Question about Maytag MDB7100AWB Dishwasher
Dishes not clean
There seems to be water getting to the washer but not cleaning properly and leaving soap deposits on dishes especially in the top rack. How do you remove the top and lower spinners and tell if the center sprayer is getting water?
  • herbj Dec 01, 2008
    I also feel that I need to check the spinners top and lower. I had something in 2 of the holes in the bottom spinner that looked like paper, but I got it out and I am wondering if there is more stuck in the spinner. How do you get it and the top spinner out? Thanks.
  • 114 Answers
There may be a couple of solutions to your problem. First, if you are not rinsing the dishes thoroughly before loading, your sump area in the bottom of the machine will get clogged, thus preventing enough velocity to reach top rack. Second, and most likely, your water inlet valve (or solenoid valve) is restricting. You have a timed fill mode through the timer and if the valve is not opening fully, you do not get the proper rate of flow into the machine. Replace the valve and your problem will most likely be solved.
Posted on Dec 01, 2008
  • Dave Harrison Dec 03, 2008
    As long as the holes are clear and open, they should be ok. If you wish to take off the bottom arm, there should be some sort of nut (either a small wing nut in the center of the arm or larger nut around the outside of the arm) that will unscrew to allow you to take off the arm.
Kenmore 13789 draining/cleaning issues
Check your wash arms - make sure the holes or nozzels are clear (not blocked), and make sure they are free to turn. Make sure you are not over-loading the dishwasher or placing large plates or pans in front of the soap dispenser. Next is to check to see if enough water is going into the DishWasher (DW). This varies with different models, so it's hard to tell you how much is enough. Next thing to check is to make sure the heater is working to heat the water during the wash cycle. (Listen for the soap dish to open, then open the door 10 or 15 minutes later and see if the water is hot.) If your dishwasher has a removable filter, you need to take that out and clean it at least once a month. And finally, if your dishwasher is all encrusted with calcium and hard-water deposits, you probably need to run a dishwasher cleaner in the machine. (Use Dishwasher Magic, or Finish Corp's Dishwasher cleaner, or Glisten, or even Lemi-Shine detergent-booster powder or their dishwasher cleaner.
Hope this helps!
Dec 31, 2012 | Kenmore 13789 / 13782 Dishwasher
Dishes are not cleaned on the top level, the bottom level is OK, seem like the spray arm is not revolving
top spray arm will be blocked with sediment/food deposits etc remove clean thoroughly with hot soap water and shake/tap it on side of sink to dislodge deposits if the outermost holes are blocked the arm will not turn and you will get poor wash results.
Aug 17, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Filters clean, arms unblocked, salt and rinse-aid ...
Yes! you are already having the answer. check your water inlet flow. Clean the strainer at the machine water hose connecting end.
Check the drain filter also. Refer user guide for instructions on cleaning.
May 19, 2010 | Dishwashers
Maytag dishwasher
Go buy a product called Lemi-shine and run it thru your dishwasher empty to clean out any hard water and soap deposits. If you can try using only about 2 table spoons of detergent and stay clear of the premeasured tablets. Most of the dishwashers being sold are low water usage units and it is very easy to overwhelm them with soap. It also helps if the oils from the foods are still on the dishes. People tend to clean the dishes to much before loading them and then the enzymes in the detergent have nothing to attach to. Basically this leaves the soap nothing to attach to except the dishes and hence you get cloudy dishes with soap stuck all over them.
Jan 30, 2010 | Dishwashers
Leaves white on dishes
There are 3 standard answers to solving the white-deposits-on -dishes problem: 1) Use a rinse aid; 2) use less detergent; 3) use vinegar in the washer. If you have hard water, none of these may work, especially if you've had the problem for a while. Because phosphates were ordered removed from dishwasher detergents, hard water minerals can now react with the soap to create a heavy greasy-feeling scum. That scum can build up in the water lines, arms, bottom reservoir, and filter, providing an endless supply of goo to spray on your dishes. This can be fixed. You need to remove and clean out the spray arms, the filters, and especially the array of parts at the bottom of the tub. I've seen up to 1 cup of coagulated/crystallized scum in the bottom of dishwasher tubs. Once you clean out the scum, then run the washer empty with a completely full detergent cup on the highest temperature setting, extra rinse. Before you start it add to the detergent cup 1 teaspoon of TSP(tri-sodium phosphate), a very powerful phosphate cleaner available at hardware stores. Your washer will now have all scum gone from the inner workings. From now on you must always fill both your detergent and pre-wash cups to the max and use a high temperature water setting, extra rinse. Chemically what you're trying to do is adding so much detergent that the scum-forming reaction is overwhelmed by the dispersant action of the detergent, and the extra heat helps this to be more effective. I am not a fan of vinegar in the wash cycle. Why? In some washers the vinegar fumes can reach the exposed contacts of the printed circuit board or touch pad, corrode them, and then your washer won't work at all, along with being very expensive to fix.
Nov 28, 2009 | Maytag Dishwashers
Water & soap was coming out of the dishwaster. Replaced the seal around the door. Ran again on a pots & pan cycle to clean & it worked fine. Ran a normal cycle with dishes & soap &...
That sounds like the float switch is acting up. It is a mushroom looking device on the bottom that has a movable (up and down) plastic cup over the top. With the machine off, take the lower tray out and lift up on the cup--you should hear a faint 'click' when it nears the upper limit. It should also drop to the bottom when released. There may be food deposits that interfere with the proper movement of the cup. Are you using dish washer detergent only?
Aug 15, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Cutlery is cloudy and dirty, some food is dried onto knives and forks. Cups and glasses are cloudy and not clean on inside. Coffee or tea stains are not removed. Plates and soup bowls seem OK , and water...
they must have changed the way they treat the water in your area. those spots are caused by hard water. www.dishwasherfilter.com has a product out for this problem. it filters the water going into your dishwasher leaving them spot free and crystal clear with every load. you will love the way your dishes look.
Mar 21, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Dishes not getting clean
the problem is hard water leaving the residue. go to www.dishwasherfilter.com and get the dishwasher filtration system. it will reduce the hard minerals that leave the residue and your dishes will be clean as can be. it is very affordable and fits right under your sink.
Mar 10, 2009 | Maytag MDB6000 Dishwasher
Dishwasher Issues
I would try using a different soap or less of your current soap.
Jun 21, 2008 | Maytag 24 in. MDB4100 Built-in Dishwasher
LG front loader not filling properly
You have to remove the top of machine to have access here. Plug off the wall; you need a grip plier to loosen the clip to see what is blocking the hose.................refit carefully & firmly.
Nov 03, 2007 | Kenmore 44102 Front Load Washer
Maytag MDB7100AWB Dishwasher Logo
384 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
