Question about Dell Latitude C400 Notebook
C 400 Latitude display problem
When I power on my C 400 Latitude note book, it does not show display. From top panel where ON button is fix, there are 3 LED indicators, LED 4 (Lock "A") blinks 10 or more times but note book does not display. after 15 sec it automatically power off.
  • m_ih2002 Dec 02, 2008
    I disassmbled all hardware i.e HD,RAM,MODEM and keyboard panel one by one with chak for repair my C400, for 2 times my system showed display for a moment, when I again assembled all hardwares, and powed on, it again showed only caps lock blinking.
  • m_ih2002 Dec 03, 2008
    Thanks sir for a good assistance like nice instructor. there is only one module of ram. during assembling/disassembling system give 2 time display.....but later become off.
    Master:
  • 474 Answers
That LOCK A sysmbol is the caps lock.
Most likely its due to hardware failure. Be sure the battery is holding a charge and the power adapter is working.
It could be bad Ram. Usually when there is nothing at all but a quick light on and off and nothing, its due to motherboard issues or hardware plugged into it. Try removing any CD drives or add in devices.
Good luck
Posted on Dec 01, 2008
  • Chris Busch
    Chris Busch Dec 02, 2008
    Hmm. well, how many Ram modules does it have? if it has two, try using one or the other and if one doesnt work and the other does, then it a bad ram module and replace that one.
    Im guessing the System board went out and unless you can get one for cheap, i would invest in a new laptop.
    I work with alot of the new dells and have had alot of them have bad mother boards.
    Have your tried powering it on without the battery in it and just AC power? If that works, then its the mobo battery connectors.
    If its none of these then im affraid it bad luck.
How do i use the percentage function?
If you want to find 25% of 500
ENTER....
500 X 25 [2ndF] % will display 125.
If you want to know what % a number is of another number like for instance...
What percentage is 120 of 400?
ENTER...
120 [DIV] 400 [2ndF] % will display 30.
If you want to increase a number by some percentage like
Increase 500 by 25%
ENTER...
500 + 25 [2ndF] % will display 625.
If you want to decrease a number by a percentage like
Decrease 400 by 30%
ENTER...
400 - 30 [2ndF] % will Display 280.
NOTE [2ndF] is the 2ndF button. Do not enter the brackets [ and ].
NOTE [DIV] is the divide button. The text editor would not let me enter the divide symbol
Jul 18, 2014 | Sharp El-w535x Writeview Scientific...
NOTE BOOK SCREEN DOES NOT COME ON
Screen does not come ON or not showing any display even the power LED is lit. Sometimes it is due to the laptop was not shutdown properly or the battery was drained or laptop was left idle. This is a simple solution that may fix the problem. If the power LED is lit, turn off the NB, remove all the power sources (battery and charger). Without the power sources, hold the power button for 10 secs and put the power sources back and turn ON the laptop. If this doesn't resolve the problem, it needs to be checked for possible Motherboard problem.
Hope it works!
Mar 12, 2011 | Acer Aspire One PC Notebook
I have a subaru liberty 2003, the display panel sh...
Drop me a note if you are still interested in getting this fixed. I may have the solution for this.
May 19, 2010 | 2005 Subaru Legacy
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
Dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Jul 16, 2009 | Dell Latitude D600 Notebook
Fujitsu Seimens T4010D Life Note Book
Have you tried to remove the screw thats connected to the Video connector as well. It is a hexagon shaped screw.
Jun 04, 2009 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Boot problem
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Apr 05, 2009 | Dell Computers & Internet
I'm getting c-6 400 code
This is a fixing error.But it can be caused by a power dip aswell.
Try to reset it,if the error presist then there is a problem on the fixing.
To reset-Switch the machine off,open the front cover,switch the machine on again.If it shows "open cover",press the system menu counter button.press the arrow up ones to display system settings,hold the start and # button in and press "ok"or"set"
go down with the arrows untill maintenance mode is display,press ok,then enter the number 163 and press ok.
set it for exeuteand press ok.
Then the error will be cleared.
Jan 22, 2009 | Copystar CS-1500 Copier
Dell Latitude C400 Notebook Logo
158 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
