Question about Kenmore Elite 45986 Front Load Washer
Kenomore He washing machine on frix, error codeF30
Stopped machine to add more clothes and now won't restart. Manual says to maually drain, more dial to spin drain, just getting clicking noise. Did receive codeF30.
  • 240 Answers
Take off top cover, look at dispenser unit on left side. arm is getting caught on pin on left. try unsticking or bending plastic arm down. or replace servo motor asm. with arm. take off arm and try moving pointer back and forth to check for free range of motion. should not stick. pointer/nozzle is part of dispenser housing asm.
Posted on Dec 03, 2008
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Washing machine not draining water
What is the model number of your unit?
Nov 27, 2012 | Washing Machines
The washer was completing a normal cycle. Then I noticed that it had stopped at the drain/spin. It was performing a spin but stopped with a big clunk and then just sits there. I have removed all the...
possible jammed or blocked drain pump......find the pump and check it for blockages.....if you drop the hose on the ground water should run out ......
Feb 10, 2011 | Washing Machines
Washing machine will not drain
sounds like the heater has gone it will stop in cycle if it does not heat up or it washes forever
switch off the machine turn the dial to spin to get your clothes out
get a expert in to check the heater
Jun 27, 2009 | Bosch Washing Machines
Error code F-28
It may be that the drain pump is not the problem at all. Error Code F-28 on the Kenmore HE2 means that there is a signal error between the Central Control Unit (CCU) and the Motor Control Unit (MCU)
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Kenmore Elite 45986 Front Load Washer Logo
60 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
