Question about Sony Playstation 3 (PS3) Console
Sony PS3 will not power up -
Playstations 3 is plugged in and all of the color coded plugs in the TV, but will not power up.
  • jilliannas23 Dec 30, 2008
    Kiddo's PS3 will not turn back on now. Makes one beep like it is going to turn on...then two beeps and goes off. Everything is plugged in right. No warranty on it so not sure what I should do.
    Problem Solver:
  • 18 Answers
1. First check the power cable by removing it and then plugging it in again. You may find it is not pushed in far enough.
If that is good then follow these steps
  • The console might not be turned on. Turn on the console using the main power switch on the back of the console.
  • Make sure the AC power cord is securely connected.
  • Visually inspect the AC power cord for damage. Do not use if frayed, cut, or damaged in any way.
  • Confirm the wall power outlet is active (receiving power). Try a different power outlet.
  • If possible, test the power cord by connecting it to a different PLAYSTATION 3.
  • If possible, try another AC power cord on your PLAYSTATION 3.
  • If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PLAYSTATION 3 power supply and the PLAYSTATION 3 may need service.
  • Make sure the vents are not obstructed in anyway.
  • Make sure there is adequate ventilation for the PLAYSTATION 3. There should be at least four (4) inches of clearance between the air vents on the system and any walls, televisions, entertainment centers, etc. Otherwise the unit may not function properly due to what are actually environmental issues.
I hope this helped
cheers
John
Posted on Dec 02, 2008
When i turn on my ps3, the green light stays on and the tv screen doesn't even change. i changed the cords to make sure the audio/video wasn't just out. i tried to enter 'recovery mode' but it won't even...
If you have a "slim" ps3, it does not beep 3 times. Try this.
First, with the system off,plug in your old red, white, yellow cables into the tv. (make sure your tv is on the correct setting). Now, just turn on the ps3 the regular way. Did you hear the sounds it normally makes when booting up (the ps3 boot music?). If so, thats good. If you did not, check again that the tv is on the right channel, and if possible, try another set of red, white, yellow cables.
If you heard sound, but do not get a picture, turn the ps3 back off. After the red light comes on, hold your finger down on the power button for about 5 seconds. If you have a fat ps3, it will beep 3 times after a few seconds to get back to regular tv mode. If you have a slim ps3, it will beep once, then 1 more time a few seconds later. It should reset and turn back on. If your tv is on the right channel and the cables work, then you should now see a picture and you know your audio/video is working. You can now try your HDMI cable and it should prompt you to use the HDMI at this point.
Hope that helps.
Mike!
Mar 02, 2011 | Sony Playstation 3 (PS3) Console
Tip
How to use a ps3 wireless controller.
<span>Ensure your playstation 3 is properly set up and connected to Plug the power cord for the PS3 wireless controller into one of the usb ports on the front of the PlayStation 3.<span><br /><br /></span><span>Plug the power cord for the PS3 wireless controller into one of the USB ports on the front of the PlayStation 3.<span><br />Plug the other end of the power cord into the access port on the top of your wireless controller.Allow the wireless controller to charge, leaving it plugged into the PlayStation 3 undisturbed for several hours to gain a full charge.Disconnect the PS3 wireless controller from the power cord. Press the PS button to start up the PlayStation 3. The PS button is in the middle of the controller. It is clear and displays the PlayStation logo of a letter P and a letter S molded together into one shape.Use the wireless controller to control the PlayStation 3, exactly as you would have with a corded controller for earlier PlayStations.<br /><span><br /><br /></span></span></span></span>
on Dec 06, 2010 | Sony Playstation 3 (PS3) Console
My playstaion is plugged into the tv but its reading that there is no signal, ive tried it on two tvs and with two sets of input cables and nothing is working, it still reads no signal
Hello, you will want to try resetting the video output.Manually push and hold down the power button till you hear the second beep.This resets the video to composite(yellow cable)
Jan 09, 2011 | Sony Playstation 3 (PS3) Console
I need help setting up my ps3 to my phillips tv
Plug the colored wires in the colored sockets, then plug the power cord into a power outlet, these are often found on a wall. And don't forget you must also plug the power cord ON the ps3. Then open the tv, either by using the remote or also you can open it using the button on the tv. Then you open the ps3 and switch the input channel on your television until you see the ps3 display. After that pick up a wired controller, be sure it is wired if not it won't work. For the final step use the wire of the controller and wrap it around your neck. You will then proceed to pull as hard as you can for as long as you can, until you die.
Mar 24, 2010 | Sony Playstation 3 (PS3) Console
Powers on but won't feed through to the tv
you either have the wrong channel
if you have a tv make sure you have it set on tv if you have an hdtv set it on hdtv.
or the AV cable is not plugged into the right colors or you dont have the VIDEO cable plugged in
also ask a friend who has a ps3 to borrow there AV cable your AV cable might not work anymore.
Dec 23, 2009 | Sony Playstation 3 (PS3) Console
I have a Prima LCD T.V. and i have a PlayStation 2,3 And i need to know were to plug in the red yellow and white wires in too the back of the tv and also what channel to put it on so that i can play.
the cables and the connections are color coded..just connect the matching color cables to the back of the tv..power both ps3 and the tv on..use the AV settings on the tv to change to AV1/AV2 etc ,in some tv the button on the remote is labeled as 'source'..hope it helps..
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
I have power to my ps3 but no pictu on the tv.
Also, if it was previously plugged in to HD, it might need to be switched back to SD cable. To do this switch your ps3 off, then press and hold the power button when you turn it on. It will beep once when you turn it on, then beep again after a few seconds. Once it's beeped the second time the display settings will be reset and hopefully it will show up on the screen.
Aug 05, 2009 | Sony Playstation 3 (PS3) Console
Ps3 has no power
Well I think your house might have killed the PS3. I would recommend talking to an electrician about what happened.
You can try using a different TV and see what happens. However...
Unfortunately the PS3 is pretty much dead now. Hopefully its still under some kind of warranty or can still be returned (tell them it won't turn on). To replace the parts needed would require precise installment and should only be done by professionals.
Sorry for the death of the PS3.
Don't forget to rate :)
Apr 08, 2009 | Sony PS3 40GB Best Sellers Bundle Console
Hd tv as no hdmi plug
There are PS3-components cables available out there (the Red/Green/Blue one) you can use to connect your PS3 to your TV and still get HDTV on your TV system. You should be able to get it where you bought your Playstation. Got one for 39.99$ CAN
Cheers
Dec 22, 2008 | Sony Playstation 3 (PS3) Console
PS3 Sparks during hookup
u have a grounding issue with either ur cable or dish box,.and if u plug anything up to it it will spark adn shock and if u do it over and over it will fry the system,. hope this helps
Nov 19, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,248 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
