I turned on the computer, it boots up, but the screen is very dark you can't really see everything clearly. Not even the mouse movement.
  • 31 Answers
Make sure that theres no loose connection between the monitor and video card at the back of the cpu..then try to boot again the pc..if problem dsnt solved, remove the video card if its pci,try to clean the pins using pencil eraser. then put it back and restart the pc.
Posted on Dec 02, 2008
My mouse pointer is frozen in the. Middle of the screen
Hello Anthony- do a cold boot on your computer; meaning turn off your computer through the normal shut down process. Wait a few minutes for RAM to clear completely. Start the computer..do you have the same problem? If so, you may have to update the mouse drivers. If you are using a wireless mouse, make sure you replaced the batteries in the mouse and that the mouse receiver is plugged in properly- maybe jostled loose somehow.
If you added new peripherals you may have an IRQ conflict.
Try booting up in safe mode, if the mouse works without freezing, try booting up - initializing one driver at a time to isolate the problem by process of illumination.
Feb 12, 2017 | The Computers & Internet
When computer is turned on the initial page vanishes the screen goes blank and the mouse arrow appears then sadly nothing just a dark screen !!!!!!!!!!!!
this problem might be due to the corruption of logon file
install a fresh copy of windows or try to restart it in safemode by pressing F8 repeatedly before boot screen.
Mar 30, 2010 | Acer Aspire One PC Notebook
Same problem screen goes dark.
Hi
Well I would have thought this to be a classic failing monitor until you said even a new monitor does the same thing. This being the case it can only be the video card or drivers for the card. Resolution is easy to change and could cause the problem if the resolution selected cannot be displayed by the monitor. At the main windows screen right click the mouse and select properties. Now click the settings tab and the resolution is on the left side. Your display should also be listed.
Thanks
Jul 22, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Black Screen on Startup.
Did you try " Last known good configuration at start up. If after boot you press the F8 key where you said you went into safe mode, did you try to load the good known config. It sounds like you have a corrupted registry.
Jul 14, 2009 | Acer Computers & Internet
Cursor runs all over the screen w/o moving hp wireless mouse
Your mouse could be defective, but let's try a few things first. Try to remove any wireless devices close to it (i.e. wireless router)or try to plug it in a new USB port. Last thing try to use a very dark mousepad. The laser respond to reflection so any white on a mousepad combined with some sun light could result in a free for all mouse pointer.
Jun 05, 2009 | HP Wireless Optical Mouse
Laptop Screen Turns Black
I assume you turned off and restarted the computer and its still dark but you can see what is on the screen. If that is the case then your backlight or lcd inverter has gone out and needs to be replaced. Its better if its the inverter as they are typically cheper than the lcd.
If you find this helpful please rate it.
Thanks
May 03, 2009 | Computers & Internet
Computer boots up, but can't use keyboard or anything else
sounds like a problem in windows may have to reinstall the os
Mar 30, 2009 | Acer Aspire 5100 Notebook
Blank screen when computer is turned on
When you get the Dell splash screen press the F2 key to get into setup. Use the arrow keys to go down to Drive Configuration and press enter. Go down to Primary Master Drive and press enter. Is the Hard Drive listed there? If not, that is your problem. Press Escape then use arrows to go down to Memory Information and press Enter. Is all of your Memory listed? If not, that could be the problem. Press "esc" to get out of setup. If the Computer does not freeze while in setup I would suspect the Hard Drive is bad. Is the Pointer responding to Mouse movement or does it lock up? In your situation I would first try to Boot from the Windows CD. Write back and I can explain how to do this. If that does not work I would begin to test Hardware. Do you hear any Beeps when the unit is turned on? If you can, E-mail back with more Info.
Jan 16, 2009 | Dell Dimension 3000 PC Desktop
Unable to access windows or internet. Screen dark.
Take the battery out. Then run it through some tests. Plug it in without the battery and boot it up. Then unplug it, but the battery back in, unplug it from the computer and see if it will boot up with just the battery. Finally, plug everything back in, with the battery, and boot up. That should clear it.
Dec 31, 2008 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
David Payne
David Payne
