Question about KitchenAid Refrigerators
I have a kitchen aid side by side build in 2000. The freezer and frig are not being cooled. The fans come on, and the compressor sounds like it comes on for a few seconds, then I hear a click and it sounds like the compressor is shutting down.
  • vze2jk Dec 05, 2008
    It turned out to be the relay. Thanks
    Sergeant:
    Champion:
  • 291 Answers
You may be able to get by with a start device for your compressor but if not you will have to have compressor replaced / if you like i can try to help with a start device / larryyb
Posted on Dec 01, 2008
  • Larry Youngblood
    Larry Youngblood Dec 05, 2008
    the relay is the start device ,,,, have a good day / larry
Frig is making loud noise when it turns back on to cool.
proberly ice build up around the fan motor.You may have a defrost problem.
Oct 16, 2014 | KitchenAid Whirlpool Kitchen Aid...
Refrigerator kitchen aid
Might be a defrost problem. or maybe a damper or bad fan motor. Look in the freezer for signs of frost on the back wall. If you see it then that means the frig is not defrosting. Unplug the unit for a few days and if it goes back to normal operation that will confirm a defrost problem.
May 22, 2013 | Refrigerators
Not cooling good
There is a fan down by the compressor that aids in cooling compressor and getting rid of the water that comes out of the freezer during defrost cycle. I am sure that you took the paper cover off the back of the unit on the lower back side so your unit might not have a fan. Now lets look at the fan inside the freezer is it running can you hear it when you open the door? Does the compressor make a clicking sound as it is hot to touch and trying to come on? get back with me ok ken
Jan 31, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Unit doesn't work when icemaker is on- Kitchen Aid Superba
that is unusual for the ice maker to cause it not to cool, but definitely not unheard of. if the fill tube to the ice maker, or ice maker itself, is leaking down the back of the freezer, behind the evaporator cover, it would form ice around the evaporator fan motor. this would cause the fan not to run, and the temp in the freezer and frige would rise. the ice would melt when it went into defrost, but then build up again. you should remove the rear panel in freezer and see if you see any ice build up around the fan blade, and if so, find where it is coming from. I hope this is the case for you. much cheaper than a compressor or new frige if it is. let me know if you have further questions. good luck, shane.
Sep 10, 2009 | KitchenAid Superba Architect KSCS25INSS...
Divider strip between fridge and freezer is hot
First take the grill off at the bottom under the doors look at the grate under the frig That is your condenser it will probably be covered in dust clean it off the see if you can fill air blowing under the frig there is a fan under there that keeps that coil cool and it runs around the door to keep condensation from build around the doors if no air is blowing take the back panel behind the Frig and there should be a fan running if the compressor is running this will also cause the compressor to over heat and will not cool as well but it might just need to be cleaned Good luck
Apr 03, 2009 | KitchenAid KSRG22FK Side by Side...
I have an amana side by side refrig, the frig side cools a little
sounds like yhour compressor is not runnning, look behind the unit and se of the fan down below is turning and if the compressor is cold, or overheated and redhot
Mar 09, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Whirlpool refrig not cooling
is the fan in the freezer working when compressor is on? if not you need to replace it. do you have a large frost build up on the back wall of the freezer? if so you have a defrost problem, or back to the evaporator fan. If the fan is working you have a defrost problem which could mean a bad heater, timer, or bad defrost thermostat....
Jan 03, 2009 | Whirlpool GS6NBEXR Side by Side...
Amana afd2535deb Frig- freezer works fine but frig doesn't cool
If the compressor didn't come on the freezer wouldn't work at all. The problem is in the inside fan on the fridge side.
Nov 09, 2017 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Refrigerators Logo
107 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
