Question about WYSE Winterm 3235LE (90202401R) PC Desktop
WYSE 3235 thin client needs bios flashed
I have a terminal that won't boot past checking for the mouse and keyboard. I moved the terminal to another location using known good peripherals and it does the same thing. There is a procedure to flash a unit from a working machine but I can't remember how and not sure if it will work since the bad box won't boot.
Al Newman - Sears QMT
  • 3 Answers
Holding down the 'G' key while turning the thin client should perform a factory reset. If that doesn't work there is a program called NETXFER that will flash the winterm. You need a PC with a crossover cable or a hub(not a switch) to use the program.
http://www.wyse.com/supportdownload/8series/NetXfer%20Instruction.pdf
Posted on Dec 16, 2008
    Novelist:
  • 157 Answers
The easiest way to would be to take apart the machine so that the motherboard is exposed. Once you do, you will see a small, circular watch-like battery. Remove this for about 15-30 seconds. By doing so, it will perform a hard restart when the BIOS memory is cleared and you will have your original factory settings. If this does not work, consider the ports/card for the peripherals. Perhaps it is a hardware problem.
Posted on Dec 01, 2008
Yah but how to do you clear the darn passwords out??? That's the real reason we are here. Most people like me have bought these things at a second had computer store and the knuckleheads put AS-IS on the thing and sell em for 20 bucks!! Can't you help with this?
Posted on Mar 04, 2013
2 Suggested Answers
techjuli
  • 157 Answers
SOURCE: I have a WYSE 3235LE
The best solution for resetting the bios is to do a hard restart. This requires you to get to the motherboard and take out the battery for about 15-30 seconds before replacing it. By doing so, the temporary memory in the BIOS is erased and you will have you factory settings.
USB port on Wyse VX0 is not enabled. How do I access control panel to manage settings?
You have to enable it in BIOS. Look up how to get to BIOS on your particular computer. (Make & model)
Oct 24, 2013 | WYSE Winterm V90LE Thin Client - Thin...
I have a wyse winterm v30 thin client. what steps will it take in order to reload the firmware?
you can download this pdf guide from
https://support.wyse.com/OA_HTML/cskmbasicsrch.jsp?jttst0=6_23871%2C23871%2C-1%2C0%2C&jtfm0=&etfm1=&jfn=ZG455B66622DEA31A7AE70467E3EBEC537FE9176B1484EFD6E483B952B0ED1CF6F10611204C7B33B20AA233809D7249C41FE&oas=etuN3Cl3pQgYaOxTZDlD7w..&categoryId=10820
this will show you the steps to do a USB firmware upgrade.
Mar 20, 2011 | WYSE Winterm V30 Thin Client - Thin Client...
I am looking for thin client with ambeded processer with 4 GB Ram please tell me about thin client configaration
Hi DB_minse. Check out the Devon IT line of thin clients here: http://www.devonit.com/hardware - I believe the TC5c units can come as 4GB ram- and as far as I know they are a very good brand!
Feb 14, 2011 | WYSE R90L Thin Client AMD Sempron 150 GHz ...
Start Wyse S90 takes a long time
Try updating the OS from the Wyse website (using WSI, the new USB imaging tool, or WDM). It might simply be that the current image is corrupt. 10 minutes is excessive. It should boot in under 2 minutes easily.
Apr 15, 2009 | WYSE S90 THIN CLIENT KB/MSE XPE...
How can i reset S30 wyse box
Try a G-key reset.
Failing that use WSI and an S30 image from the wyse Website.
WDM also has the option to to re-image the client.
You may also be able to get into the control panel of the terminal, and download an FTP image and set the terminal to upgrade from the image when uploaded to your ftp site. From the control panel, you can initate the upgrade manually
Mar 24, 2009 | WYSE Winterm S30 Thin Client - Thin Client...
Wyse v90l
Best thing to do here is a re-image the client using the tools on the Wyse website.
The new USB imaging tool is pretty handy at imaging this model, and should get this back to a default image and working very quickly :)
Jan 14, 2009 | WYSE V90LE Thin Client VIA 1.2GHz, 1GB...
I have a WYSE 3235LE thin client in a Sears retail environment. I need to reset the bios. There is a way to flash it from another terminal but the bad box won't boot. It stops with keyboard/mouse error....
Dec 01, 2008 | WYSE Winterm 3235LE (90202401R) PC Desktop
WYSE Winterm 3235LE (90202401R) PC Desktop Logo
1,327 people viewed this question
Top WYSE Computers & Internet Experts
Archie Ferrarini
Archie Ferrarini
Daniel
Daniel
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
