What is patch file - Computers & Internet
    President:
  • 2,110 Answers
Patch file is a .exe file that is used to update system file to newer version in which bugs are removedfrom older version..
Posted on Dec 01, 2008
What Files Will Be Displayed in the Flash Memory in Addition to the Default Startup System Software Package and Configuration File?
After a device is powered on, it initializes the configuration by reading the configuration file from the flash memory. When you run the dir flash: command in the user view, the following information is displayed:
<HUAWEI> dir flash:
Directory of flash:/
Idx Attr Size(Byte) Date Time FileName
0 -rw- 812 Jan 01 2008 00:00:56 private-data.txt
1 -rw- 948 Jan 01 2008 07:16:55 vrpcfg.zip
2 -rw- 90,602 Jan 03 2008 03:58:15 v200r008sph001.pat
3 -rw- 6,418,980 Jan 19 2008 20:19:42 s2700-v100r005.cc
4 -rw- 12,240 Jan 03 2008 04:52:43 $_patchstate_reboot
14,632 KB total (8,228 KB free)
In the command output:
· The private-data.txt file saves service initialization data. Initialization data of some tasks is irrelevant to the configuration and is not recorded in the configuration file. The private-data.txt file records initialization data of these tasks, for example, the number of times the device restarts.
· The $_patchstate_reboot file records the patch status. This file is created after the device runs a patch and cannot be deleted. The file records the status of all patches, for example, the active state and running state.
· The v200r008sph001.pat is a patch file. The file name extension of patch files is .pat.
Sometimes, the flash memory saves a notilogindex.txt file. If a destination host is configured for Inform traps, the number recorded in this file is used as the initial serial number and filled in the Request ID field in Simple Network Management Protocol (SNMP) packets. The system starts a timer when the SNMP task starts and updates the file every 12 hours.
May 10, 2016 | Computers & Internet
Tip
Quicken will not print more than seven checks.
You may run into this problem if you use the 2005 or 2006 version of Quicken’s personal finance software (such as Quicken Basic, Deluxe, Premier, Premier Home & Business). If you try to print eight or more checks at once, they won’t print.
According to Quicken Help & Support, Intuit fixed this problem for both the 2005 and 2006 versions of Quicken. You’ll need to download and install the latest patch, which includes the fix for this problem. Quicken offers manual and One Step Update methods to update your version of Quicken with the latest patch. You’ll need an Internet connection to download the patch. If you have a dialup connection, connect to the Internet before you start any of the update methods below. Once you complete the patch installation, Quicken will be able to print eight or more checks.
To read Quicken’s solution for this problem, visit www.quicken.com, click Help & Support, and then select 2006 For Windows (make sure Quicken For Windows and Quicken 2006 appear in the Product fields). Next, type 2997 into the Search field and click Search.
Update Quicken 2005 manually
Visit Quicken Help & Support, select 2005 for Windows, and enter 3810 in the search field. Open the How Do I Manually Update Quicken 2005 For Windows To The Latest Release? link. This page has all of the patches for Quicken 2005. However, you only need to download the patch that has the highest R number. The latest patch carries all of the data from the earlier patches. In this case, you will want to download patch QW05R5PATCH.exe.
Click the file’s link. If you have Windows XP, a File Download – Security Warning may appear. Click the Save button. In the Save As window, choose a location to which you’d like to save the file and then click Save. When the download completes, simply double-click the file to start the patch installation.
(NOTE: This method involves downloading and installing a single patch file. If you don’t have an Internet connection but have a friend who does, you can download the file to his PC and then burn it to a CD [assuming your friend’s PC has a CD-RW]. Use the CD to transfer the file to your computer.)
Update Quicken 2006 manually
Visit Quicken Help & Support, select 2006 for Windows, and then enter 3796 in the search field. Open the How Do I Manually Update Quicken 2006 For Windows To The Latest Release? This page has all of the patches for Quicken 2006. However, you only need to download the patch that has the highest R number. The latest patch is QW06R3PATCH.exe and carries all of the data from the earlier patches.
Update Quicken 2005 Or 2006 With One Step Update
You can also update your version of Quicken using One Step Update. You can start the update by clicking Online Menu and then selecting One Step Update. Next, uncheck any checkboxes that appear and then click Update Now. The tool will download and install the latest update for you.
by: -micromaster
on Mar 19, 2008 | Intuit Quicken Basic 2004 (028287007543)...
How do I install patches?
Download n install 2 softwares for G2 from ZOOM website.
1. USB subsystem. Driver to connect zoom fx to PC/Notebook.
2. EDIT & SHARE. Software to create/copy sound patch.
Connect USB cable from G2 to PC/notebook.
No need adapter power supply, because the power is supply via
USB cable from PC/notebook.
Open EDIT & SHARE. It's easy,like copy,paste,rename,delete etc.
Just open the menu that you want to do and follow the
instructions. Sound patch can be load from files that you
download, or create it in EDIT & SHARE.
Patch can be load one files or group. Right Click the sound that you want to change,copy-paste it from new file/sound.
You can import/export files/patches from/to PC library (downloaded files).
It is recomended that you save/backup your original files,before load new sound.
I hope this helps.
Regards.
Aug 31, 2015 | Zoom G2 MultiEffects Guitar Pedal
Adobe acrobat distriller 3.0
SYSTEM REQUIREMENTS
Perl 4 or later installed on any of the following systems:
IBM AIX 4.2 or 4.3 with IBM?s Y2K patch installed
HP UNIX 10.x or 11.x with HP?s Y2K patch installed
Sun 5.4/Solaris 2.4 with Sun?s Y2K patch installed
Sun 5.5/Solaris 2.5 with Sun?s Y2K patch installed
Sun 5.6/Solaris 2.6 with Sun?s Y2K patch installed
Sun 5.7/Solaris 2.7
18 MB of hard disk space for Acrobat Distiller
32 MB RAM
INSTALLATION INSTRUCTIONS
The Acrobat Distiller 3.02 for UNIX Y2K Patch consists of two files:
-the distill file, which is the Distiller startup script.
-the distill.y2kfix.pl file, which is a Perl script that is invoked by the Distiller startup script.
To install the Acrobat Distiller 3.0.2 Y2K Update:
1.Make a backup copy of the distill file, which is located in the Distiller 3.02 installation directory. For example: cp distill distill.bak
2.Copy the distill file and the distill.y2kfix.pl file included in the archive to the Distiller 3.02 installation directory.
3.Make sure that the distill.y2kfix.pl file has execute permissions. For example:
chmod a+x distill.y2kfix.pl
4.Modify line 1 of the distill.y2kfix.pl file so that it contains the pathname to the Perl interpreter installed on your system.
5.Modify line 16 of the distill file so that the "install_dir" contains the pathname to the Acrobat Distiller 3.02 installation directory.
Oct 29, 2014 | Adobe PageMaker 7.0 for PC
How do you active a patch for a game once you download it? It is an unofficial patch
This depends on the game and who made the patch.
MOST patches have what is called a self extracting installation file.
Assuming this is a windows machine.
It should have an .EXE extension. Double clicking this will cause the file to execute and install. Be careful however. Unofficial patch Screams VIRUS!!! Also keep in mind running patches will cause anyone with a different version number to be unable to connect with you in a multi-player game.
Use caution and certain of who and where this patch came from.
Oct 03, 2009 | Jade Empire Special Edition for PC
Upgrade for settlers downloads but won't run
I had this issue as well. Download the patch directly from the website, and run it locally. Afterwards the updater won't find a newer patch, and goes directly to the game. I don't know whether this will break again once a new patch is released, but you should be able to manually install it again at that time. Patches can be found at http://www.ubi.com/US/default.aspx under support --> patches.
This link may take you directly to the right place.
http://www.ubi.com/US/Games/Info.aspx?pId=5923&tab=download&dcId=63
Aug 02, 2009 | Ubi Soft Entertainment The Settlers: Rise...
Where to get games for r4 cards
ok look up roms for the games but i dont how to work ds games which most people ask for. i have heard of a way to hack the capabilites of the ds with two cards one the PASSME card which is the ds carttridge and then the micro sd card slot that is the GBA slot on the bottom.
Super Nintendo games and any games before need emulators.. and the emulators need to be patched before they play.
google up super nintendo roms or the the title of a game and then rom.. Mega Man X3 rom
patching
ok here we go!!!!!!rusty on this!!! so ur card is working but games no.. well if ur emulators are not pacthed they wont start so patching the emulators [or programs like ultra thing] will make sure its runs on ur R4 and make sure you download files for R4. here are the files and sites
http://hbnds.biohazardteam.org/ has emulators!! they let you play snes nes and more
http://chishm.drunkencoders.com/DLDI/#patchers ok go to the R4 files for this site ok and also it has the patching programs on the bottom Win32
extract the file ok get the dlltool32.exe file and drop it in a folder on your desktop and put the file for your R4 in the folder to and the emulator also then run program dlltool32.exe and chose the patch file you downloaded and the emulator file and run it! it should say patch success and now set the emulator and any files it came with and add games in the card and run it should work
Jul 02, 2009 | Nintendo DS Lite Console
Quicken 2004 Installing on Windows Vista
Jan 18, 2008 | Intuit Quicken Basic 2004 (028287007543)...
Help me..........
First check IMEI using *#06# If imei is digits solve this problem by using Init Simlocks in UFS If imei is ????...4 This can be solved by Patch option in UFS
Feb 05, 2007 | Nokia 1100
Computers & Internet Logo
David Payne
David Payne
