Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Sound but NO picture
When I turn my TV on I hear the sound but no picture. The screen remains black. Even when I use a dvd I can hear the dvd but cannot see the picture. Also as I turn the channels I can hear the static in the channels changing but again no picture. I also try pushing the TV/VIDEO button and it will swith back and forth but i do not see anything on the screen. This is the 32 " WEGA. Thank you
    Genius:
  • 1,139 Answers
Hello ashleewith2e,
This sounds like a high voltage problem or a picture tube issue (burnt out filament). I would first determine if you had high voltage at the anode of the TV by using a high voltage probe. If you do not have high voltage then I would suspect the voltage doubler, the IHVT (Integrated High Voltage Transformer) or the Horizontal Output Transistor (I doubt this only because you don't have a power supply failure and I would expect this in a modern TV since the high voltage supply is tied to the low voltage supply), the more likely suspect is the voltage doubler. Second possibility I would check is the CRT socket board and CRT filament. Unplug the TV and with a multimeter set to read resistance check to see if the filament pins read a low resistance if so the filament is good. Plug the TV back in and turn it on and check the voltage on the CRT board and compare them to the schematic values. These two tests should localize the issue. Now, If you have a background in electronics, this should be no problem to do, however if you do not have a background in electronics, I would suggest that you have a qualified TV technician troubleshoot and repair this TV set.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 07, 2008
I have an AVOL 55' LCD tv and when I turn it on there is no picture. I put a DVD in and played it and I can hear sound but when it's the tv by itself there is no picture or sound at all. Ple
tried to look at the darkened room if their is a white screen, it could be the t-con board. if totally black screen, it could be the inverter board was busted or the screen back light itself.
Aug 02, 2012 | Televison & Video
No picture just sound
GO SETTING TAB AND FIND OPTION SET DEFAULT MANUFACTURING SETTING AND TRY
May 18, 2012 | Sony KV-35S42 35" TV
Have sound but no vision?
When the screen goes black, shine a flashlight on the screen to see if you can see a faint picture. If you can then the ballast board for the backlight is bad. If you can't see a faint picture, then the T-CON board needs replacing. You can get parts from here:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 12, 2018 | Philips 32PF9830 32 in. HD-Ready LCD...
My samsung dvd-sh855m has no picture, only sound. there is no picture at all so I cannot even set the machine up. When I put a dvd in I can hear it but the screen stays black
Press the 'pscan' button on the front of the recorder 3 times and the picture will come back. This is a little sod as you only need to catch the pscan button once - if your TV doesn't support a progressive scan your picture has gone....
May 04, 2010 | Samsung DVD-HR720 DVD Recorder
My tv screen hv179 has sound no picture,
While the TV is on, take a flashlight and shine it on the TV, close enough to attempt to see any picture. If you see picture then your inverter board is bad. If there is a backlight but no picture then your video board is bad.
Nov 02, 2009 | Televison & Video
When initially turned on TV will alternat between picutre & black
When the tv goes to a black screen does the sound remain on? Also,if you listen carefully can you hear any arcing noises in the back of the tv?
Aug 03, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My portable COby DVD player stopped working. DVD rotates when I put it in by screen remains black... With TV out option sound comes out and picture/sound shows on TV once I connect it to DVD
I have had some very bad luck with Coby products and am sorry to hear that you have too but please make sure that the connector jack is clean and functioning properly. The connection jack has a device inside it that knows when the plug is inserted and then sends the audio and video out to the TV. If the connector is really dirty it could be that the connector is not working properly.
There isn't a lot more to look at unless there is some obvious problem with the screen such as a loose wire or a broken hinge.
Feb 26, 2009 | Coby TF-DVD8107 Portable DVD Player with...
No picture on tv when i turn on dvd. get split screen black & whi
Give this a try. Using your user's manual, locate the "Configuring your recorder" section. Under this section there will be "System setup - general" subsection. Being that you are unable to see anything on your tv display you will need to use your manual as your display. Press the "SETUP" key on your remote. Once again using your manual as your display, scroll down to "Restore factory settings" and press "ENTER" As long as you are located in North or Central America and using interlaced video outputs you should have your normal display back.
Hope this helps.
Nov 24, 2008 | Protron PD-DVR100 DVD Recorder
Ilo 42"widescreen lcd tv
I hooked a sylvania 220sl8 dvd/cd/vcr, The vcr works, the dvd does not. Why?
Oct 27, 2007 | iLO 2600 Television
Dvd/vcr combo,vcr is fine ,but dvd no picture,or sound,disc reads.
Hi There is an I/P button on your player's remote control. Power your player on then press the I/P button on your remote control.
Aug 16, 2006 | Apex Digital ADV3800 DVD Player/VCR
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
