Question about Hitachi NV45AB2S Coil Roofing Nailer
I have been rebuilding Hitachi nalers for about 2 years now and this one has me stumped. It works fine if you single shoot it. If you hold the trigger and try to bounce shoot the nails, the driver will not return fast enough.
    President:
  • Hitachi Master
  • 1,388 Answers
The roofers that frequent my shop want their nailers to work like machine guns. Here is what I do to make the hitachi 45 nail fast. Remove the cylinder and sand the fine scratches where orings meet cylinder. I use a rubber slug with a small bolt through the center. The rubber slug fits snuggly into the cylinder and the bolt into chuck of drill. Turn the cylinder with the drill while holding fine sandpaper against the scratches untill smooth. remove the nose from body and replace the sheet (part # 877125) and the bumper. If the sheet fits loose on the driver and the bumper has cuts or missing pieces, the driver will not return with full force. also the oring on the piston should not be too tight. Just snug enough to hold the weight of the piston. While nose piece is off check the air passage to feed piston for trash, use a small wire and push through to make sure. Make sure the orings on the feed piston fit snug. Actually push the feed piston by hand in the nose piece to make sure the three orings fit snugly. A loose feed piston will reduce nailing speed. Finally replace the boot on the firing pin. If the boot is blown off its seat with use replace the firing pin. A loose firing pin will waste air and lower pressure reducing nailing speed. Good luck
Posted on Dec 02, 2008
My 04 trailblazer won't work in 3 or drive but if I start in 1st to get moving I can get all the gears working I'm a lil stumped on what may cause it
Time for a trans rebuild
Some trans fail sooner than others
80% fail from not changing the fluid every 3 years
or known problems, when the mfg makes them, year after
year, with no intentions of correcting things
The fixes are only done in the aftermarket when they fail
You say your stumped,based on what,doing nothing
& worrying what this issues are?
Anytime you have a trans problem & drive ten miles, you pretty
much ruin it
The answers only come from testing, as soon as this seen to
be acting up
May 17, 2014 | Cars & Trucks
Hitachi 53SDX01B sound
This set had lots of audio problems- some idiot decided to put the entire audio circuit on a single compact board---it develops all kinds of bad solder connections on the numerous flat Pak chips on both top and bottom of the board.
Board no longer available from Hitachi (srs board) and rebuild usually is over 150 plus shipping.
We send the board out for that as I have seen top notch experts spend hours trying to solder the board and not after have a working set.
Hitachi just crammed too many parts in too small an area and the heat bakes the board---Understand I was seeing this failure when these sets first came out--failing after a week or two in someones home.
Apr 13, 2012 | Hitachi 53SDX01B 53" Rear Projection...
XHDR6435 radio was working fine yesterday, now it will not turn on. the red led behind the faceplate flashed when i turn on the car, and cds will load and eject but the radio will not power up. i habe...
I just Spoke to tech support. This is what they said:
1. Key in the on position and the red power button lit, remove the face plate.
2. On the left bottom side press and hold the reset button, with a pen, for 10 seconds and let go. The red led on the right should flash.
3. Reinstall the face plate.
4. Push power. The unit should come back on.
Mine worked, and i was about to tear it out and return it. So try this first or even call tech support for Dual 1-866-382-5476.
Jun 14, 2011 | Dual Electronics XHDR6435
Doesn't shoot. makes the noise, but no nail comes out. Right in the middle of a job, suddenly the gun stopped working. Pull the trigger, air leaks out. Let go, and it sounds like it shot a nail,...
I have had this problem myself, the only fix is a rebuild kit which you can pick up pretty cheap on ebay. the kit will consist of a bunch of seals and just pay attention to the way you take it apart and you will have no problems
Jul 31, 2010 | Hitachi NR83A2 2" To 3 1/4" Full Head...
NV45AB2 worked great a year ago.hooked it up last week and it only shoots the nail 1/4 inch in a piece of wood and it wont advance the next nail.My framing nailer works so the hose presure is good.
if you havent used in a year the o rings could be dry and you can try and lubricate them, but sounds like it needs them replaced. You can try going to Nailgundepot.com and buying an o ring rebuild kit from them. It contains all the needed parts except for the grease to lube the o rings. Let me know if you need more help
Dec 23, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
4l60e Shifts into 1 and 2 then slips drasticly< rpm
This is the typical transmission failure on these. You need a rebuild. The 3/4 gears clutches are burnt up.
Oct 18, 2009 | 1994 Chevrolet C1500
My nail gun will shoot one nail then stop. Any
I had the same problem with my Stanley stape gun. Had to replace all the seals and piston. Works find now! Check-out internet ...search for a rebuild kit for your model of gun. Get the complete rebuilding kit ....take about 1/2 hour to rebuild.
Jun 11, 2009 | Stanley Tools & Hardware - Others
RAID rebuild problem
Your NUMBER 1 ENEMY when doing multiple drives in a single case is HEAT!!!! Make 100% sure those drives are COOL!!! if not you will continue to have issues.
Dec 10, 2008 | Biostar P4M800-M7A Motherboard
THE D100 REFUSED TO SHOOT THE PAINTING IN THE INSERTED IMAGE. CAMERA IN ALL OTHER RESPECTS WORKING FINE. TRIED ALL MODES.
When you say you tried full manual, I just wanted to check that you also switched to manual focus? The D100 has a switch on the right side of the lens, says M, S, C, for manual, single, or continuous focus? You need that in M with a painting like that, or to should truly diffuse subjects like clouds or fog.
The reason it works fine with only part of the painting in frame is that the camera can then identify and focus on the edge of the painting. It could also focus on any painting with linear or sharp detail. Autofocus is rather clever, but not clever enough!
If you had indeed set manual focus, then I admit I'm stumped. Full manual mode with manual focus never refuses to trigger the shutter on my D70; although it does often take pictures I don't understand at first. :) Good luck -- let us know what you find out, please!
Oct 19, 2007 | Nikon D100 Digital Camera
Hitachi NV45AB2S Coil Roofing Nailer Logo
332 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
