Question about Compaq MV 540 15" CRT Monitor
Speaker wiring i can't get the speakers to work. so i want to know what plugs into what.
    Problem Solver:
  • 47 Answers
The audio out cable (green ended wire sometimes) goes into the audio out socket of your pc. (both are green some in cases with older computers then it will be the middle on of the 3 sockets) if you have more than 3 audio sockets then they will indefinetly be colour coded. if you have a sub and/or remote, plug the left speaker jack into the white socket and the right speaker jack into the red socket of either the remote or sometimes the sub. then just plug it into the wall and adjust the volume control via the start menu and the remote if you have one.
hope this helps
kev
Posted on Dec 01, 2008
Please help me install a kenwood cd player in a 1995 GMC sierra truck the plug is cut off and i dont know the wires
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Nov 27, 2011 | 1995 GMC Sierra C1500
How to connect all components to work
you will have all them all in user manual itself right?
Jun 08, 2008 | Audio Players & Recorders
Plugged in a Kenwood stereo in a 2000 tahoe. Have all power but no sound. Radio is not defective. When plugging the same stereo into a 99 express van, it works just fine. My question... What is the wiring...
Hi, your factory wire colors are below. Please let me know if you have more questions.
2000 Chevrolet Tahoe Car Radio Wiring Schematic
Car Stereo Dimmer Wire: Brown
Car Audio Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Car Audio Rear Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Doors
Feb 10, 2011 | 2000 Chevrolet Tahoe
The wiring harness. To the stereo has been cut. I need to install oem stereo and don't know where to start to find which wire hold the ground or power.
1998 Chevrolet Malibu Car Stereo Wiring Diagram
Car Stereo Antenna Trigger Wire: Pink
Car Audio Front Speakers Size: 4? x 6?
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Hope this helps (remember to rate this).
Nov 05, 2010 | 1998 Chevrolet Malibu
Installing Labtec LCS 800 speakers
1 wire goes between the 2 speakers
1 wire goes from the speaker with 2 jacks in it to the computer, the back of the computer should have a green port to plug in the cable to
1 wire is the power
this is a guess without seeing your setup
Feb 17, 2009 | Labtec Audio Players & Recorders
Left Channel Not Working.
Has it ever worked?
Try this - connect one pair of its speaker wires at a time and test it. Watch the polarity.
• Make sure all cube speaker arrays are connected to the proper terminals according to their
position in your room.
• Check to be sure all wires are connected to your surround receiver with the proper polarity
(+ to + and – to – wires). Incorrect wiring can result in a total loss of module output.
• Correct any wiring problems before you plug in your receiver and turn it on.
How do you know the receiver's Left channel isn't the fault? Sounds like a source issue.
Jan 04, 2009 | Bose Acoustimass 16 Speaker
Wireless speaker won't come on after plugging in now....
Try the adaptor that you know works in the speaker that doesn't. That will eliminate if its the adaptor or the speaker. You will need a multimeter to check if its the on /off switch or not. A quick alternative is to "bridge" out the on / off switch wiring. (Use a piece of wire to join the wires going through the switch together.)
Sep 04, 2017 | Acoustic Research 900MHz Wireless Stereo...
Digital clock
Here is a wiring diagram of the radio by wire color:
Radio Constant 12V+ Wire: Green/Yellow
Radio Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Green
Radio Illumination Wire: Light Blue/Red
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Blue
Radio Amp Trigger Wire: Blue (Same as Antenna Trigger)
Front Speakers Size and Location: 5′ x 7′ Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers SIze and Location: 5′ x 7′ Rear Deck
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Aug 14, 2008 | 1988 Ford Mustang
Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Jan 15, 2008 | Altec Lansing VS4121 2.1 Channel Powered...
Rear left speaker not playing
If the speaker itself is working then the problem will most likely be the connection point where the speaker plugs into. If you dont know how to check for this problem, i dont really want to tell you just in case you hurt yourself. Take it to a shop and have it looked at by someone thats knows what there looking for.
Sep 06, 2006 | Logitech Z-540 Speaker
Compaq MV 540 15" CRT Monitor Logo
53 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
