Question about ASUS P5S800-VM Motherboard
ASUS P5S800-VM shuts down after about 5 mins (sometimes more, sometimes less). Ive intermittantly had this issue in the 18 months I have owned it, say once every few months, it shuts down on its own, and wont power up until I pull the power cable, and re-connect it. Now it is doing it constantly, and it started doing it practically overnight. In the time immediately and recently prior, I had: Removed the Uninteruppible Power Supply power board I had been using for a standard 6 gang General Purpose Outlet board (I always had blamed it for faults, and I wasnt happy with the battery backup only lasting minutes anyway) Inadvertantly touched my finger across the cable to my external USB hub, definitely causing a small short (but I thought, no damage) Tested a known faulty external self-powered USB hub (not mine, and didnt know it was faulty until afterward) About this time the fault began, and I noticed the fan in my PCs power supply had seized. Replaced it. No difference. I would like to think simply fitting a couple more fans would be the trick, as it has always run hot, but truly, it seems too coincidental to be happening after these recent things I have done. I am considering running this regcure thing, not sure if it can help, also im tempted to just throw the old power supply away when i go to buy the extra fans. Any idea would be greatly appreciated.
  • 1 more comment
  • Tuft Argus Jan 31, 2007
    My apologies - where i said :
    "About this time the fault began, and I noticed the fan in my PCs power supply had seized. Replaced it. No difference."
    By "no difference", I meant that the PC still shuts down, not that the fan doesnt run - the new power supply fan runs quite well. The extra fans I was thinking of adding were just to help it (and the Motherboard heatsink one) out a bit.
    Any further solutions would be great.
  • Anonymous Mar 26, 2008
    Yes same problem. Frequently shutdown every day after 2 years of use.
  • Anonymous Apr 15, 2008
    kjh uihuhiuh oiuiiuhykk \
    jklkjjojo
This motherboard NEEDS a power supply over 400 watts otherwise it will destroy the power supply hooked to it
Not necessarily true. I ran this motherboard for the first 18 months of it's life with a 250W power supply and had no trouble with it. I only upgraded because I needed to install a second dvd burner.
Posted on Apr 04, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
Remove you CPU Heatsink and fan, look around the socket for possible capacitor damage. look at the small brown ones if the top shinny surface is poped up like in this illustration. If so then replace you motherboard
Posted on Apr 13, 2007
I just ran into the same problem with maybe 2 and a half years of use on this board.
I blamed the PSU and replaced it, but a new power supply did nothing.
I then removed the cpu heat sink as suggested here, and it was these capacitors hidden by the heatsink that were bulging and needing replacement.
I will either be replacing them, or buying a cheap used s478 mobo, as I dont feel like upgrading video card and ram now, not for my parents comp anyway.
Posted on Apr 30, 2008
Posted on Mar 23, 2007
  • 624 Answers
If the power supply fan is not working, even after changing the fan, then it definitely needs to be replaced. Simply putting other fans in the case will not create enough draft to keep the power supply cool enough to run reliably. Also if it's acting flaky enough to not run a fan it could also be providing unstable power to the other components putting them at risk as well. Let us know how it goes and please don?t forget to rate this post.
Posted on Jan 28, 2007
Is the ms 6540 motherboard compatible with the asus p5s800-vm
what u mean compatible? if u mean u want to change your ms 6540 to Asus P5S800-VM, then i tell u it cannot be done.
first thing that u look when to change mainboard is SOCKET type... ms 6540 have socket type 478 and asus p5s800-vm have socket type LGA775. thats mean your old processor cannot be use in asus. socket 478 is older than LGA775.
So if u want to change your mainboard for ASUS P5S800-vm, then u need to change your processor to... about RAM socket and VGA socket, ms 6540 have same type with ASUS P5S800 (DDR400) so u dont need to change your RAM and VGA (if u use external VGA)
hope this useful, regards.
Aug 18, 2011 | ASUS P5S800-VM Motherboard
Hello I have a ASUS P5S800-VM Motherboard with no HD on it just some RAM,graphics card,the CPU and a sound card.My problem is that whenever I switch it on it will stay on for about 15 seconds then shut...
There is no help for this, sounds like board has gone bad in one spot.
Why not use Windows to shut down the machine, or buy a surge supressor with individual switches.
Lastly, you could change out the Mboard with a new one, probable cost $40-$80 if you DIY - plenty of instructons on the WWW
Feb 04, 2011 | ASUS P5S800-VM Motherboard
MOTHERBOARD DRIVER P5S800 VM
Go to the following website to get the driver you need for your ASUS P5S800-VM Motherboard.
http://www.driverstock.com/ASUS-P5S800-VM-driver-download/6-9-10176/index.html
Jan 21, 2011 | ASUS P5S800-VM Motherboard
I have motherboad asus P5S800-VM and I get a beep when I turn and after about 5 seconds I get like 5 consecutive short beeps, can you help please. thanks buzopr@gmail.com
I hate giving a bad diagnosis as I am afraid that you will not respond to the post well or give me a poor rating. But never the less, I will give you the information that you have requested.
5 beeps whether you have an AMI or Phoenix BIOS means that there is a CPU error. That does not mean that the processor is dead, you may be able to reseat the processor in the socket and get the computer back up and running.
I am just telling it like it is, 5 beeps means CPU error.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Apr 01, 2010 | ASUS P5S800-VM Motherboard
Need driver motherboard asus p5s800-vm
Drivers for your P5S800-VM Motherboard can be downloaded thru manufacturer's Support site:
http://support.asus.com/download/download.aspx?modelname=P5S800-VM&SLanguage=en-us
Just select the correct Operating System you are using and you're good to go.
Hope it helps.
Feb 06, 2010 | ASUS P5S800-VM Motherboard
I have formatted my pc. so i want to free download asus p5s800-vm
Hello safaathullah,
All the drivers for the Asus P5S800-VM motherboard can be found at Asus web site, click the link below. (All are also free).
http://support.asus.com/download/download.aspx?modelname=P5S800-VM&SLanguage=en-us (Win XP).
Enjoy safaathullah!
Any question?
Thanks for using Fixya!
Mike
Dec 06, 2008 | ASUS P5S800-VM Motherboard
Motherboard won't post.
I looked up your P5S800-VM motherboard on the Asus site and it doesn?t list the Pentium D915 ?Presler? dual core processor on its list of supported CPSs. Here is the link to show to your sales rep: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5S800-VM
Apr 15, 2007 | ASUS P5S800-VM Motherboard
ASUS P5S800-VM Motherboard Logo
332 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
