Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
Water pump won't turn off. Have to unplug to stop
Unplugged and plugged in again.
    President:
  • 1,462 Answers
I assume you mean drain pump not turning off
take bottom front panel off and you will probably find water in the bottom tray.
mop it out and machine will go.
if fault reoccurs, you have a leak
Posted on Dec 01, 2008
Water pump shorted out. Now will not stop running unless washer is unplugged
oops you shorted the control board and now it needs more fixing at more expense
Jul 13, 2016 | Kenmore Elite Oasis 27052 Top Load Washer
Drain pump wont stop
It sounds and look's like the pressure switch. Their should be a tube connected to the pump that travels to the top of the machine ! ?
It could be more expensive (e.g timer) but check that you can blow through this tube from the pump to the pressure switch, a very slim tube about 7mm. Hope this helps ?
Jan 21, 2014 | Amana Washing Machines
Shallow water pump keeps stopping
new pump --not big enough for the job
old pump --motor windings problem, faulty start run capacitor
I suspect that as the motor is 1/2 hp if will run good when there is a need for water but under pressure the pressure switch is set to high so the motor overloads and gets hot
Mar 24, 2017 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
Pump won't drain water and keeps faulting for pump cleaning. Have turned it off, unplugged pump filter, cleaned it and restarted it several times with no luck. What else could be wrong??
Check to see if there is a drain filter. My GE has a small "door" at the bottom of the machine that has a filter behind it. If so ALL of the water will drain when you open it so be prepared. Then clean all of the junk from inside the filter or "trap"
Apr 15, 2013 | Washing Machines
My keurig b70 coffee maker says prime. sounds like the pump works for awhile then stops. prime lights up on the screen and doesnt let me do anything else why
Mine would brew the first cup fine, then the pump would run but would not draw water from the reservoir. I turn it off, turn it back on it would draw water for one cup then would not draw water again. I unplugged it waited 30 seconds and plugged it back in, assuming that would reset the electronics. It worked fine following the PDPU (power down, power up) procedure. Simply turning it off will NOT reset the processor, you MUST unplug the unit. Remember to wait 30 seconds or so prior to plugging the unit back in.
Nov 28, 2011 | Keurig Platinum B70 Coffee Maker
Machine stopped mid cycle, won't spin or did not drain, no error code displayed, tried unplugged and restart. no luck
next time send the model number,open the door,look around the opening where you put the clothes in and you'll see a tag with the model and serial numbers,it has to drain first before it will spin,check the pump,get a shop vac and vac out all the water,remove the bottom panel and look at the pump,if the middle of the pump can be removed turn it counter clockwise slowly until the water starts to leak out and vac it up until all the water is out,then remove the middle part of the pump and clean it out,if the middle doesn't come out remove the hoses and check the pump to see if anything is in it and check the hoses,after you remove any debries you find fill it with some water and put it into a drain to see if the water drains,if it doesn't you can check the pump again to make sure you cleaned everything out,stick your finger in and fell around the impellar to make sure it's clear,if it's clear replace the pump.usually an error code will come up but if it fills and agitiates but won't drain i would start at the pump.hope this helps.
Aug 15, 2011 | Maytag EPICz 3.7 Cu. Ft.
My washing machine is a hotpoint WF240. It started to overflow with water and spilling onto floor. We pulled it out from wall and found outgoing pump had fallen down, we put it back where it was supposed...
The machine will fill with it connected to the Electrical supply then stop if unplugged providing the fill valves/ water is okay....If it keeps on filling after unpluged then sounds like faulty fill valve,if on the other hand it fills without stopping when plugged in then its your air hose or Pressure switch at fault,Good luck
Apr 06, 2011 | Washing Machines
Spin cycle does not work.Water does not drain. When I run it, I get multiple beeps. The manuals to turn off and unplug. Repeat if necessary. Problem not solved.
Unplug the machine slide it out and tip back so you can reach under it. In the front corner underneath is the pump with a paddle wheel type fan on it that shpould turn very freely. If it is turning freely and won't pump it is either the pump or motor controller board.
Most likely something stuck in it though, try turning it to free it, If that works pump out the water if you can and then remove the pump. If it won't turn remove all the water you can, tip back at least 45 degrees and disconnect the 2 plugs from the pump (power unplugged first) then remove the pump by turning anticlockwise, it will first move just a little and stop, at this point realse the catch that is stopping it turning further and remove. clear what ever is blocking it. If the pump is rusty or the copper windings appear burnt (will be darker in the middle section REPLACE THE PUMP.
Re fit the pump, make sure it turns freely, if not take it off and try again.
Apr 16, 2010 | Fisher and Paykel GWL11 Top Load Washer
Cuisinart programmable espresso maker em-200C
Currently, both my manual and steam button are flashing. No idea why. Any help?
Feb 27, 2008 | Cuisinart Programmable Espresso Maker
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
96 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
