Question about Zanussi ZDQ895 Electric Double Oven
Why does my oven keep switching off?
My Zanussi electric oven (ZDQ895) keeps shutting off. Sometimes it switches itself off once during use, sometimes five times, sometimes it doesn't switch on at all. Sometimes it stays on with no problem. The problem has become more regular though.
  • 1 more comment
  • Anonymous Sep 02, 2008
    my zanussi zdq895 electric double keeps switching off
  • lauriebr Nov 28, 2008
    I have the same problem, started on Fan Assisted oven setting. oven cuts out and time lamp comes on. Now has started happening on other oven settings, it is intermittent and the the oven has not reached the required temperature. I am suspicious of the controller board.
  • Peter Sep 19, 2012
    Did either of you sort this problem, I have the same, it's only on the bottom oven and sems to be totally random, sometimes fine but other times it will happen several times
    President:
  • 1,462 Answers
There is a casing stat which senses overheat. this can be due to lack of ventilation if a built-in type or a fault with the fan
Posted on Mar 20, 2007
Clock always resets when switch switched off and then need to reset it. is there any way of bypassing this clock. i done need it
no it is designed to stay switched on all the time by keep turning it off at the mains could damage your timer and then it wil not reset keep the main switch on all the time it will be ok the only time you switch off is for cleaning or a repair or you go on holiday
Sep 13, 2011 | Zanussi ZHQ575 Electric Double Oven
Zanussi double oven switches off during cooking. It can be restarted without a problem so fault can not be detected. It displayed error 3 message once.
The shutting down of the oven is due to a defective thermal switch or thermistor. Replacing the thermistor could fix the problem. It is usually located in the inside compartment of the oven and connected to the control panel board.
Dec 02, 2010 | Zanussi Ovens
Zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
Dec 26, 2009 | Zanussi ZBF260 Electric Single Oven
Zanussi double oven ZDQ895 top of the oen is hot but oven will not come to temp bottom part of oven feels cool (fan oven)
If the fan is working o/k, then you need to fit a new oven element located behind rear cover of oven compartment.
Please rate my solution.
Thanks.
Nov 15, 2009 | Zanussi ZDQ895 Electric Double Oven
Zanussi 360 just tripped and now keeps tripping
You will probably find that it is the oven element that needs replacing, located at rear of oven compartment behind rear panel.
Thanks.
Nov 11, 2009 | Zanussi ZBF360 Electric Single Oven
AEG over B1180 Keeps switching itself off after about half an hour
if oven is in fact overhaeting then fauklt will be the thermostat
Nov 05, 2008 | AEG B1180-4 Electric Single Oven
Hotpoint sy36 oven
the electric went off wasnt sure why at the time but when i reset the trip fuse my oven stopped heating up so somethingobviously blew in the oven to cause the the elctrics to trip,
does anyone know how to replace the heating element, also the fan on the top isnt working either
Jun 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
My oven keeps turning itself off
the oven may be trying to protect itself because of a faulty device that says "I'm too hot". As electric clothes dryers have a thermal high temp limit switch to protect them, look for this device (may be 1 inch round with 2 wires connected) and replace it
May 24, 2007 | De Dietrich UMP404 Powerclean Stainless...
Zanussi ZDQ895 Electric Double Oven Logo
1,506 people viewed this question
Top Zanussi Ovens Experts
gunfai
Level 1 Expert
Dado
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
