Question about Frigidaire Affinity ATF7000ES Front Load Washer
Frigidaire affinity washer doesn't start
The frigidaire affinity washer doesn't start: the door closes properly but the door locked button doesn't come on
  • 1 more comment
  • donnahelein Jan 12, 2009
    the lights wont go on, it beeps but wont start the wash
  • rischk Feb 01, 2009
    Same problem!  It started doing this a month after we purchased it!  We have had the repairman from the dealer out TWICE to repair it and it still has the same problem!  We are requesting that they replace the machine, since it is clearly a dog and under warranty.
  • jmega21 Feb 22, 2009
    I have the same problem, I took out the part and it is part number 1317632.
    I have not however received it or obviously tried it. It was $68.
    President:
  • 1,294 Answers
Try holding the 'options' & 'select' buttons together till the door lock button comes on. This is the child lock function. You can do it again for the lock to come off. Hold down for over 3 seconds
Please reply or rate.
Posted on Mar 24, 2009
Get my frigidaire washer to start. The lights go on as soon as I close it. Usually I have to push the start button for this to happen.
Hello friend, thanks for your post!
It sounds like it could be a possible issue within your control panel or door lock assembly. If the door is not making that connection it is closed the washer will not start. I would recommend having a professional come out to properly diagnose your appliance to avoid any unnecessary part purchases. -Matt
Sep 13, 2014 | Frigidaire Affinity ATF7000E Front Load...
Code E 21 Error on Affinity Washer Front Loader
I've had problems starting my washer because the door does not close properly, and then I get an error or pau code
What has worked is to unplug the washer for a minute, close the door, and then plug it back in. it then starts normally with 2 pushes on the start button
Jul 06, 2014 | Frigidaire Affinity ATF6000F Front Load...
Not working
Good Afternoon James,
I see that you are still having trouble with your Frigidaire Affinity washer, model# ATF7000E, finishing and now starting a load, even after replacing the door lock.
I would start by making sure that your washer door is completely closed.
Next I would check to make sure that your washer controls are not locked. You will see a "LOC" code if the controls are locked. To get them out of the lock mode, press and hold the "Options" and "Select" buttons at the same time for 10 seconds.
If you are still having trouble you will want to give your washer a hard reset. You can do this by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes.
Once power is restored, if you are still having trouble with your appliance either not starting or not completing the cycle, I would recommend contacting either the manufacturer or your local authorized technician. Hope this helps.
-Best Regards-
WP
Apr 07, 2014 | Frigidaire Affinity ATF7000E Front Load...
Door will not lock
Hello Bob - From what you have described it sounds like the door strike is not aligning with the door lock or the washer possibly has a defective door switch. I would suggest contacting a professional to move forward accurately and properly diagnose the unit.
Oct 03, 2012 | Frigidaire Affinity ATF7000E Front Load...
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Door lock sensor on affinity washer
It sounds like the entire door latch assembly needs to be replaced. The sensor inside is no longer communicating correctly with the main control board.
Aug 29, 2012 | Frigidaire ATF6000ES Front Load Washer
Frontdoor is closed but washer control says it is not closed
frontdoor locking mechanism bent and not locked properly,take off door and bend/adjust mech so that it locks in position when closed.
Jul 22, 2012 | Frigidaire Affinity FAFS4272L 4.2 Cu. Ft....
My affinity washer will not close to start a cycle. the buzzer goes off and i get the code "dr" but it seems to close fine
Have a service technician test the sensor in the door jam that senses when the door is closed (this is signaled by the electronic lock).
Dec 14, 2009 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
1,277 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
