Question about Philips 50PF7320A 50 in. Plasma HDTV
Flickering white lines in 50PF9630A/37 philips plasma
I got philips plasma 50PF9630A/37. There was no picture only sound. The screen was flickering with white lines on screen. I updated my TV with available latest driver on philips.com (Software, Version: 1.5.0.0 ). Now i am able to see picture but too many white lines are flickering on the screen with picture freezing. I think i have updated driver very well as per the instructions and result. Please guide me what could be the problem. You can use technical terms as i know little bit about this.Thank you.
SOURCE: PHILIPS 50PF9630A/37
Quick test of the plasma screen itself:
1) Turn on the TV
2) Try to bring up an on screen setup menu using the remote or buttons on the tv.
3) Does the menu appear? If so, the screen itself is ok.
If it doesn't come up you make have an issue with the screen itself. I am not sure it would be possible to set contrast and brightness settings such that the picture would completely disappear, but I suspect you should be seeing something on the screen just from having turned it on.
We also need to know more about what you have connected to the television. HD televisions typically have several inputs on them including HDMI, digital cable, VGA and component. Let's say for example you have PS3 connected via HDMI. You can tell the PS3 to send audio across the HDMI cable as well as video. You also have the option of running separate connections for your audio signal. It is the existence of these options that make it necessary to understand where and how you have things connected, very specifically.
Posted on Sep 17, 2008
JonnieC
  • 139 Answers
SOURCE: Screen Issues
Looks like the gas needs sorting.Did something hit the screen?It looks like ink splotches does it?Bring it back to where you bought it if its still under guarantee otherwise it will be very expensive to get it fixed
Posted on Mar 15, 2009
ladywinn
  • 5138 Answers
SOURCE: I have a 50" Philips plasma TV, model #
The board you are talking about is it the SSB board?Which is the signal board,Problem now could lead back to the Display Panel, unless the board you replaced has a defect in it ! You should keep in mind that New does not mean it works.
Encompass Parts Distribution 1-800-638-3328
They have One in stock Price 137.49 (Ssb) small signal board for Display.
Posted on Sep 10, 2010
ekcnoel
  • 998 Answers
SOURCE: help philips 50pf9630a/37 no power remote or
If you open the cover at the back of your tv you will see the ac input then you can see the fuse their, if made of glass you will see the filament, if cut and no burn mark just try to replace it,but if the whole glass is burned and cant see the filament of the fuse your regulator is shorted replace it.
Posted on Oct 23, 2010
  • 11800 Answers
SOURCE: Philips 50 inch plasma 50PF9630A/37 - Picture has
It's called x-main - the board that controls the horizontal lines of pixels - and you can find it here
http://www.partstore.com/Part/Royal+Philips+Electronics/Philips/996500030024/New.aspx
Posted on Oct 28, 2010
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
50" Toshiba Plasma screen is flashing with flickering sound
www.tacp.toshiba.com/tacpassets-images/.../42hp66_om_e.pdf
http://www.fixdevice.com/smanuals/file/31149.html
Above, download these Service manuals, it will show you how to troubleshoot, and identify what board to repair change.
May 05, 2010 | Toshiba 50HP66 50 in. Plasma Television
I have a Philips plasma TV model #50PF9731D/37 with a weird ambi-light issue. When I first turn on the set, the ambi-light functions on both sides. But after I introduce a signal (cable and PS3 use HDMI...
Unfortunately the 'green line' issue mentioned in the review appears to still be happening on screens that are shipping to end users. (It's been documented in detail on AVForums).
Hopefully this should be rectified by a firmware change (simply being able to adjust the picture vertically as well as horizontally would help).
The clearlcd technology is new for philips
VERY VERY COMMON IN PHILIPS!!! People all over the internet are noticing the same problem. Philips is still working on it. I will let you know as soon as they have a solution.
Jan 17, 2009 | Philips 50PF9630A 50 in. Plasma Television
1) Turn on the TV
Sep 17, 2008 | Philips 50PF9630A 50 in. Plasma Television
Vertical lines through the right side of the screen
Sorry sounds like you have a bad panel Try changing picture format if the lines don't dissappear or change bad panel
Apr 17, 2008 | Philips 42PF7220A 42 in. Plasma Television
Vertical white line
Dont touch it just keep it running. one of the days you wake up and it will vanish just as it appeared without cause. This is because it has happened to me once with my Philips 42. the don
Aug 09, 2007 | Philips 50PF9630A 50 in. Plasma Television
Philips 50PF7320A 50 in. Plasma HDTV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
