Question about E-Machines eMachines Monitor E15T4
Monitor - # E181h bm (18.5 in wide)
Stand that came with monitor is too low and can't adjust the viewing angle.
Any suggestions other than placing books under the stands???
Well, askergo.com had some fairly neat Ideas for under 10 bucks. Like a cubby hole type riser to place papers, pens, etc. with monitor sitting on top.
Posted on Dec 14, 2008
  • 3 Answers
Monitor is on but no display
Posted on Dec 01, 2008
Hp f1905 drops down
Contact HP by phone and they should help you getting another stand for your monitor.
Mar 26, 2012 | HP f1905 19" Flat Panel LCD Monitor
My Acer 21.5'' wide screen monitor shakes when I
Get a better stand to hold the monitor. There is nothing wrong with the monitor, it's the operator.
Jun 24, 2011 | Acer Computers & Internet
Black color missing on my screen acer e181h in place of black color, my screen has red. it is soooo hard to see. it happens randomly!
the problem might be with the video cable..try using a other cable if this doesnt work try going in the monitor menu an degaus it
Nov 05, 2010 | Acer AL1702bm 17" LCD Monitor
Someone asked me to take photos with my Nikon D90. I have the 18-105mm lens that I got with it. Is this able to take 'wide angle' photos?? I know there are special lenses made specifically for wide...
The 18-105mm lens at the 18mm end of the zoom range is a pretty fair wide-angle lens. Look through the viewfinder and turn the zoom ring (the big wide ring at the front of the lens) one way and then the other. The 105mm end is the view that looks like you're using binoculars, the 18mm end is the view that looks like you're using binoculars backward.
Oct 28, 2010 | Nikon D90 Digital Camera with 18-105mm...
How do I adjust the angle of my HP LE1901 monitor?
mcdevito75 here, Most Monitors will angle some what for ease of viewing by simply angleing by hand pressure, secure your monitor at the 3 and 9 O"clock position with your hands and see if this helps. Look at the base and back of your monitor for any levers, or knobs to loosen so you can adjust the angle. Remember you may not be able to angle your monitor and if not, you may have to use a better chair.
Jul 27, 2010 | HP LE1909W Monitor
How do i adjust the stand so that the monitor is is not to low on the stand
Here's the manual for your monitor.
http://support.dell.com/support/edocs/monitors/E176FP/En/index.htm
If you got it with the stand it usually comes with, I'm afraid the height is not adjustable. The screen can tilt toward you and away from you, but that's all.
Sorry I don't have better news!
Mar 13, 2010 | Dell E176FP 17" LCD Monitor
Hi I am running Triple Acer AL1912 LCD monitors on a Mo-View triple monitor stand. I have run these for a couple years without fail. PC is running 2 video cards a NVIDIA GeForce FX 5600 and a NIVIDIA...
Most comon problem with monitors are bad caps in the power supply, any good reapair shop should be able to fix them easily, see pictures of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
At least you will have some info so you will not get ripped off by repair shops.
Mar 01, 2010 | Acer AL1912 19" LCD Monitor
No sound from headset plugged into monitor
From the manual I found, this model does NOT support ANY audio connections.
http://www.p4c.philips.com/files/1/170b1a/170b1a_dfu_aen.pdf
170B Product Features
- 17" color LCD monitor with excellent display performance.
- Dual input-accepts both DVI Digital and VGA Analog input.
- Advanced AUTO adjustment automatically optimizes picture quality.
- Wide viewing angle technology.
- 7.1 (181mm) small footpring with full detachable cables.
- USB Bay for upgrade to USB Hub.
- Optional protective cover to prevent LCD panel damage.
- Standard VESA mounting holes and optional tilt/swivel Wall Mount Kit.
But if yours does have these ports, I would suggest they are not for a headset, but for connection to the _PC_. I would suggest your model monitor has built in speakers, and the green port is the INPUT from the PC Speaker output. The pink goes back to the PC from the MIC which is built into the screen.
Apr 21, 2009 | Computers & Internet
How to angle the monitor
I have Model X203H & had the same problem. The support CD explained how to adjust the monitor:
Screen position adjustment
To optimize the viewing position, you can adjust the monitor tilt by using
both of your hands to hold the edges of the monitor.
The monitor can be adjusted to 15 degrees up or 5 degrees down.
Apr 16, 2009 | Acer 22" X223w LCD Monitor
X2gen MG19E monitor
The only way to adjust the tilt on these monitors is to loosen the screws that attach the stand to the monitor. We had to completely remove the stand from the monitor to get to these stand screws.
Feb 12, 2008 | X2Gen MG19MY 19" LCD Monitor
E-Machines eMachines Monitor E15T4 Logo
193 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
