Question about Labtec DC-505 Digital Camera
Driver not compatible w/ Windows XP SP2
The software that came with camera has an installation disk, but it's flagged by windows as not passing the logo test. I installed anyway, and it did not work. I've tried d'loading the driver on the Labtec site : http://www.labtec.com/index.cfm/service/listing/AMR/EN,crid=68,crid2=1764 Still won't work, I did find one on driverguide.com that says it's compatible, but it's not. Any solutions??? Much appreciated...
All i can say is that this labtec device is useless. i have lost all hope after searching for drivers and trying to get it to work but i have been unsuccessful
Posted on Jul 10, 2007
Need drivers
there is no driver yet for windows 7.but download scan gear and scan gear toolbox from here:http://software.canon-europe.com/products/0000473.asp  open properties,compatibility and run it in compatibility mode for xp sp2
Feb 28, 2010 | Canon CanoScan N650U Flatbed Scanner
Is Software available for Vista?
According to HP, no. See link.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=&cc=us&product=59968&lang=&#
However, you might be able to install the Windows XP drivers and run the driver in 'Compatibility Mode' for XP SP2.
First, un-install any drivers you have installed for the scanner (if you have tried any).
Second, disconnect the scanner from your computer.
Download the driver and the software update from the provided link (above).
Once you have downloaded the driver (ps804en.exe) right click it, select the Properties/Compatibility Tab and check 'Use Compatibility Mode' and set it for Windows XP SP2, and also check 'Run as Administrator'
Then click ok.
Now run ps804en.exe and do not connect your scanner until the installation is finished (unless it specifically asks you to connect the scanner).
Now right click the updated software (ps803mu.exe),select the Properties/Compatibility Tab and check 'Use CompatibilityMode' and set it for Windows XP SP2, and also check 'Run asAdministrator'
Then click ok.
Now run ps803mu.exe
With any luck this might work.
Sep 25, 2009 | HP Photosmart s20 Film Scanner
Compatibility
Go to this site to download your i-rocks IR-3230 Web Camera driver http://www.i-rocks.com/Download.aspx I hope this driver has passed the Windows Logo testing.
Thanks.
Jul 14, 2009 | i-rocks IR-3230 Webcam
I have the disk it installs everything but it wont work it needs a driver please download the needed driver i'm using vista thank you Kim
You have to install the software drivers in compatible mode of Windows XP SP2.
Right Click on the setup file----->Select Properties------>Select Compatibility----->Select the "Run in the Compatiblility Mode of Windows XP SP2"------>Also select "Run As Administrator"---->Apply----> OK.
Now reinstall the Printer Software. It will work for sure.
Jun 07, 2009 | Lexmark Z600 InkJet Printer
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
Problem with running installation CD
If you explore the disk and find the exe. file you might be able to right click on it and click Properties. Sometimes there is a Compatibility tab that shows a list of Compatibility modes for older operating systems.
There is a chance that the camera won't fully function if you do this though so I would suggest you install Service Pack 2, as SP2 is basically the '2nd half' of xp, and will make installs much easier.
hope this helps
chris
Dec 17, 2008 | Logitech QuickCam Pro 9000 Web Cam
Installation conflict with Windows Logo Testing
IF YOU HAVE INSTALLED THIS SOFTWARE ON A COMPUTER RUNNING XP AND IT WORKED WELL AND YOU FEEL CONFIDENT WITH THE SOFTWARE, I WOULD NOT WORRY ABOUT THIS SCARE TACTIC YOU ARE GETTING ON THIS NEW COMPUTER. IS THIS NEW COMPUTER RUNNING XP,SP2 AND THE OTHER ONE RUNNING JUST XP OR XP,SP1? THIS MIGHT BE WHY YOU ARE GETTING THIS SCARE SCREEN. IF THIS SOFTWARE HAS BEEN WORKING ON A MACHINE WITH XP, IT WILL CONTINUE TO WORK ON XP.THE LOGO TESTING AND VALIDATION PROGRAM WERE MADE TO STOP PIRATE SOFTWARE. IT DOESN'T SOUND LIKE THIS IS THE CASE HERE. SOME OF THIS LOGO TESTING HAD A LOT TO DO WITH GETTING UPDATED SOFTWARE TO WORK WITH NEWER VERSIONS OF XP AND VISTA. LIKE I SAID IF YOU ARE COMFORTABLE WITH YOUR PROGRAM I WOULD NOT FEAR THE WARNING AND INSTALL YOUR PROGRAM AND WHEN YOU DO, JUST CHECK FOR ANY UPDATES TO YOUR SOFTWARE.
Oct 01, 2008 | SiPix SC-3300 Digital Camera
Camera doesnt work
Sorry talhahs, creative has not written Vista compatible driver software for you're PC-Cam 350 camera. Hence you're camera will not function with any version of Vista.
There are few SD readers currently that are compatible with Vista. Click on this link to see one type.
http://www.vavolo.com/productdetails.asp,mode,1,ProductID,3908,gclid,CPqsn6iJ-JMCFQEnGgod1UrbWg
A card reader that will help you in transferring pictures from you’re camera to you’re PC while using Vista.
Win XP, unlike Vista will still run program software even if it has not passed MS's compatability.
Good Luck!
M
Jun 15, 2008 | Creative Labs PC-Cam 350 Digital Camera
Veo stingray 330v driver for vista?
Solution:
Download the veo 330v drivers from this site: http://www.softsci.com/veodrivers.htm
Run the setup program. Cancel the automatic install.. It extracted the setup files to c:\setup
Browse to that directory, right click on setup, properties, compatibility, set it to xp sp2 compat. close the properties. Install. Unplug usb, replug. Vista WILL find and install drivers and they DO work. They work with Yawcam, MSN Messenger at least. I haven't tested with any other software. This is on the Vista Ultimate Edition at least..
Aug 09, 2007 | Veo Connect Webcam
Labtec DC-505 Digital Camera Logo
295 people viewed this question
Top Labtec Cameras Experts
Are you a Labtec Camera Expert? Answer questions, earn points and help others
