Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Black ink We have installed a new black ink cartridge and it's not printing!! We've reset it, reinstalled it, and even reinstalled the printer completely :(
  • 4 Answers
The black printer cartridge leaked a fair amount of ink in to the printer. I am getting all lights flashing and the printer won't even turn off when I hit the power button. I did some cleaning and it...
Sorry to hear that.. here are some instructions that should help you out:
Instructions
things you'll need: Microfiber cloth
1. Ink Cartridge Errors
2. Turn the printer on and open the ink cartridge cover. Wait for the cartridge carriage to stop completely before reaching into the printer.
3. Press on the top of each print cartridge, then pull the cartridges free from the carriage. Make sure you are only using HP cartridges labeled as "HP 60" or "HP 60XL."
4. Reinstall the ink cartridges and close the cover. If the ink cartridge error message displays again, remove the ink cartridges as before.
5. Clean the copper metal contacts on the cartridges using a dry microfiber cloth. If you still see the error message after you reinstall the ink cartridges, replace hem with new cartridges.
Print using the device's ink backup mode if you do not have a replacement for one of the cartridges. Remove the cartridge you cannot replace and close the cover and continue printing. The printer will automatically use the backup mode until you install a new cartridge.
Mar 21, 2011 | HP DeskJet F4280 All In One Printer InkJet
I installed a new black ink cartridge(lc61bk) on a brother mfc-495cw and now nothing is printing.
Check out if you've installed it correctly. Also check out other ink cartridges, are they empty? If yes you won't be able to print anything. However, if all ink cartridges are OK then try to reset the printer or reinstall the drivers. You can find help in MFC 495cw users manual
Feb 27, 2011 | Brother MFC 490cw Color Inkjet...
Black ink not printing even tho a new black ink cartridge was installed recently and working properly until I opened the unit to install a new color cartridge and now the black ink is not printing and the...
Try to reseat your cartridges. Unplug and replug your printer into the power source to reset itself. If that doesn't help, try to clean your cartridges and check if print quality improves. If you're using Windows, go to Start -> Programs -> Lexmark X74-X75 -> Lexmark X74-X75 Solution Center -> Maintenance -> Clean print nozzles to fix horizontal streaks.
Feb 17, 2011 | Lexmark X75 All-In-One InkJet Printer
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Dell A940 prints black but doesn't print in color. I installed a new color cartrige and the 50c error went away, but still doesn't print in color...
Hi there Error 50c
This is for yours.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Nov 20, 2009 | Dell A940 All-In-One InkJet Printer
All colors print only black does not print. New
reset your print option set automatic or color select
Aug 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
I just replaced black ink cartridge and snapped all cartridges back in place and recharged the printer now it wont recognize the black ink cartridge even though it was just replaced
Try wiping the copper contacts on the new cartridge with a dustfree cloth dampened with some alcohol. Dry thoroughly before reinstalling.
May 05, 2009 | Office Equipment & Supplies
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
E5 Error when I reinstalled new & original cartridges
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
597
Jul 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Refilled black ink before it ran out-now can use at all
After hours of reading about this I finally found the solution. This will NOT reset your levels but you will be able to print without being told you have empty levels.
Start, Control Panel, then Printers and Faxes.
On the next screen, Right click on your printer then on Printing Preferences. Now select the Advanced tab.
Near the bottom left, you will see more options. Click that and then Appearance. Check NEVER display printing status and make sure under Complete-A-Print, all is unchecked. Click OK at the bottom.
You can print without the stupid messages coming up. Dells printer ink cartridges have a computer chip in them and the refurbished ink does not which causes these error messages telling you your ink cartridges are empty.
Jan 14, 2007 | Dell 924 All-in-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
53 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
