Being a novice with anything technical i don't know where else to go ! i have used my wi-fi both at home and abroad , now for some reason i cannot access the internet on pda . the response is cannot find page , i have checked the address etc and all seems ok . i recently went online to hp and after some time they assisted by helping me remove all files to pc and wi-fi worked again . however when restored wi-fi again didn't work . not knowing what i'm looking for in settings is there possibly something simple that i can do ? help
It could be that your connection is ok but the cached files and cookies are corrupt.
Clean out the cookies and temp internet files in the temp folder or whatever your pda uses to clean itself of old files.
Ensure that you have the appropriate network key code needed to
enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address
restrictions, you will require pre-authorisation for the router. You
will need to find your Samsung Jet's MAC (Media Access Control)
address. This is a 12-character code which may be needed by the network
controller to enable the phone to connect. See Getting the Samsung
Jet's MAC address below.
You can get to the Wi-Fi
application either via the main menu or using a homescreen Wi-Fi Widget.
To get to the Wi-Fi application via the main menu, press the MENU
button (either on the home screen or the hexagonal button beneath)
In the main menu, swipe your finger sideways to go through the
menu
pages until you see the Wi-Fi icon. Press to
select.
The Wi-Fi application opens.
Alternatively, to
use the Wi-Fi Widget, from standby, press the home screen. The Widget
toolbar opens up.
Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi
Widget. The Wi-Fi Widget will pop
up on the main screen.
Press the Wi-Fi Widget on the main part of the
display to launch the Wi-Fi application. The Wi-Fi application opens.
Once
in the Wi-Fi screen, press the large Wi-Fi button in the middle of the
screen to turn it on. Wi-Fi is activated and the
button turns blue.
Press SEARCH Nearby Wi-Fi access points (APs)
will
appear as small circles on the display, with their names next to them.
Press the circle representing the Wi-Fi Netowrk you
want to connect to. An options panel appears.
You can press
CONNECT to
connect to the network or
press ADD if you want to add it to a list of preferred
networks for easy access later.
You are taken into a settings
menu for the Wi-Fi access point. If the Wi-Fi access point requires a
network key code,
scroll down to the Network Key panel. Press
to select.
The numberpad appears. Type in the network key code
and press DONE. You are returned to the previous settings screen. Press
SAVE
A list of connections
appears. Press the back arrow button
If you initially pressed
CONNECT, the phone will
connect to the selected Wi-Fi network and a confirmation message will
appear. The display now shows the new connection, illustrated by blue
dots linking the circles onscreen (Figure 15).
If you initially
pressed ADD, you will be returned
to the Wi-Fi screen. Press the circle representing the Wi-Fi network you
want to connect to. A pop up panel appears.
Press CONNECT. You
will be connected and the
connection illustrated onscreen.
Press the back button to return to the home
screen.
From the home screen press MENU to enter the main
menu (Figure 1).
In the main menu, press INTERNET
Choose which
browser option you want (Home, Enter URL, Bookmarks,
etc.) (Figure 18) and press to select. If you press Home you will be
taken to the pre-loaded home page.
If required, use the
numberpad to type in an URL or scroll a list to
select bookmarks. When an URL is completed press GO.
Alternatively press the bookmark you wish to access. You will taken to
the web page requested.
Activate Wi-Fi and press SEARCH,
as before.
When the Wi-Fi access point you want to connect to appears on
the
display (Figure 8), press it to select.
A pop up options panel
appears (Figure 9). Press DETAILS
Details of the Wi-Fi access
point appear onscreen.
Scroll down by dragging your finger up
the screen. Towards the
bottom of the settings list, DEVICE MAC appears, with a
string of 12 charactesr beneath (Figure 21). Each handset has an
individual MAC address, and this panel will display your Samsung Jet's
unique Mac address.
Make a note of the MAC address. You will need it if you want to use
the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC
address restrictions. This can be added into the wireless router
settings access list.
Your kindle has a sim card installed for 3G (lifetime licence paid by amazon and paid for on purchase price on the unit) but that is not related to the wi-fi function on your kindle. Your wi-fi service needs to be logged in to with the same password as you use to log any computer on to your router when at home or whatever wi-fi password is required when elsewhere (e.g a bus, train or restaurant).
Hello Ricardo.
How are You? I Guess you need to
1- Check your wi-fi router model.
2- Check your wi-fi settings.
also please check how many devices are connected to your wi-fi at same time. because some routers can only support upto 5 device. you can check this in the settings and also routers manual.
Turning Wi-Fi on and connecting to a Wi-Fi network 1 Touch > Apps tab > Settings > Wi-Fi from the WIRELESS & NETWORKS 2 Set Wi-Fi to ON to turn it on and start scanning for available Wi-Fi networks. Tap Wi-Fi menu again to see a list of active and in-range Wi-Fi networks. • Secured networks are indicated by a lock icon. 4 Touch a network to connect to it. • If the network is open, you are asked to confirm that you want to connect to that network by touching Connect. • If the network is secured, you are prompted to enter a password or other credentials. (Ask your network administrator for details)
Wi-Fi stands for wireless fidelity. The term Wi-Fi, which is alternatively pushed by the Wi-Fi Alliance, a trade group that pioneered commercialization of the technology. Wi-Fi is mostly about connecting to the Internet without physically attaching your computer to anything. Mostly it's about using laptop computers.
A Wi-Fi enabled device such as a personal computer, video game console, mobile phone, MP3 player or personal digital assistant can connect to the Internet when within range of a wireless network connected to the Internet. The coverage of one or more (interconnected) access points — called a hotspot — can comprise an area as small as a few rooms or as large as many square miles. Coverage in the larger area may depend on a group of access points with overlapping coverage. Wi-Fi technology has been used in wireless mesh networks, for example, in London.
In addition to private use in homes and offices, Wi-Fi can provide public access at Wi-Fi hotspots provided either free-of-charge or to subscribers to various commercial services. Organizations and businesses - such as those running airports, hotels and restaurants - often provide free-use hotspots to attract or assist clients. Enthusiasts or authorities who wish to provide services or even to promote business in selected areas sometimes provide free Wi-Fi access.
Routers that incorporate a digital subscriber line modem or a cable modem and a Wi-Fi access point, often set up in homes and other premises, can provide Internet-access and internetworking to all devices connected (wirelessly or by cable) to them. One can also connect Wi-Fi devices in ad-hoc mode for client-to-client connections without a router. Wi-Fi also enables places that would traditionally not have network access to connect, for example bathrooms, kitchens and garden sheds.
Good luck and have a nice day.
rating the solution is highly appreciated.
nno you dont need to download anything!!! first go to settings then turn on your wi-fi then pick your routers name then insert your password and thast it.
You probably called their customer support or billing, which know nothing about technical stuff.
Wi-fi is completely independent from the cellular network, so it will not charge you anything. Wi-fi just connects to a wireless router, like the one in your home, if you have one. In other words it connects to the internet via someones home/office internet connection. I have a touch diamond and dont have a data plan, and only use wifi, works great..BUT:
If you do not have a data plan (pay as you go data) with Bell, IMMEDIATELY get a 'data block' on your phone, at first they might say oh it will not let you use some functions, etc, put insist, persist, and use force if neccesary as they dont like giving you a data block..It costs about $50 per mb if you use the pay per use internet! I think that was the 1X, but im not sure, its ridiculously high!
You will not believe me but I have a similar problem. I have also Belkin router at home and wireless connection with my e800 works perfect. A few days ago I have tried to connect my PDA to wireless router of my best friend. His wireless network is protected like mine and after configuration of all settings I had no success.
The funny thing is that PDA show me the status CONNECTED but I can not use the internet explorer. Like I said, at home with my Belkin it works properly. I can really not explain what the problem is.
