Question about Dryers
I need to replace a timer on my series 90 kenmore dryer. I cannot figure out out to remove the control panel to gain access.
  • 291 Answers
You should have 2 screws at each end of console panel to remove and then pull out at bottom and swain up or 6 screws on back of console and back panel comes off
Posted on Dec 01, 2008
Need to remove lower panel
Some lower panels are a friction fit and may have to be carefully pried off to gain access inside.
Mar 04, 2014 | Kenmore 659 Electric Dryer
My kenmore 500 series dryer will not turn on! it has power to the unit
The dryer could think the door is open so it will not start the cycle when the start switch is pressed. You will need to remove the door switch to gain access to the wires on the switch. Remove one wire and tape it to the other wire. Try the dryer to see if it starts the unit. If it does turn the timer to off and order a replacement switch. If drum did not start to turn then you want to lift the top of the dryer to gain access to the start switch. Again remove one wire and touch it to the other wire to see if the drum starts to turn. If it did order a new start switch and replace it. The next item to check is the belt around the drum making sure it has tension on it. If not you will have to remove the front lower panel making sure the belt is around the motor pulley and tension rollers. Make sure the motor has voltage by using a volt meter. I do not have the schematics for this unit, and the last Item would be to check the thermal cut off and to trouble shoot the timer circuit.
Feb 11, 2011 | Kenmore 500 6952 Dryer
The off/on pull switch appears to be broken. I suppose we need a new part and someone to help me. Will you please advise? Thank you. Bill Anderson
If your handy enough to attempt to replace the control timer yourself..You can start by unplugging the dryer first and removing the screws on the rear of the control panel...You'll then need to slide a flat screw driver under the clips located on the left and the right sides of the panel that attach to the top lid of the dryer... its a little tricky but you'll figure it out... once inside the control panel remove the nob from the timer and remove the wiring clip attached to the timer...remove all the screws holding the timer in place on the panel...A new timer could cost up to $85.00 it depend on the model...Good luck
Apr 20, 2010 | Kenmore 64902 Electric Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
My Kenmore Series 90 dryer won't run as it appears the door does not hit the actuator. It would appear either the door has moved to a lower position or the actuator has moved up into the dryer. May I ask...
The door switch or actuator is broken. A common problem. On most Kenmore dryers this is replace by lifting the top. Since you haven't given the whole model number I will discuss raising the top on the most common model.
If your model has a lint filter at the top the slide show below should show you how to raise the top.
Kenmore Dryer
Disconnect power to unit. Lift the cover from the lint filter or if yours is the one with a filter and cover together, remove the whole filter. You will see 2 screws under the cover/filter, remove them. Now, you will need a putty knife or a thin shafted straight screw driver to remove the top panel. Push the putty knife or screw driver to "pop" the front top clips. The top panel will hinge back towards the wall and can be left there. Just inside the top of the front panel, you will see 2 screws, remove them. You will see the wires for the door switch on the right side. *** the top of the front panel toward you to gain access to the switch for replacement.
Reverse process for reassembly. Good Luck
Sep 19, 2009 | Kenmore Dryers
Looking for a timer for a kenmore 90 series dryer Model M-460-G
HI, I would check the fuse in the dryer first. here is how: UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. This is very comon problem and the timer will still make a noise when the fuse is bad.
Please let me know if this help or if I can assist you further.
Mar 22, 2009 | Kenmore 75944 Gas Dryer
Kenmore 90 series won't start timer ticks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Motor removal and replacement on a kenmore electric dryer 90 series model# 110.86984110
remove screw at each end of console. pull & flip back out of way. remove top, remove bottom panel, slide putty knife to release both retainer clips. remove screws to remove door panel assy. remove belt, remove drum. remove motor clamps & remove wires from motor conector.good luck.
Aug 07, 2008 | Dryers
Dryers Logo
60 people viewed this question
Top Dryers Experts
