Question about WYSE Winterm 3235LE (90202401R) PC Desktop
I have a WYSE 3235LE thin client in a Sears retail environment. I need to reset the bios. There is a way to flash it from another terminal but the bad box won't boot. It stops with keyboard/mouse error. Yes, I tried another location with a known working unit's peripherals. Al Newman Sears QMT
  • wnewma0 Dec 01, 2008
    techjuli,
    I removed the cover to access the board but there is no discernable battery unless it is on the backside in which case I would have to remove too much and risk damaging the surface mount jacks. Thanks for the possible solution.
    Al
    Novelist:
  • 157 Answers
The best solution for resetting the bios is to do a hard restart. This requires you to get to the motherboard and take out the battery for about 15-30 seconds before replacing it. By doing so, the temporary memory in the BIOS is erased and you will have you factory settings.
Posted on Dec 01, 2008
USB port on Wyse VX0 is not enabled. How do I access control panel to manage settings?
You have to enable it in BIOS. Look up how to get to BIOS on your particular computer. (Make & model)
Oct 24, 2013 | WYSE Winterm V90LE Thin Client - Thin...
I have a wyse winterm v30 thin client. what steps will it take in order to reload the firmware?
you can download this pdf guide from
https://support.wyse.com/OA_HTML/cskmbasicsrch.jsp?jttst0=6_23871%2C23871%2C-1%2C0%2C&jtfm0=&etfm1=&jfn=ZG455B66622DEA31A7AE70467E3EBEC537FE9176B1484EFD6E483B952B0ED1CF6F10611204C7B33B20AA233809D7249C41FE&oas=etuN3Cl3pQgYaOxTZDlD7w..&categoryId=10820
this will show you the steps to do a USB firmware upgrade.
Mar 20, 2011 | WYSE Winterm V30 Thin Client - Thin Client...
Print Screen on a Thin Client
PrintScreen dont work!
Use the free program, ex. Gadwin PrintScreen
Jun 30, 2009 | WYSE S10 (90210501) Network Terminal
How can i reset S30 wyse box
Try a G-key reset.
Failing that use WSI and an S30 image from the wyse Website.
WDM also has the option to to re-image the client.
You may also be able to get into the control panel of the terminal, and download an FTP image and set the terminal to upgrade from the image when uploaded to your ftp site. From the control panel, you can initate the upgrade manually
Mar 24, 2009 | WYSE Winterm S30 Thin Client - Thin Client...
Wyse v90l
Best thing to do here is a re-image the client using the tools on the Wyse website.
The new USB imaging tool is pretty handy at imaging this model, and should get this back to a default image and working very quickly :)
Jan 14, 2009 | WYSE V90LE Thin Client VIA 1.2GHz, 1GB...
WYSE 3235 thin client needs bios flashed
The easiest way to would be to take apart the machine so that the motherboard is exposed. Once you do, you will see a small, circular watch-like battery. Remove this for about 15-30 seconds. By doing so, it will perform a hard restart when the BIOS memory is cleared and you will have your original factory settings. If this does not work, consider the ports/card for the peripherals. Perhaps it is a hardware problem.
Dec 01, 2008 | WYSE Winterm 3235LE (90202401R) PC Desktop
I have a 3235le with wince 2.12. How can I upgrade the RDP client to 5.1 or 5.1+?
I tried to do the same thing but ran into the same problem - I gave up. However, I have been successful in loading RDP 5.1 onto a Wyse 8235LE. Works great with full resolution RDP sessions!
Sep 03, 2007 | WYSE Winterm 3235LE Network Terminal
No display in monitor
This may be the problem with the WYSE driver. Ensure that correct driver is intalled and colour profile is compitable. Syncmaster is auto detected by window based OS.the message "Sync out of range" comes due to improper out put video signal.
Jul 24, 2007 | WYSE Winterm 3235LE Network Terminal
WYSE Winterm 3235LE (90202401R) PC Desktop Logo
493 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
