Question about Adesso ACCELL FIREWIRE GOLD 6PIN/6PIN 6FT (a005b-006h)
I wish to transfer movies from a camcorder to my computer. My camera has a 4 pin connection. The computer specs state the firewire port is 4 pin but has a port the same size as a 6 pin. Can I use your 4 pin/6pin gold cable?
    Sergeant:
  • 320 Answers
First off thanks for choosing fixya.com
Since not all cables are made the same way it would be best to check the manual, or online documentation for your camera. The manufacturer probably makes a cable specifically for that camera. If the camera has a removable card such as SD or MMC you can purchase a generic card reader for your computer and simple transfer data using the card reader, In some cases this is cheaper due to the high cost of some USB/Firewire cables. Only use cables recommended by the manufacturer. This will not only ensure your warranty stays in tact but also makes sure you do not damage your camera or computer by using a wrong cable.
Hope this helps you.
Jei.
Posted on Dec 14, 2008
I dnt hav usb cable for my handy cam DCR-HC52E ...
Product Summary
    4-pin to 4-pin IEEE 1394 iLink FireWire Cable dv out to laptop Connect and transfer home movie from your digital camcorder to Notebook computer.
    You will need a Firewire port on your computer, also known as a DV port or IEEE 1394, to use this cable. This is NOT a USB cable.
    This DV cable will connect your laptop (notebook)
    NOTE: for some models, becuase of no DV jack on the body, this cable connects to docking station/cradle instead of connecting directly to your camcorder.
Mar 20, 2011 | Sony DCR-HC52E Mini DV Camcorder
Usb device not support in computer?
USB will transfer your still photos to a PC.
If you wish to copy movie files you will require a firewire cable and ports.
Usually a 4 to 6 pin firewire cable depending on the computer. eg laptop verses Desktop/Mac.
Al
Feb 16, 2011 | Panasonic NV-DS50EN Mini DV Digital...
I'm not able to install drivers for my sony mini DV DCR-TRV22E handycam on mac os.
The DCR-TRV22E Camcorder can be connected to the Macintosh Computer with the i.LINK (Firewire) cable. The Software supplied with the Camcorder is not compatible with the Macintosh Computer. Instead you've to use the Firewire cable for connecting the Camcorder to the Computer. You can use the iMovie Software for transferring the videos. You do not require any drivers from Sony, to transfer the video via i.LINK.
You require to purchase either a 4 - pin to 4 - pin or a 4 - pin to 6 - pin i.LINK / Firewire cable depending on the number of pins on the i.LINK / Firewire port of your computer (since Camcorder will have only 4PIN i-LINK, while the Computer may have a 4PIN or 6 PIN i.LINK port).
Thanks for using FixYa.
We wish you a happy Christmas and NewYear!!
Dec 23, 2010 | Sony Handycam DCR-TRV22E Mini DV Digital...
PC with Windows XP will not recognize DCR-HC96 Handycam, and I don't have the software disk that came with the camera. Help
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Windows XP Operating System only):
As you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
As you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video. The i.LINK port is also called IEEE 1394 or Firewire port.
An i.LINK is a black D shaped connector with 4 or 6 pins. The i.LINK cable is an optional accessory for the Camcorder. You require to purchase either a 4 - pin to 4 - pin or a 4 - pin to 6 - pin i.LINK / Firewire cable depending on the number of pins on the i.LINK / Firewire port of your Computer (since Camcorder will have only 4PIN i-LINK, while the Computer may have a 4PIN or 6 PIN i.LINK port).
You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
Good Luck!!!!!!!!!!!!
Sep 29, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Unable to transfer video information onto PC ACER ASPIRE using windows Vista for editing by windows movie maker. Interface on PC is via USB. If software driver for firewire or 1394 interface is available...
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Sep 28, 2009 | Sony Handycam DCR-TRV16E Mini DV Digital...
Where can get the sony handycam DCR-HC42 device drivers support Windows vista
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
Aug 31, 2009 | Sony Handycam DCR-HC42E Mini DV Digital...
My sony camcorder DCR TRV19cannot be detected on my vista computer
The videos from the tape camcorders cannot be transferred to Windows Vista Operating System as there is no USB Streaming ooption available on the Windows Vista Operating System.
The Camcorder uses the USB Streaming function to transfer the videos to the Computer.
You may wish to purchase a i.LINK/Firewire cable to connect the Camcorder to the Computer in order to transfer the videos from the Camcorder to the Computer.
The i.LINK cable is a D shaped port labeled as i, DV, IEEE1394. Please refer to your Computer manual to check whether there is an i.LINK port on the Computer.
Sony Camcorders contains 4-pin i.LINK port on it.
If your Computer has a 4-pin i.LINK port, then you can use a 4-pin to 4-pin i.LINK cable to connect the Camcorder to the Vista Computer.
If you're Computer has a 6-pin i.LINK port on it, then you can connect the Camcorder to the Computer using a 4-pin to 6-pin i.LINK cable.
You may wish to click the link below to get more details about the 4-pin to 4-pin i.LINK cable.
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=11039459&tab=Features
You may wish to click the link below to get more details about the 4-pin to 6-pin i.LINK cable.
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=11040679&tab=Features
Jul 10, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Driver for DCR-HC28
It's not possible to transfer the videos from the Camcorder to the Vista running Computer using a USB connection.
The Camcorder uses the USB STREAMING function to transfer the videos to the Computer. The Vista doesn't support the USB STREAMING function.
However, you may transfer the videos from the Camcorder to the Computer using an i.LINK/FIREWIRE cable.
If your Computer has an i.LINK/FIREWIRE port on it you can connect the Camcorder to the Computer using the i.LINK/FIREWIRE cable.
The i.LINK port is a D shaped port labelled as DV, i, IEEE1394, Firewire.
If the i.LINK port on the Computer has 4 pins on it, then you can use a 4-pin to 4-pin i.LINK cable.
If the i.LINK port on the Computer has 6 pins on it, then you can use a 4-pin to 6-pin i.LINK cable.
The i.LINK port on the Sony Camcorder is a 4-pin i.LINK port.
I will forward a link to a page where you can get the steps to transfer the videos from the Camcorder to the Computer using the i.LINK connection.
Jun 15, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
Transferring video to PC
Check if it has the firewire port. If so, you can get a 4 pin firewire cable and connect to the PC.
Switch on the Cam.
Open Windows Movie Maker and import video from device.
4 pin firewire would look like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
You can use the Movie maker to burn it to the Disk
Sep 26, 2008 | JVC GR-DX77AG Camcorder
How to download video from panasonic nv-gs15 to Computer
I connected with USB and used MS Movie Maker. The sw that came with the camera only transferred still pictures.
Oct 02, 2007 | Panasonic NV-GS15 Mini DV Digital...
Adesso ACCELL FIREWIRE GOLD 6PIN/6PIN 6FT (a005b-006h) Logo
51 people viewed this question
Top Adesso Computers & Internet Experts
Alun Cox
Pcm2048
Chris Benedict
Level 1 Expert
Are you an Adesso Computer and Internet Expert? Answer questions, earn points and help others
