Question about Xerox Phaser 8200 Laser Printer
Error message 15.004.45:16589
I have an 8200 phaser xerox colored printer, it's giving me an error
message of 15.004.45:16589 do you know what it is?
Thanks Bonnie
    President:
  • 2,072 Answers
Drum heater lamps are out. They are 2,,,, 150 watt halogen bulbs that you can purchase anywhere they sell light bulbs. The way you can tell if they are bad is turn off the lights in the office or room the printer is in. Turn the printer on and look inside the right side fan exaust vent. You should see a glow inside the machine if they are working, I doubt you will see anything. One or both have burnt out, replace both to repair it.
To skip the if you want to I will send you instructions, I will send them now.
First of all you will need Torx bits or drivers to remove the covers etc. I think mostly you will need a number 10 and 15 size.
First off you want to remove both side covers, there is one screw on the top back of the covers, and another on both covers, top front, you have to open the front paper path door to access the front screws. Then about the middle of the covers pull up and outward, they will kind of pop off, but thats fine, they have tabs on the bottom that can be pesky.
Remove the paper tray, the green maintenance tray and set aside.
Now remove the 2 green rails that the maintenance kit rides on. They both are held in by one screw. It will take some manupilating to get them out, but basically you push them sliightly back, inward and twist slightly until they come out. TAKE NOTE of how the leaf springs are on the rails, A hint when putting them back in, is to take some scotch tape and tape them on the side to keep them in place, You will see what I mean when you remove them. But its much easier to get the rails back in when those springs are taped to the side. And no worry about removing the tape afterward, I will have no affect on the machine if its left in.
Next, you look up and you will see a stainless steel curved plate. About 10 inches long and 3 inches high. There are 2 screws on the top of it that must be removed. There are 2 tabs on bottom, Once the screws are removed it just lifts out.
Now about midway up the paper path is the registration rollers. First, you have to go, ( looking from the front of the machine) to the left side of the machine, You will see a electromech clutch on a shaft with a 2 inch black gear with a belt attached. Remove the clip that holds the clutch on, slide off the gear and just let the belt drop in place.
Now, return to the front,The assembly is stainless steel, you will see a couple of rollers on it and some paper path actuators. There is one screw on the right side of that assembly that you need to remove, and on the left side, just by the bearing there is an "E" clip holding the bearing against the frame. remove the screw and the clip, Then move that transport CAREFULLY to the left and out. Be very careful to keep the 2 pieces together, there is a switch actuator that can be easily broken. So please take caution. On the right side, there will be a bearing that WILL fall out, and drop down into the paper feed area. Trust me it will do that. Just locate it and pick it up. When replacing that transport. I suggest, ( unless your considering suicide LOL) Put some white out or a little glue on the outside of that bearing when you press it back into the frame. Otherwise, IT WILL keep falling out and really try your patience. Just trust me on that one.
Now, look in the front , just above where the maintenance tray would go. You will see 2 screws, about 10 inches apart, They will be surounded by a beige/brownish plastic. Remove those 2 screws, they hold in the heater assembly you want to repair. When you remove those screws it will not yet come out, wiggle it a bit and look on the right side so you can easily determine the conectors, plugs you need to remove. Some have 1 some have 2.
Once you do that, slide that heater assembly downward and out. You will see the 2 lamps in there.
Take those little spring metal clips out,, replace BOTH lamps. Use some emery cloth to clean the contacts. Clean the reflector behind those lamps before replacing . That will make the heat transfer more efficient.
Once those are in , in reverse order reassamble. Just be cautious replacing that registration assembly so you dont break the black actuator.
It's really not hard, just takes some time. Give yourself an hour to an hour and a half. But that is your problem I guarantee it.
Posted on Dec 01, 2008
I have a phaser 8860 that has stopped and gives a printer error of 09,035.43:65927
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8!9!6!9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Feb 17, 2015 | Xerox Phaser 8860/PP Color Laser Printer...
I own a Xerox Phaser 3100MFP and it keeps giving me an error message saying "Printer error Fuser temp"...Help
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
Sep 22, 2009 | Xerox Phaser 3100MFP/S Laser Printer
I have a xerox phaser 8200 colored printer. It has an error message it's 15.004.45:16589
Somehow your question was posted twice, I am just responding to remove this message from the queue
Dec 01, 2008 | Xerox Phaser 8200 Laser Printer
PRINTING ERROR
Online Repair Services For Printer Users At Low Costs Call 1- 800-956-0247
We are an authorized service center at toll free number to provide Printer Repair Customer Support services for online printer users at low costs. We have dedicated and professional team, who is very trained and experienced to repair printer rightly. Our printer technicians are highly proficient and depth knowledgeable to solve all technical errors related to printer. Our experts are simply available to help you for any type of technical error. Our online repair services are also available at your desk to solve your problems immediately.
Corporate Office:-
1680 Michigan Avenue,
Suite 700, Miami Beach, FL, 33139
USA Phone Number:- 1- 800-956-0247
http://www.printerfixit365.com/
Youtube:- https://www.youtube.com/watch?v=71cwRgd1W7M
Blog:- https://printerfixit365blog.wordpress.com/2018/03/12/how-to-use-a-printer-at-affordable-cost/
Facebook:- https://www.facebook.com/Printer-Fixit-365-1061418913976081/
Twitter:- https://twitter.com/printerfixit365
Google Plus:- https://plus.google.com/103524620603339733341
Mar 04, 2008 | Tektronix Phaser 860DP Thermal Printer
Phaser 850
Flat Rate - Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer
iTezen.com is Now offering Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer at a flat rate. Basically we repair any problem you may be having with your Phaser Printer for a flat rate. The flat rate covers cost of parts, labor and travel expenses. The flat rate is all you will pay to get your printer back in order. No hidden fees or charges. We show up! We Repair it. You pay us the rate for you model.
Our Flat Rates:
MODEL: Tektronix Phaser 840 Color Printer Repair - $159
MODEL: Tektronix Phaser 850 Color Printer Repair - $159
MODEL: Xerox Phaser 860 Color Printer Repair - $159
MODEL: Xerox Phaser 8200 Color Printer Repair - $159
MODEL: Xerox Phaser 8400 Color Printer Repair - $179
MODEL: Xerox Phaser 8500 Color Printer Repair - $199
MODEL: Xerox Phaser 7700 Color Printer Repair - $209
MODEL: Xerox Phaser 7750 Color Printer Repair - $249
MODEL: Tektronix Phaser 780 Color Printer Repair - $179
MODEL: Xerox Phaser 790 Color Printer Repair - $179
To further guaranty the quality of our services we accept COD payment (Cash On Delivery of service).Our technician will arrive at your location and repair your printer, get you printing again, then collect the payment.
We have technicians in:
Alabama, Arizona, Arkansas, California, Colorado, Connecticut, Delaware, Florida, Georgia, Idaho, Illinois, Indiana, Iowa, Kansas, Kentucky, Louisiana, Maine, Maryland, Massachusetts, Michigan, Minnesota, Mississippi, Missouri, Montana, Nebraska, Nevada, New Hampshire, New Jersey, New Mexico, New York, North Carolina, North Dakota, Ohio, Oklahoma, Oregon, Pennsylvania, Rhode Island, South, Carolina, South Dakota, Tennessee, Texas, Utah, Vermont, Virginia, Washington, West Virginia, Wisconsin, and Wyoming.
Itezen, Inc.
Tel. 516.776.7346
http://www.itezen.com/
Email: sales@itezen.com
Feb 08, 2008 | Tektronix Phaser 860DP Thermal Printer
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser 8500N front control panel LCD died
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1866-877-0191 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Nov 26, 2007 | Tektronix Phaser 860DP Thermal Printer
Phaser 860 error code 07.003.45:116163
It is a print head tilt error.
Most likely ink is in the stainless steel pivot block at the bottom of the print head.
Also the printer could have been unplugged and the cleaning blade is stuck to the print head.
Or a cable is binding the print head movement.
Nov 12, 2007 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Oct 22, 2007 | Xerox Phaser 6100/BD Laser Printer
Xerox Phaser 8400
There is a flag sensor on the registration assembly that is possibly broken.
Sep 07, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8200 Laser Printer Logo
66 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
