Question about Motorola Mobility RAZR V3
Keyboard only partly working
I dropped my Motorola Razr V3m and now only about 1/2 of my keys work. The phone works fine otherwise.
  • 62 Answers
Um check and make sure that behind your keypad and see if there not blocked by dirt or something with your connection although your need tabs to check and see to get of your keypad but be carefull if you dont know what your doing and aint got insurance dont do it, i also think there is a solved problem about opening the keypad up. Hope that helps.
Posted on Feb 12, 2007
SOURCE:
Motorola Razr flip phone stuck on contacts, right arrow key won't work. I turned phone off & removed battery & still won't work
Hi Anne,
In that case you will need to perform an FDR (Factory Data Reset), How do reset my DROID RAZR here you will find the steps to do that.
Regards,
Maya
Motorola Support
Jul 17, 2016 | Motorola Mobility Lot Of 3 Razr V3c V3m...
PC SUITE
I googled "motorola razr usb driver" and the first hit was this blog which has zip files and instructions for V3, V3c and V3m drivers.
Works great for me!
If the link doesn't work for you, just use this URL:
http://blog.gruby.com/2006/11/27/charging-a-motorola-razr-over-usb/
Jun 06, 2010 | Motorola Mobility RAZR V3m Cellular Phone
My Motorola RAZR V3 cell phone key board lights up but not the display screen. How can I fix this?
IS PROBLEM NAME IS STRIP PROBLEM OKK PLZ CHECK THE STIP IS CUT MOBILE DISPLAY NOT WORKING IS PART PRICE IS ONLY150
Aug 29, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Cannot format PNY 4gb microsd card
I could help if you provide some more information about the error message or something.
The most common cause is something might have corrupted the video card and its no longer usable
May 30, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Motorola V3m Razr
this is an failure or corruption of core software...u might just keep it on charging for a while...then remove the batteries for an hour...then again switch it on with sim...if that works then again do same thin wit sim....if stil then master clear the phone...or take to an moto assist dey'l clear ur phone...
ne other prob's do tell me..N plz do rate me
cya
Apr 09, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Backlight display not working
Hey Dannes1956,
The Motorola V3m has a light sensor, which is visible just above the right soft key -- the key above the CLR button. This light sensor turns the backlight on when you press a key in the dark and disables the keypad backlight when you are in a well-lit area.
Your phone sounds like it's operating normally. I believe they disabled the option to activate or deactivate that feature.
Hope this helps,
cHiPz.
Mar 17, 2008 | Motorola Mobility RAZR V3
Motorola V3m keypad problem
open the phone and clean the keypad connector really good
Dec 11, 2007 | Motorola Mobility RAZR V3
Pink razr v3m
a master reset will not help that problem that you are having , take the phone to a mobile service center and have them replaced the flexcable and that will correct the issue.
Oct 02, 2007 | Motorola Mobility RAZR V3
V3m backlight problems
you must get a specialist to change the screen because the pixel generator has been dampened. Good luck!
Sep 12, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility RAZR V3 Logo
139 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
