Trying to use the bizhub 200 as a network printer.
Computor does not see the printer connected via cat 5 cable. How do I connect to this machine. Need step by step please.
  • 4 more comments
  • wrhdpw1 Dec 02, 2008
    Yes, I am able to access the admin settings of the router. It is a combo router/modem
    no i do not see an ip address for the bizhub
  • wrhdpw1 Dec 03, 2008
    password for copier does work. It shows an IP address and subnet mask. "network" is set to auto.
    there is no # next to gateway. Whould the gateway # come from the router? Whats next?
    The password for the bizhub does work. It shows an IP # and subnet mask #.
    There is no # next to Gateway. Whould the gateway # come from the router?
    Whats next?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Do you see an IP address assigned to the Biz hub in the admin settings of the router?
  • Tim Babcock
    There are quite a few steps to this. Do you have access to your admin settings on your router?
  • 2,794 Answers
First thing your going to have to do is go into the administrator setup of the copier by pressing the utility counter button. The password is 12345678 by default. Select network settings and enter an available ip address for your copier along with the subnet mask and gateway settings.
These settings work for a 300. I don't know if any of these changed for a 200 series. Let me know if they do.
Posted on Dec 02, 2008
  • Tim Babcock
    Tim Babcock Dec 03, 2008
    The gateway number is the IP address of the router. Once you populate that and it is set for auto, the router should assign an IP address to the copier. After it does, make sure the auto is off and that IP address is static in there. That way if the power goes out, it doesn't assign you a new IP address.
    When that is working, then we can get into setting up a port in Windows.
I have documents hung in que that has machine not printing
need details - what OS, is it hardwired via USB or connecting via network or wifi - could be port is blocked in your router's firewall, could be port is blocked in the PCs firewall, could be lots of things. Not sure what you mean by going online to clear documents - online where? is this a "cloud" printer? try shutting off printer for 20-30 sec then restart it - that may clear docs stuck in it's internal memory. going to need more details if you expect anyone to offer more detailed troubleshooting.
Dec 10, 2014 | Konica Minolta Bizhub C 353, Bizhub...
Konoka bizhub 200 need to connect to my computer
Have you given it its IP address? Is set up on a network or just a single computer? If single computer will need a cross over cable. Cat 5 do you print driver disk or down load from Konica Minolta web site download driver are free.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 20, 2014 | Konica Minolta Bizhub-200 Minolta Printer
My printer is not connected right
Do you mean router or switch?. Is this network Bizhub 200? Do have print drivers if not go to konicaminolta web site a down load FREE
Mar 20, 2014 | Konica Minolta bizhub 200 Printer
Network challenges
Sounds like your version of windows may not support your printer and or the drivers need updated. Possible firmware update as well
May 03, 2012 | Minolta bizhub 200 All-In-One Printer
Konica minolta c200 in network i want to scan in ubuntu 10.10
1 Download irfanview software from google and install it on your computer. 2 Now open the installed software. 3 click on file tab which is the first tab on the left. 4 Now bring cursor down and click on the 3rd last option which is select twain source. 5 Now you will see konica minolta c200 scanner in option menu. 6 select it and press ok 7 now again click on file tab and then click on acquire batch scanning option 8 place the document which you want to scan in pohtocopier machine and press ok from software. 9 scanning will commence and save in your computer c drive. usb cable or network cable must be connected with your system and machine. All the best
Mar 11, 2011 | Minolta bizhub 200 All-In-One Printer
We have a Konica Minolta Bizhub 250 at the office and I want to use it as a scanner...I connected the printer to my laptop using a USB cable but it doesnt send the scanned files to my PC. I'm not really...
First of all, bizhub 250/350 is not a single pc scanner.you cannot use it as a scanner by connecting usb cable with it.its a network scanner.so to use it as a network scanner, you have to do these main steps........
1-assign a free ip address to the machine.
2-ping it from the system to check the connection between machine and computer.
3-now, make a scanner one touch account on the machine.
4-enter computer's ip address in the destination option.
5-create a folder on the desktop of your computer and share it.give it full rights.
6-turn the firewall off.
7-enter the folder name which you have made, in the machine.
8-enter user name and password of your computer in machine.i mean while making scanner one touch account.
9-now place the original on glass and scan it........
Aug 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
I am trying to install my bizhub c250 through network cross cable with my computer. I adopted almost all the instuctions available for the configuration of the same but could not get a print through...
What you have done should have worked.
You may need to enter the IP address into the printer using the printer console not via the computer printer properties.
If it still does not work check the IP address range of your network card, the printer's Ip address needs to be in the same range, ie the first group of numbers must be the same, only the last group of numbers are different.
You may need to use a LAN hub with normal LAN cables and not a crossover cable.
Jul 23, 2010 | Office Equipment & Supplies
I cannot connect to my Bizhub 250's web page on one specific computer in my office.
if you cannot connect to your bizhub 250's page then please perform these actions to get rid of this problem.
steps are as follows:- 1-Check that your computer is connected with the machine via network cable. (via Hub etc) 2-if you know the IP adddress of the machine then ping it from your computer. 3-To ping an ip address simple go to "RUN" at the start menu. and type "ping _._._._._,_,_, (ip address of the machine" in the blank you will type the ip address which you want to ping. after entering press "ENTER" if it shows TTL=64, or TTL=32, OK then it means your machine and computer ids coonected with each other. 4-is still webpage is not viewing then install the page scope software or check your connection between machine and computer.
Jun 19, 2010 | Konica Minolta bizhub C250 All-In-One...
When I plug a cable into port 8 it will shutdown the switch
Your router supports a total of 8 connections. However, on the back there are 9 physical ports. Port 8 has two physical connectors where one (we will call it port 8a) is used to connect to a PC and the other (we will call that port 8b) is used as an uplink port. The uplink port (8b) cannot be used if something is pluged into 8a. If you are trying to use all 9 physical ports that is likely ther problem. If you need more than 8 devices connected to your switch get another 8 port switch (any brand will do) and connect the two switches via the UPLINK port with a 7 foot CAT-5 cable. Do not use a CAT-5 patch cable less then 7 feet long to connect two network devices together such as computer to switch or switch to switch as that will probably cause another problem with timing.
Another possibility is that the device at the end of port 8 has a malfunctioning network adapter. Try connecting a laptop to port 8a using a 7' CAT-5 cable. You may also want to try pluging the problem cable into another port as a way to test if the problem is somewhere along the cable run.
Oct 29, 2009 | Linksys EtherFast EZXS88W (DSLSEZXS88W)...
ENET Port issue on BEFW11S4 Wireless Router
Hi!
Try these steps:
1. Make sure the wireless is disabled when you're doing that. It might cause a confusion between the wired and wireless connection.
2. Try to plug it at other ports (1-4)
3. Try another known working ethernet or CAT-5 cable.
4. Set the laptop's LAN card's speed to 10-hald duplex.
Try these and hope it will help you ;-)
Apr 02, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
2,606 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
