Question about GE (PSS26MSRSS) Side by Side Refrigerator
Where is the drain pipe located in the side by side profile ge
I have a ge profile fridge side by side and it has water leaking from the base. also there is ice being formed at the bottom bin of the freezer section. i need to flush out the drain pipe ( i think there might be a clog)
but am unable to locate it. pls help if u can.
thank you
  • raveenashamd Dec 01, 2008
    so , u are saying that the drain hole is inside the freezer in the bottom where the ice now being collected due to poor drainage or no drainage at all?
    Sergeant:
    Champion:
  • 291 Answers
In the back at bottom in freezer there is a drain hole which may not be seen due to ice but remove the ice and clear with hair dryer or hot water / larry
Posted on Dec 01, 2008
  • Larry Youngblood
    Larry Youngblood Dec 01, 2008
    right ,,, you have to clear the ice to get to it
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
Ge side by s
found norcold #160107210--new #160107200-----on E-Bay ,under RV Thermostate-----thru seller---- eastcoastrv---Lexington,South Carolina
Oct 26, 2009 | GE Refrigerators
GE Profile with water leaking. Does not seem to be a slow leak. More like an intermittant "dump." Water on floor and refrigerator shelves. Thanks!
Look under the refrigerator and locate the defroster water drain pan. There should be a tube running down the back of the refrigerator which drains water into this pan.
If this tube or other parts of the defroster drain system gets blocked, water can get diverted before it reaches the drain pan.
Oct 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water puddles front left of side by side ge profile fridge
If you clear the drain, the water will not fill up again. (try hot, but not boiling, water, forced into the drain hole with a turkey baster) When drain is clear, water will run into the drain pan located near the compressor. The fan will cause that water to evaporate.
Jun 07, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
My GE Profile fridge periodically (eve other n) leaks water
Thaw out the defrost drain in the freezer. It has frozen over and the defrost water has nowhere else to go except on your floor.
Apr 08, 2009 | GE Refrigerators
TOO MUCH ICE
just switch off and melt the ice away with a hairdryer.
drain is behind the back panel inside the freezer
Dec 02, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking
hi. thanks for the question. the problem you have is with a clogged drain . pull fridge away from wall .remove back panel . clean all coils. locate the drain tube from fridge. clean. thanks the appliance doc
Oct 04, 2008 | GE Profile PSI23NCR Side by Side...
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
283 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
