Question about Marvel 6BAR-BD Beverage Cooler
I have Marvel 6bar beverage refrigerator that suddenly stopped cooling- any suggestions on how to fix- I am trying to avoid paying a couple hundred dollars for repair thank you for your time
  • subdriver May 11, 2010
    What is the serial number of your unit? I would need this to know what control it has. You most likely have a failed thermsitor. Not easy to replace...but not rocket science either.
  • 93 Answers
If light work but not running at all, then change the temp control (thermostat). If compressor and condenser fan motor are running but not cooling, then you have sealed system problem
Posted on Mar 02, 2010
Marvel 6BAR Not Staying Cold
i don't know much about these units,don't work on them but work on sub zeros and have helped out some customers that have me look at them,usually what i find is when they are cool but not cold is the coil is blocked with dust and the heat can't escape from the machine,i use a shop vac,i vac out as much of the dust that i can see and then set it up to blow and blow out the coil,after doing this it usually works
Nov 19, 2011 | Marvel 6BAR Wine Cooler
I have a marvel wine cooler that frosts up and also tends to have temperture issues. Bottles on second shelf freeze. Temp adjustments to less cold make it too warm.
you have a restriction in the cooling side sounds like the filter line dryer is clogged up and will need to be replaced. Also the system will have to be recharged by a professional check to see if its in warranty.
Dec 17, 2010 | Marvel 6BAR Wine Cooler
Marvel 6BAR light does not illuminate. The bulb
More than likely your socket has a bad connection (probably the ground). There are two switches that can send the socket power...the door activaed switch and the manual override (ON/OFF button in the toe-kick). If you turn on the manual switch and the light is steady, then the door switch is bad. Otherwise I would trace out the connections on all the switches and on the back of the socket.
Dec 10, 2009 | Marvel 6BAR-BD Beverage Cooler
Everything inside the refrig is freezing or getting frozen. Soda can are exploding.
Either the unit is low on freon (as seen by heavy frost on the left of the evaporator and none on the right) or the thermsitor is toast and lying to the controller (most common cause). Call the factory at 800-223-3900 and order a replacement...PN 42244531 It comes with replacement instructions.
May 06, 2009 | Marvel 6BAR-BD Beverage Cooler
Refrigerator operates properly for a few days then stops working
When you said it stopped working, do you mean it is not working at all? or is it not cold enough? If not working at all, that will be thermostat, when you change the thermostat, did you adjust the small switches to match you unit and make sure wires are connected properly, If not, it would work properly. If not cold enough, check and make sure the condenser fan motor and compressor are running, if both are running but not cooling then you have sealed system problem.
Mar 28, 2009 | Marvel 6BAR-BD Beverage Cooler
Marvel undercounter refrigerator, works for a few days then stops
I experienced same problem with my refrigerator, Marvel ar61. Call Marvel and they will send you a repair kit which includes a new thermostat, switching relay and a new thermistor. My refrigerator is working great.
Marvel 6barbd undercounter fridge
marvel 6sbar-BD with wine storeage racks on the bottom and two glass shelves above. If I put sodas on the top shelf they expode. I have it on the lowest setting. Please advise.
Dec 22, 2008 | Marvel 6BAR-BD Beverage Cooler
Marvel 6bar-bd gets too cold - explodes soda can
I also have the same problem. Our Marvel 6BAR runs continuously until the beverages freeze. A technician came out and replaced the thermistor under warranty. It was a simple repair that anyone could do. This solved the problem for about another 18 months, but it has returned. I will now search for this part and do the repair myself. It only takes a few minutes to do.
Aug 30, 2008 | Refrigerators
Marvel 6BAR stopped cooling
The dip switches define the temp range. You have it set to the warmest. Try moving the next dip switch to move the range cooler.
Jun 23, 2008 | Marvel 6BAR-BD Beverage Cooler
Marvel 6BAR-BD Beverage Cooler Logo
807 people viewed this question
Top Marvel Refrigerators Experts
richie46
ray gallant
Are you a Marvel Refrigerator Expert? Answer questions, earn points and help others
