Power save mode
Hi thanks for your help i remove the power cable for 15 Min's put it back in the computer turned on the power and the computer worked, but the next day it was back to square one stuck in power save mode at start up i got it wrong before i said stand by mode but it is power save mode it sticks in. the computer is my daughters and any help will be gratefully appreciated as i am not too clever with computers.
regards tony.
  • 5,318 Answers
Go to the control panel, then Hardware and sound, then under Power Options you will see change power settings. Select that and choose what you require.
Posted on Jun 21, 2017
  • 19396 Answers
SOURCE: stand by mode
Check the display cables , and if you have one test a different monitor on your computer.
If this is not a sceen problem, then it is an internal fault possibly the motherboard.
Try first leaving the PC power cord unplugged for ten, fifteen minutes and check if PC restarts afterwards.
Posted on Nov 28, 2008
  • 474 Answers
SOURCE: power save mode
Yes, you arent getting a signal to your monitor from your video card. Try replacing. If its onboard then the Mainboard may be bad. These machines are known by Dell to go bad and is covered under warranty, provided you still have it.
The message you are getting is coming from the monitor, not the P.C.
Its telling you you it went into power save since its not getting a video signal from the P.C. Check connections as well.
If your using any kind of splitter, remove it and connect monitor directly to P.C. to be sure.
Good luck
Posted on Dec 01, 2008
  • 72 Answers
SOURCE: monitor warning pc enter power saving mode
Are you using usb keyboard and muse. if so your usb ports are dead
Posted on Jun 16, 2009
  • 5 Answers
SOURCE: Can't get PC to boot up, monitor says power saving mode & beeps
Posted on Jul 13, 2009
  • 63 Answers
SOURCE: My monitor is stuck in Analog Power Saving Mode.
you can find it in safemode press f5 in boot up.
Posted on Sep 27, 2009
Ge x5 14mp
Your camera has a power save mode. When you put it in mode power save you can chose when he display should go off. It can be set to 30 seconds, 1 min, 2 min or OFF direct.
Check the setup menu, part about Power, and select 30 seconds. Or don't use power save.
I hope this will help you. (page 65 from he manual)
Jan 19, 2014 | Cameras
Gateway fpd 1530says
If you see a message box that says "Power Saving Mode" after pressing the power button, then it simply means that the monitor/display is not detecting the computer. Check the connection/cable between the display and the computer and make sure your computer is not in standby mode by moving your mouse.
From what you stated in your problem, you dont need a inverter or a bulb. If you have any image like the message box displayed then its working fine. It just isnt seeing any signal changes on the input and therefore goes into power saving mde. Try another cable or hook it up to a different computer to check the cable.
Oct 16, 2012 | Gateway FPD1530 15" Flat Panel LCD Monitor
My Dell 1300 Inspiron Notebook will not start up, it gets to two green lights but won't go to Four. I cannot get it to start in Safe mode, it will not recognize the command. It does recognize F2 and F12....
Hi petergreenus,
Have you tried draining the power of your system? Please follow the steps below on how to power drain your computer.
1. Turn off the computer.
2. Unplug the power cable from the outlet and remove the battery.
3. Now, press the power button for about 15-20 seconds.
4. Put back the battery in and plug the AC adapter.
5. Press the power button and try to observe the system.
Hope it helps.
Thank you for using FixYa.
Dec 04, 2010 | Dell Inspiron 1300 Notebook
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Jan 14, 2010 | LG Flatron L1750S 17" LCD Monitor
I have i canon mp210 i got the black and colour ink cartridge refilled, but when i put them back in the black and colour light still stay on. i have held down the stop/start button for more then 5 seconds...
Things to try, unplug printer for a min of 10 mins.
clean the chip on front of cartridge with nail varnish remover very lightly though.
Reinstall the cartridge holding down the button for a min of 5 seconds.
If that dont work maybe one of the cartridges have failed it does happen from time to time.
I have my own remanufacturing business so know the market & technology fairly well.
Nov 06, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Sleep mode wakes up on it's own
turning off all the power saving items does not help this- it just ensures that it doesn't automatically power down your hard drive or shut off power to your monitor automatically when you aren't using it.
May I suggest Hibernation Mode as an alternative? this mode saves everything you are doing to disc and shuts your computer down completely. when you turn it back on, it will restore what you were last doing onto the screen, so you can pick up where you left off.
you can find more information on this and sleep mode from here:
Aug 03, 2009 | Microsoft Windows Vista Home Premium with...
No picture on the screen
I have this Panasonic PanaSync SL70 17'' monitor, I don't use it often. It is still in very great shape. However, I tried to turn it on yesterday, I got a black screen. The power LED is on and I can hear the relay is clicking when signal received. I tried to remove the signal cable, I can see it turns to power saving mode. It seems that everything works fine except no picture. I am if the transformer is gone, but not sure. I am wondering if you can help?
Feb 19, 2008 | Panasonic PanaSync SL70 (White) 17" CRT...
My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
Dell E173FP stuck in power save mode
Just had the same problem... what worked for me was simple. Unplug the cable from the monitor, hit the power button a few times until Dell screen poped up with a few color bars because it knew it was no longer connected to a PC. Then plugged the cable back in and all was fixed.
Oct 13, 2007 | Dell E173FP 17" LCD Monitor
Right click on your desktop>Properties, then click on Screen saver tab, then at botton of the box you should see 'Monitor Power'. Click on 'Power' then Power schemes tab. Look at 'Turn off monitor' and set to 'Never'
Nov 30, 2006 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
