Question about Whirlpool ED2FHSS Side by Side Refrigerator
Overfilling ice tray with water
I have a ED22TQXFW00 whirlpool rifrigerator (side by side) when the ice maker fills up with water it is overfilling and running over. What do I do?
  • 114 Answers
Does the water eventually stop flowing? If not, your solenoid valve is sticking open and defective. If you also have ice and water through the door, this is a dual solenoid valve. If it does eventually stop, your ice maker could be sticking in fill mode. Either way this could be a potential for a flood. I would recommend replacing both.
Posted on Dec 01, 2008
Water overfilling the freeze tray on Whirlpool conquest ice maker
The overfilling is most likely caused by defective water control valve on the ice maker side. The replacement for your model is a=> W10408179 Water Inlet Valve
The water fill adjustment can be found in the Ice Maker Troubleshooting Service Manual These settings can cause too little or too much by turning the set screw so use caution. I will be here should you have questions or comments, Thanks Sea Breeze
Mar 08, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ED5VHEXVQ03 side by side. Ice maker is not making ice. Checked water line - okay. Checked water valve - okay. Water filling tray - okay.
Whirlpool Ice Makers are about the hardest working part on your refrigerator and their average life is about five years. You can fill the tray with tap water if the ice slots are already empty and let the water freeze. If after the water freezes and the ice drops to ice bin then the water control valve.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
Jun 29, 2011 | Whirlpool Refrigerators
The ice cube tray in the automatic ice maker overfills with water. After the ice dumps, the water for the refill overflows the tray and some goes in the dump bin.
Good day,
Sounds like a bad water valve located in the rear bottom of the machine. (not shutting down properly).
Solution is to replace the valve.
In extremely rare cases it can be a faulty ice maker.
The ice maker sends power to the water valve for 7 seconds on each cycle. If the circuit board in the ice maker malfunctions, it could cause this problem.
But again, very rare.
Dec 04, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
Kenmore by Whirlpool sxs water in the door. Ice maker 106.565424
The water control valve for the ice maker side is your most likely reason. If filling ice maker with tap water and allowing to freeze. If it dumps then the water control should fill. if not the valve is not working. Sea Breeze
Oct 16, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice Maker is not working on my Whirlpool Gold Refrigerator
I removed six screws from the ice maker to pull it out of the refrigerator.  Their are four screws holding the ice maker in place and two screws on the ice maker door.  Had problems getting the electrical harness disconnected.  Used hot water to removed the ice cubes that were struck in the ice tray.  Poured all remaining water into a bucket and re-installed ice maker.  As of now, the ice maker is making ice !
Apr 08, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Just installed ice maker cords, no water filling ice trays
Hi make sure that the arm on the ice maker is in the down posistion as it will only put water in the ice maker in this posistion. It will take a little time to fill so be patient as the timer in the front on the ice maker needs to cycle first. Make sure you have connected it all correctly to...
Dec 29, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice Maker overflow
my icemaker overfill can you help
Oct 31, 2007 | Refrigerators
Whirlpool ED2FHSS Side by Side Refrigerator Logo
236 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
