Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Wireless entry pad
My wireless pad will not reset, I have changed the batteries (two different batteries) and I have reset the remote controlls. The remotes work fine. I have noticed that the last 30 or 40 times I used the wireless pad that I had to try it upto 6 or 7 times before it would kick in
  • padnowork Dec 04, 2008
    You are the man. Thanks.
    President:
  • 2,992 Answers
It sounds like either the keyboard is bad, or the transmitter is slightly off-frequency. In either case these units are not repairable. There's no replacement keyboard, and it would cost less to replace than to have a shop check the radio part.
Posted on Dec 01, 2008
My keyless entry pad will let garage down when code is keyed in, but when code has been keyed up to let it up it will not do so.
I assume you mean that the entry keypad works when the door is open but not when the door is closed. This usually indicates that the signal strength on the entry pad is low. Try changing the battery.
Insert a small Philips screwdriver in the opening on the bottom of the battery compartment cover. Pull the cover slightly outwards then pull the cover down. The battery in the compartment is a 9V battery. Then replace the cover by inserting the lip in the top of the battery compartment and then snap it into place.
If you change the battery quickly, you shouldn't need to reprogram the opener. If a new battery doesn't solve the problem, check what may be causing signal interference when the door is down. (Consider moving the keypad to a spot closer to the door opening. I know that we have the keypads placed on the side of the door jamb on our garage doors. When the small handheld remote units start to loose their batteries, bringing the remotes to that area that often works.)
I hope this helps.
Oct 04, 2013 | Sears Craftsman LiftMaster Chamberlain...
Reset Craftsman keyless entry pad.
What you are asking for is not possible. You need to call a garage door repair technician. They will drill a hole through the door and using a special tool can pull the rope to release the door.
Sep 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Changed code on the wireless chamberlain security key pad
Does it work from wall button? Hit learn button for 10 seconds. Hit again for 1 second and code keypad.Opener lights should blink 2x. Hit learn again for a second and hit button on a remote (Any button you chose). Again, lights should blink. Now should work. Repeat for any other remotes.
Jul 24, 2009 | Chamberlain 950CB Remote Control
LiftMaster 1/2hp: Key Pad Won't Work!
If you have a wireless keypad replace the battery.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keylees entry and remote controls do not work at the same time
There are two types of technology with this operator (rolling code and non-rolling code). This operator will except one or the other but not both. It is not uncommon for a rolling code (Security+) remote or keyless to lose the "rolling"part of its technology and become a non-rolling code device so it is not compatable with the rolling code technology. You will need to replace the one remote or keyless that is not like the others.
Nov 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
65 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
