Question about Toshiba Satellite A135-S4527 Notebook
The computer boots up but the screen is dark.
I turn on the computer, it boots up windows, I can barely see the desktop or the mouse movements.
  • tracyg77 Jan 09, 2009
    very dark screen as soon as i turn on my laptop. i can barely see the windows, pointer, etc if i strain and look really, really closely. i tried opening it up and wiggling around wires, rebooting, etc. i am most likely going to try reformatting the hard drive but i'm not sure that's even going to fix the problem. any information on how to fix this (besides take it to a repair shop, since i don't have the money to do that) would be greatly appreciated.
    thanks
  • kathy_morris Feb 26, 2009
    My computer screen in very very dark, and you can barely see anything. When I restart the computer, windows loads and I can enter my password (harly visible), and my desktop opens up. I think the computer is working, there is just something wrong with the screen. When I restart it, it lights up for a second, then goes dark. How can I fix this? One minute the computer was working perfectly, then when I came back to it, it was still running but the screen was almost black. How can I fix this?
    Novelist:
  • 137 Answers
First check your brightness settings and restart the computer and charge it fully and turn it off overnight and all that good jazz. I'm guessing that this is more complicated though.
Laptops are lighted with small fluorescent bulbs, like the 4ft. bulbs in overhead lighting in office buildings but much smaller. My guess is that this bulb failed or (maybe more likely) the part of the computer that creates the charge for this bulb failed (the inverter board). Fluorescent bulbs require a high voltage to get started (around 600v) and this inverter board turns the 5v charge on the motherboard into the 600v required to start up the bulb.
The good news is that most computers have an inverter board that can be replaced.
You should check ebay and google for specifics on the inverter for the A135, HERE'S ONE on eBay that would not be too difficult to replace if you don't feel squeamish about opening up the LCD case of the laptop. You could also try contacting someone on Craigslist or at your local computer repair shop and have them do it.
Whoever does this should first check to make sure the light bulb is not burned out and that the inverter board is getting the proper incoming voltage.
Posted on Dec 01, 2008
Bought a used computer without a mouse.Installed
regarding your mouse issue frist of all what windows your using if u using win 98 or 2000 and your mouse is USB then u have to insatall usb drivers for that windows Xp then it will conact driectly to the Harware it wnot ask for divers
thne chack your mousr will work if not then you have problem with you windows just ub-date your windows
May 01, 2010 | Televison & Video
When computer is turned on the initial page vanishes the screen goes blank and the mouse arrow appears then sadly nothing just a dark screen !!!!!!!!!!!!
this problem might be due to the corruption of logon file
install a fresh copy of windows or try to restart it in safemode by pressing F8 repeatedly before boot screen.
Mar 30, 2010 | Acer Aspire One PC Notebook
When i try to boot it up, the monitor, keyboard, and mouse don't
So, this is a Desktop unit. My advice is this; Take the cover off and try to dust off as much webbing inside as possible.Make sure you take off the power cord when working inside. You will see a fan near the middle of the motherboard. This is your Heatsink/Fan for your CPU. I would bet many pennies this is overheated and may not boot again and if it does it will be unreliable. With your fingers and everything out of the way, plug the bare unit in and turn it on. Make sure the fan on top of the CPU is running. If not, quickly shut it off. I will help you more as you write back and we will get it running.
Mar 21, 2010 | HP Compaq EVO D51S Intel Desktop PC -...
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
Frozen cursor
do you have a wired or wireless mouse?
Have you tried attaching a different mouse to your computer?
What is the brand name of your mouse?
Try booting your computer in Safe Mode. To do this, after turning on the computer, press F8 button several times. You will see a screen that will ask you to boot normally, boot in Safe Mode or boot in Safe Mode with Network Connections. Select Safe Mode.
See if your mouse works then.
Check back with me for further help, if needed. There are additional things you could try.
Oct 08, 2009 | E-Machines eMachines Desktop PC
My computer switches on but the screen is almost blank. You can see the acer logo and the windows logo show up on it when you switch it on but just barely. The screen is very dark.
Unfortunately I have some bad news. This means your 'backlight' on your LCD panel is burnt out. This can be fixed, but often it isn't worth the work. If you still want to use this laptop, you can hook up an Desktop LCD Monitor to the laptop and use it like a desktop computer, with a USB Keyboard and mouse, but sadly the LCD backlight is fried. I've lost 2 laptops to this.
Jan 30, 2009 | Computers & Internet
Blank screen when computer is turned on
When you get the Dell splash screen press the F2 key to get into setup. Use the arrow keys to go down to Drive Configuration and press enter. Go down to Primary Master Drive and press enter. Is the Hard Drive listed there? If not, that is your problem. Press Escape then use arrows to go down to Memory Information and press Enter. Is all of your Memory listed? If not, that could be the problem. Press "esc" to get out of setup. If the Computer does not freeze while in setup I would suspect the Hard Drive is bad. Is the Pointer responding to Mouse movement or does it lock up? In your situation I would first try to Boot from the Windows CD. Write back and I can explain how to do this. If that does not work I would begin to test Hardware. Do you hear any Beeps when the unit is turned on? If you can, E-mail back with more Info.
Jan 16, 2009 | Dell Dimension 3000 PC Desktop
I turned on the computer, it boots up, but the screen is very dark you can't really see everything clearly. Not even the mouse movement.
make sure that theres no loose connection between the monitor and video card at the back of the cpu..then try to boot again the pc..if problem dsnt solved, remove the video card if its pci,try to clean the pins using pencil eraser. then put it back and restart the pc.
Dec 01, 2008 | Computers & Internet
Unable to View Desktop after booting.....
try booting into safe mode by holding down the f8 key during bootup.
if you have a recovery CD, you might also try booting from that.
Mar 28, 2008 | Microsoft Windows XP Professional for PC
Sony vaio screen dark then light
might be going into a powersave after it boots...try checking the power options
Feb 28, 2008 | Sony VAIO PCG-K35 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
254 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
