Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
Viewsonic Flat Screen TV changes channels randomly.
ViewSonic N2751W TV, will be working for about 5 mins, on the channel I choose. Then for no reason, the channel will change and start advancing. It may stop on a channel and then it starts again advancing from one channel to the other. If I try to power off the unit, it would not power off. When I get it to power off and power on again, it will continue to just change the channels. I took out the batteries out of the remote. I moved it to another room in the house just in case it was interference from other computer equipment. It still advances the channels whenever it pleases.
5 Suggested Answers
SOURCE: viewsonic n2751w
why does my 27 inch lcd monitor keep changing colors
Posted on Jan 04, 2008
The holding both Vol buttons worked great thanks!
Posted on Sep 07, 2008
SOURCE: I have viewsonic flat screen tv and it displays
you have to hold the 2 volume buttons on the top of TV down at the same time.
Posted on Nov 22, 2009
  • 139 Answers
SOURCE: How do I change the power supply for my Viewsonic N3760W TV?
YOU HAVE A VOLTAGE/CURRENT LIMITER PROBLEM THAT IS PROBABLY CAUSED BY A LEAKY CAPACITOR IN THE FEEDBACK CIRCUIT IN THE POWER SUPPLY. THIS CAN BE FIXED. I CAN GUIDE YOU IF YOU CAN SOLDER AND FIND THE PARTS- RADIO SHACK OR MABYE AN OLD TV AROUND?
Posted on Dec 27, 2009
Testimonial: "Awesome help."
SOURCE: I have a Viewsonic flat-screen tv, it displays "menu locked" ??
Try holding the VOL + and VOL - buttons on the TV (not on the remote) down together. You should see a "unlocking buttons" message on screen. This might work. However, I tried it repeatedly, as told to by the Viewsonic "service" rep, and it didn't work for me. Viewsonic is ****, and so is its "service"!
Posted on Nov 02, 2010
My viewsonic n2751w tv will not stop channeling down... have to put weight on top to stop
mmm sounds like a sticky channel switch on your tv itself. Spray some special stuff called Contact cleaner spray available at any electrical outlet or hobbyshop - its a little bit expensive but works great to clean motherboards and most other electrical equipment. Spray while the tv is off and press buttons in between sprays
Jan 14, 2015 | ViewSonic N2751W 27 in. LCD Television
My viewsonic keeps changing channels which makes it impossible to use. We've unplugged it and everything. once you power it on, thats all it does. it continueusly changes channels. please help
The first thing to try is to see if a button is stuck on the remote or on the TV.
Remove the batteries on the remote and see if that helps. If it fixes the problem, you'll need to replace the remote.
If that doesn't help, look close at the buttons on the TV to see if one is jammed on. If changing channels continually up, then check the channel up button on the TV, if down then check the down button.
Worst case, you might have to take the back off the TV and unplug the cable feeding the external button panel on the TV and only use the Remote (for safety, rememeber to unplug the TV while doing any work on it).
Nov 28, 2013 | ViewSonic N3235w 32" LCD TV
Tv viewsonic n3752w no signal
have you tried to reset to factory settings.how about watching a local channel does it work just let me know so i can give further solution.
Aug 11, 2012 | ViewSonic Televison & Video
N2635w 26 in. LCD Television: help me unlock my viewsonic...
try pressing and holding one of the "channel up" or "channel down" buttons for 5 seconds or more... While holding the button, you should see a progress bar that indicates "menu locking" or "menu unlocking". That should fix your problem...I found that out by accident on my TV.
May 10, 2010 | ViewSonic N2635w 26 in. LCD Television
Viewsonic HDTV 32" Channel Issue
Might have a bad tuner, try using one of the a/v inputs and an external signal device such as a vcr. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | Televison & Video
Jun 06, 2009 | ViewSonic N3251w 32 in. LCD HDTV
Viewsonic N2751w continues to cycle thru channels at startup
Unplugged the TV and removed and reinstalled each connection. Don't know why but it was enough to resolve the issue.
Jan 04, 2009 | ViewSonic N2751W 27 in. LCD Television
Powering up and warmup problems
why does my lcd monitor change different colors no picture just turns to all sort of colors ViewSonic N2751W 27 in. LCD Television thanks 4 your help
Dec 05, 2007 | ViewSonic N2751W 27 in. LCD Television
Viewsonic n2751w
Oct 18, 2007 | ViewSonic N2751W 27 in. LCD Television
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
51 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
