Question about SanDisk Sansa m240 MP3 Player
Not able to switch
I bought m240 mp3 player which i did not use it for some '8' months
then i used it, it worked fine form some days.now i am not switch able to
switch it on. pls advice
  • vlab Dec 04, 2008
Is the battery dead? Try changing it.
Posted on Dec 03, 2008
Scandisk Sansa M240 in stops transfering tracks at 8% on Napster
go to yahoo find a driver and then reregister napster it should work
Jan 18, 2009 | SanDisk Sansa m230 MP3 Player
Help on My M240
Sorry, no can do.
It worked fine for me after switching to auto settings.
I am using Windows XP.
Jul 05, 2008 | SanDisk Sansa m240 MP3 Player
Regarding sansa battery
Battery is rechargeable by plugging into computer. 19 hours is probably not right - more like 8 or 9.
Sansa's website has manuals, faq's and more at:
http://www.sandisk.com/sansa/#/support-0/
make sure you pick Sansa "Fuze" for the m240 series
-Tha Mp3 Doctor
May 24, 2008 | SanDisk Sansa m240 MP3 Player
I need the installation disk for sansa m240. i bought the mp3 sansa m240 from a friend, but he lost the installation disk. i need to install it in my computer, so i can download songs to my mp3. thanks
hey guys goto to this webpage to download the installation disk web site this might help. I tried my best !
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
or
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
Good Luck Guys
Mar 04, 2008 | SanDisk Sansa m240 MP3 Player
PC not recognising hardware
I have had the same probmlem but I've begun to realize that windows vista isn't compatible for the MP3 player when I tried using it with Windows XP -- and it worked fine.
Jan 07, 2008 | SanDisk Sansa m240 MP3 Player
Volume control stopped working
Take the warranty and the MP3 and go to the shop from where you bought. They will repair for you.
Sep 02, 2007 | SanDisk Sansa m240 MP3 Player
Volumn problem
The first thing I would try is reseting it by taking out the batteries and placing them back in. Let me know if it helped. D.
May 12, 2007 | SanDisk Sansa m240 MP3 Player
Not enough memory space for music db
Your M240 may have encountered a corruption in its Music Database, and may be corrected by formatting and updating the firmware. Try this: Manually switch the player to MSC mode and format through "Disk Management". Here are the steps: Step 1: Locate the "Hold" switch on the side of the M240 and enable it (you should see an "orange-colored" surface when it's enabled) Step 2: Plug the M240 to your computer (recommended Operating System is Windows XP and above) and check Windows Explorer if the player is detected as a "Removable Drive" Step 3: Open "Disk Management" by right-clicking on the "My Computer" icon, then selecting "Manage" Step 4: Your "Disk Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" Step 5: On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa M240. The lower section also contains the drive # pertaining to your M240. Right-click on either drive letters pertaining to the M240 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. Step 6: In general, Disk Management is more the effective tool for formatting your M240 and assuming the format processing completed without any errors, proceed to updating the firmware of your player. Step 7: Use this link to download the Sansa Firmware updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Save this file to your Desktop and run it while your M240 is still plugged in to your PC. Follow the on-screen prompts. Step 8: "Safely remove" your M240 from your PC and -- with a fresh battery -- power on your player. It should boot up normally. I hope this works. The M240 is a great player
Apr 24, 2007 | SanDisk Sansa m240 MP3 Player
New SanDisk Sansa m240 MP3 Player
Hey regan have u fixed it yet?? Mine is doing the same thing and it wont turn on at all well write back!! ~sam~
Dec 24, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
29 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
