Problems with changing the battery
Follow this procedure exactly Place the Z4 in park and turn the engine off. Allow it to cool for a half hour. Open the trunk. Pull up the removable carpet and flooring. You will now have access to the battery, on the right side seated in a bracket. 3 Remove the bracket with a screwdriver. There are a total of three screws, two on the bracket and one securing it. Remove the positive cable from the battery using a socket. Place the cable to the side. Remove the negative cable in the same manner. Pull the wall out. Lift the battery out of the vehicle. Batteries can weigh up to 70 pounds, so get some help. Place the replacement into the bracket. Replace the three screws to secure the bracket to the battery. Connect the positive battery cable and tighten it. Repeat the same process for the negative
Custom Wheels
Thanks can anyone recommend a battery. I beleive it should be an OME/80AH my car is an 04 plate.
Sorry for another post... should I keep the car powered up while changing the battery. I think there is a device that you plug into the cigarette lighter.
