Question about Nokia 1100
Phone stuck in Test Mode
I am not sure how this happened, but when I now switch on my phone it shows 'test mode' and it is unusable. thank you
  • Kay Roberts Jan 27, 2007
    I have removed the baterry and sim card and switched it back on. to no avail, still stuck in TEST MODE
  • 22 Answers
First Flash the Set using 7.36v Software. Click Reboot in normal in Ufs Then set shows insert sim After this Remove ufs cable Fit the battery This is normal procedure . still this fault persists Replace Resistors and capacitors In the BSI Path
Posted on Mar 12, 2007
  • 74 Answers
Dear. it is mostly happen when the flashing points of ur mobile are short or flash IC is short. it because that water at the flashing points may be due to sweating. if there is water at flashing points clean it with any approved cleaner.if not ok then change the resistor located near the flashing points(contents).
Posted on Mar 16, 2007
How to turn of field test mode on my zte z958
Field Test Mode: What it is and How To Enable it on Your Phone
www.ubersignal.com/field-test-mode
  1. Cached
  2. Similar
Most phones have a setting we call Field Test Mode that can show you useful information about your phone, including the signal strength in decibels. ... The iPhone has a hidden built-in Field Test Mode app. .... My Home; My Vehicle; My Work ...
Field Test Mode for iPhone and Android - RepeaterStore
https://www.repeaterstore.com/pages/field-test-mode
  1. Cached
  2. Similar
Your phone can tell you exactly how strong its signal is, in decibels, by entering Field Test Mode. How to enter Field Test Mode varies from phone to phone, but it ...
Finding Your Phone's Signal Strength Reading (Field Test Mode ...
support.weboost.com/.../206521937-Finding-Your-Phone-s-Signal-Strength-Reading-...
  1. Cached
  2. Similar
7 days ago - Finding Your Phone's Signal Strength Reading (Field Test Mode) ... My phone's 3 bars may well represent a stronger signal than your phone's ...
[PDF]Cellular Phone Field Test Modes - wpsantennas.com
www.wpsantennas.com/pdf/testmode/fieldtestmodes.pdf
  1. Cached
  2. Similar
Dial *3001#12345#* and press the Call button. This will launch the Field Test Mode app and where the bars/dots were in the top left corner of the screen, you'll now see "< Back to iPhone". Hold down the power button until you see "Slide to Power Off", then release it. field test mode on my zte z958 Google Search
Dec 13, 2016 | ZTE Cell Phones
How to flash my sony ericsson w550i
to update your phone follow these steps 1)--CONNECT PHONE(K750I CABLE)
2--SELECT MODEL
3) SELECT MCU and CUST/fs
4)TEST POINT BYPASS&TP2
5)SELECT FLASHING MODE------MCU+CUST/fs
6)PRESS GO BUTTON
FLASH MODE STARTED SOFTWARE SHOW CONNECT TEST POINT
(TEST POINT HERE)
FLASHING STARTED SOFTWARE SHOW DISCONNECT TEST POINT
FLASHING COMPLETED PHONE 100%OK thanks
Jun 30, 2011 | Sony Ericsson W550i Cellular Phone
Test mode
hello,please kindly rephrase your question.
thanks,take care.
May 07, 2010 | Nokia 1208 Cellular Phone
My mobile showing test mode after switched off
my mobile showing test mode after switched off
Jan 16, 2010 | Nokia 1600 Cellular Phone
Nokia 1600 stuck in test mode. unable to use.
This problem could only be solved by the nokia care centre.
1.This problem is happened due to chip failure, that leads to the displaying of text "test mode".
2.This chip is too small,so only nokia care centre can fix this problem.
May 25, 2009 | Nokia 1100
Need motherboard diagram for the test mode
It sounds like the flash did not finish or hung while trying, I would
think that you just bricked the phone. I have never heard of this
test mode of the board, you normally use the keypad on the phone
to enter it into test mode. If the phone does not post, I have never
heard of a way to get it to reflash.
Maybe someone will come along that knows a way.
Apr 04, 2009 | Motorola Mobility RAZR V3m Cellular Phone
When switch on n70 displaying Test mode
service auto start problem: services diabaled problem appeared on my n70
Oct 02, 2008 | Nokia N70 Cellular Phone
MotoRAZR V3M problem
its stuck in test mode you have to hold clr and soft left keys and it will go back google the rest to get into debug mode to turn off test mode because it will still be on when you exit out of the fts screen
Jul 17, 2008 | Motorola Mobility RAZR V3
Show test mode
my handset model1600 shows test mode , how do i turn on phone ?
thanks
Feb 29, 2008 | Nokia 1600 Cellular Phone
my did that when i plugged the charger in while the phone was off. i yanked the battery, went to the bathroom, came back and put the battery back in, and i was good.
Dec 15, 2007 | Cell Phones
Nokia 1100 Logo
159 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
