Question about Rainbow E series Canister Wet/Dry Vacuum
The beater stoped working .
I was vacuming when the beater stoped brefly then came back on . It did this for about five min, before it stoped working altogether.
  • christie_bri Dec 01, 2008
    Thanks, none of the contactes are burnt. Checked power with voltmeter no power at the handle. dose this mean Ihave to buy a new hose?
    Scholar:
  • 55 Answers
That sounds like a bad or burnt contact between one of the connections in the hose. Make sure all the connections are secure and look at the contacts, if they are bad you will usually see burn marks or melted plastic.
Hope this helps, and let me know if it doesn't.
Posted on Dec 01, 2008
  • David Cleary Dec 01, 2008
    If you have the switch turned on and no voltage at the end of the hose, then yes. It is most likely the hose. Not surprising, but I wanted you check for a bad connection first because that is a much less expensive fix.
    Usually if you take your machine to a local dealer they will let you put it on the machine to make sure that solves the problem before you buy it.
It smells like it's burning when I vacum/what's wrong with it
Tammy May:
Unplug the machine and remove the foot plate (at the bottom of the vacuum head) and check the belt that drives the beater brush/bar. if the beater bar is hard to turn, pull the beater bar and belt out, check the inside circumference of the belt to see if the motor shaft has worn it down in one spot. If so, remove the two bearings (one at each end of the beater bar) and remove the hair, carpet fibers, strings and any other junk from the bearings and the ends of the beater bar. lubricate the bearings with oil (thin machine oil like 3 in 1 oil works best. roll the bearings with your hands until they spin freely. Now would be a good time to check the bottom of the foot plate where the dirt is vacuumed up. check the hole in the middle of the foot plate and check the hose for clogs if the hole and foot plate hole are clear, reassemble the bearings on the beater bar and install the beater bar (with a new belt) and reinstall the foot plate. The machine should run well for you.
Jan 19, 2013 | Eureka Vacuums
BEATER BAR WILL NOT WORK. I ACCIDENTLY RAN VACUM OVER SMALL THROW RUG WHICH GOT CAUGHT IN BEATER BAR AND IT STOPPED AND I COULD SMELL BURNING. I SHUT IT OFF RIGHT AWAY. WHAT DO I DO?
remove the bottom of the machine, and if your lucky re attach the belt, if not replace it , you need to remove the beater bar to do this, so prior to taking it out, look at the ends so you know where they are and the positioning before you remove it for easy reattachment
Jul 03, 2011 | Miele Vacuums
I have a Hoover Windtunnel vacuum cleaner and new high pile carpet. The vacuum cleaner will not move forward without extreme effort. I have been told that I need a vacuum without a beater bar and that...
you can adjust the height on some vacumes like for bare floors and medium nap it will adjust how far the beater bar is from the carpet see if your is adjustable
Apr 11, 2011 | Vacuums
My vacum will not pick up, it is spitting the dirt out?
Check for blockage.
Most likely place is in the tube leading up from behind the beater bar. While unplugged, remove beater bar & belt & check.
If you have a strong shop vac, remove beater bar, belt, and bag, applying suction to the tube in back of the beater bar will many times dislodge the clog with little effort, sometimes though it will take some fishing around with a stiff piece of coathanger wire or similar.
Normally when you can apply suction with the shop vac to the tube in back of the beater bar & feel suction at the tube were the bag connects, you know you've got it all and you should be unclogged. Put it back together and you should be ready to roll.
Feb 11, 2011 | Hoover Tempo Widepath Upright Vacuum -...
My Fantom Fury upright beater bar stopped working.
Hi at the bottom of the vac were the roller brush is there is a cover you would have to take that off and then you will see were the belt is located
Oct 07, 2009 | Fantom Vacums XT450K Upright Vacuum
WHEN I TURN MY VACUME ON IT SOUNDS FINE, WHEN UPRIGHT. WHEN I GO TO MOVE IT TO HOOVER IT MAKES A SCREAMING NOISE. CAN U TELL ME WHAT IS WRONG PLEASE AND HOW TO FIX. THANK YOU
When the vaccum is upright, the beater bar is not engaged. When you tilt the handle back, the clutch engages and the beater bar begins to turn.
There are two likely possibilities for the "screaming noise". First, and most likely, is that the beater bar cannot turn because of a build up of debris or the beater bar is broken. In eaither case, the clutch belt is spinning on the non-moving beater bar causing the noise. Remove the beater bar, inspect for hair, carpet fibers or other items wrapped around the bar. Also inspect for cracks in the plasitc at the ends of the bar. Clean or replace the bar as needed.
The second possible cause is the clutch assembly. If you were unable to fix the problem with the first solution, it is time to take the vacuum in for service as replacing the clutch is somewhat difficult.
Here is a YouTube video link that will walk you through the process of removing the beater bar as well as the clutch if you decide to go it on your own: http://www.youtube.com/watch?v=7_CtaFcc5HU
Hope this helps.
Sep 23, 2009 | Dyson Vacuums
My roller do not spin
There is also a circuit protector which trips if something gets caught in the roller, so that might be the problem. There is a very small red button on the right side at the bottom of the vacuum (IT'S VERY TINY), and you just push that in and it will reset the circuit.
Aug 22, 2009 | Kenmore 31913 Progressive Direct Drive...
Beater bar not engaging,
The belt is in tact, but the beater bar will not rotate
Jan 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do i change the belt on the bissell powersteamer 1697w????
Ok taking the cover off is good. I believe the the little red thing is the beater bar. This beater bar has brushes on it an extends the width of the vacum. Pull the beater bar out straight. Some times it is tight. Next is to place the new belt around the spindle in the back and slide the beatrer bar into the belt. No twists! Besure to have the beater bar with the seperated area with no brushes inline with the belt.Now place the beater bar in place. Make sure you turn the beater bar so on the side the slotted portion slides all the way in place. Replace your cover. Turn it on and try it.
I believe this will work. Let me know.
desmjs
Dec 14, 2008 | Bissell 6594 PowerForce Bagless Upright...
Open Questions:
See all Rainbow E series Canister Wet/Dry Vacuum Questions
Rainbow E series Canister Wet/Dry Vacuum Logo
Top Rainbow Vacuums Experts
Doris Wittkamm
Level 1 Expert
Jim Parker
Jim Parker
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
