Question about Amptron G19FP 19 (Bezel, Charcoal, Titanium) 19 in. Flat Panel LCD Monitor
Mointor my screen goes red and say out of range when i plug it into the computer.
0 characters
1 Points
Samsung lcd monitor warranty check
Its main board should be replaced
Jun 20, 2013 | Computer Monitors
White display LCD TV
The screen glowinh white mean it is not getting voltage to the LCD controller, the ribbon cable may have come lose. You need to open it up and look inside.
See some pictures here:
Mar 29, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
E207WFPc Dell Monitor goes black after seconds of poweron.
The problem you have mentioned may not be due to contrast setting but the LCD itself . Power on the mointor and disconnect the signal cable from the back. if you see a self test box running on the LCD , the LCD is oK . If you donnot see the self test box the LCD is back. Dell doesnot service LCDs and you may need to get in touch with the local repair shop.
Following link may be helpful
Thanks for using Fixya
Jul 27, 2009 | BenQ FP92W LCD Monitor
My dell E196FPF 19'' lcd screen acting strange!
Are You using a extention cord or a ups that is not funtioning properly....?? if yes try connecting the power for the monitor seperately or directly to a plug base...
this mi8 solve ur problem
Apr 10, 2009 | Dell E177FP LCD Monitor
Out Of Range
It means the LCD does not like the resolution or refresh signals from your video card. Try a resolution like 1024 x 768 at 60 or 72 Hz refresh.
Monitor Mike
Jan 03, 2009 | Star Logic 17" LCD Monitor
My mointor
Probably the LCD panel itself has gone bad. The tab board in usally the problem. The welds between the glass and board go bad.
May 27, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Samsung 931B SyncmMaster
THE ONLY WAY THIS WILL CHANGE IS IF YOU HAVE A DIGITAL INPUT SOURCE CONNECTED to this mointor like HDMI AS THIS MOINTOR AUTOMATICALLY SENSES ANALOG SIGNALS AND DIGITAL INPUT SIGNALS if a digital signal is available it will switch over if a digital input singal is not available you will only be able to use the analog option
Jan 11, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Moniter won't turn on
Probably cheaper to replace this mointor with a new lcd which uses 50% less current.
even if you find the parts to fix it i suggest replacing this moinitor altogether electrical failure is a sure sign of other problems in the future.
Oct 23, 2007 | Acer AC711B 17" CRT Monitor
Amptron G19FP 19 (Bezel, Charcoal, Titanium) 19 in. Flat Panel LCD Monitor Logo
16 people viewed this question
Top Amptron Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you an Amptron Computer Monitor Expert? Answer questions, earn points and help others
