Upon boot up I am getting this error code SC555, power off and on.
Did that and still getting the same message. What is the error and how can it be fixed.
This means the pressure roler thermistor is out of position or defective. Take out the fuser, the thermistor is a little pad that sits against the lower roller. Check that it is clean and that it is touching the roller, this fault is telling you that the press roller heat lamp stayed active for 100 seconds and the code is produced to prevent damage to the machine. I hope this helps.
Each time I try to print from WordPerfect to the printer, I must set the paper size to 8.5 x 11. For...
(More)
Each time I try to print from WordPerfect to the printer, I must set the paper size to 8.5 x 11. For most of the rest of our office, it just prints.
Hi I've got an Ricoh Aficio CL3800 which has started printing black marks (small dots) each dot is...
(More)
Hi I've got an Ricoh Aficio CL3800 which has started printing black marks (small dots) each dot is about 3cm apart but line up accross the page when we run off prints - the problem happens on both b&w and colour. Any advice would be appreciated.
