Apr 04, 2009 | Computers & Internet
I have a gateway profile 3 the cpu fan wont come on it gives warning fan absent or broken and wont to go no farther.
First make sure that the CPU fan is properly connected to the motherboard. There is a connector on the motherboard that is usually labeled CPU_FAN.
If the fan is properly connected, but isn't working, a replacement can be purchased for a reasonable price. Check with Gateway or your local computer supply shop and they will be able to help you find the right fan assembly for your CPU.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 11, 2009 | Gateway Profile 3 PC Desktop
Sir i m getting a massage when start computer t have a p3 . with motherboard hp b10900 & cpu pentium 3 800 EB. 0242 : CPU fan is not connected properly please switch off your pc and place the connector of...
you have to do exactly what the system is saying Your CPU fan connector is loose or there is a problem with your CPU fan if You are well-versed with the hardware part of the system you can do it yourself Or call Your PC administrator or who repair Your PC
Dec 01, 2008 | HP (D7580-60003) Motherboard
CPU fan not detected.....
The cpu fan has a three wire connector that connects to the mother board. Usually located to the right & up from the cpu. If yours is connected currently the wires may be miss aligned. From left to right the pins are: first pin ground/Black; middle pin 12v./Red & last pin rotation/Blue. There may be a bios update that address this issue. Dell does not give up information easly.
Jan 13, 2008 | Dell Dimension 2350 PC Desktop
CPU fan not turning with ATX 12V connector plugged in
With the fans on its drawing more than the PSU has.The PSU is bad. Replace it. If it still happens please let us know...It shouldnt.
Jan 06, 2008 | EliteGroup P4IBMS Motherboard
CPU Fan Error - Averatec 3200
First, download PC Wizard 2008 so you can check the fan speeds and temp of your CPU (and every other component of your PC if need be) and see if it's operating properly. You can find it here:
http://pc-wizard-2008.en.softonic.com/
If it's malfunctioning, you'll need to replace it.
Nov 25, 2007 | Averatec Sotec 3200 Series Fan with...
HP (D7580-60003) Motherboard Logo
66 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
