Dell Inspiron 6000 Notebook Logo
Jim meyer Posted on Jan 27, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No sound Hi, the sound on my 6000 quit working. When using the sound controls I get the little window but sound is coming out. I checked the device manager and it does not show a sound device installed. All that is shows is two audio codecs and one legacy audio driver. Does anyone have any ideas? Thanks
  • Jim meyer Jan 27, 2007
    I ran the dxdiag program. It told me that a sound card was not installed....now what? Is there an way to add a card or is the motherboard hosed?
Anonymous
Level 3:
President:
  • Master 2,961 Answers
  • Posted on Jan 27, 2007
Anonymous
Master
Level 3:
President:
Answers
2961
Questions
Helped
1638018
Points
8444
The drivers you mention are related to your sound drivers to they are installed. Run this programme to see if there is a driver problem, click Start>Run then type 'dxdiag' and hit enter. It could be the motherboard sound chip thats failed.
  • Anonymous Jan 27, 2007
    It just maybe that your drivers are corrupt, go to the link below and download audio drivers and install again.
    http://support.dell.com/support/download...
1helpful
Disable motherboard sound card
If you are using Windows Vista or Windows 7. right click on the little speaker icon on the right hand side of the task bar. in the menu, click on "Playback devices". In the window that opens, click on the USB sound device, whatever it is called, and click on "Set Default". That should do it. if the USB device does not show up, then you have bigger problems than you think.
It is probably possible to completely disable the on-board sound from the bios but this is not necessary.
If you are using Windows XP go to the following link and follow the instructions.
"http://www.pcrx.com/resource_center/how-do-change-sound-playback-device.html"
2answers
I have sound but none when logging on to windows
1. check the sound mixer or the sound device to see if you have "play sound upon windows start up" checked.
Windows 7:
go to control panel > then select "Hardware and sound' then next select "change system sound" check box towards the bottom of this screen.
1helpful
How to unmute laptop sounds. Its mute and i am not able to unmute it?
  1. Click START
  2. click CONTROL PANEL
  3. click SOUNDS and AUDIO DEVICES
  4. Look at the box labelled SOUND RECORDING - if the DEFAULT DEVICE is listed as WAVE DEVICE (may have some letters and or numbers in front of the words WAVE DEVICE - they are only the name of the device) go to step 6 otherwise click the little downward arrow at the right hand end of the DEFAULT DEVICE box. Scroll down the pop-up list to WAVE DEVICE and click on it.
  5. click VOLUME in the SOUND RECORDING box
  6. A window will open entitled 'Recording Control'
  7. Put a tick (check-mark) in the little white box under the heading of MICROPHONE and make sure the Volume slider is at the top of the scale.
  8. Close the window to go back to the Sounds and Audio Devices Properties Window.
  9. If you also want to hear what you are saying into the microphone over your own loud-speakers / headphones click on the VOLUME button in the SOUND PLAYBACK box.
  10. A VOLUME CONTROL window will open. If MICROPHONE is in the list of sound sources go to step 11 otherwise click OPTION on the tool-bar at the top right of the VOLUME CONTROL window. Then click PROPERTIES. With a little green dot in the PLAYBACK box look where it says 'Show the following volume controls' - place a check-mark against microphone and then click OK
  11. In the VOLUME CONTROL window remove any check-mark from the MUTE box under the MICROPHONE heading and also make sure that the MUTE ALL box (bottom left) is also un-checked.
  12. Close the VOLUME CONTROL window. Press OK to close the Sounds and Audio Devices window and exit CONTROL PANEL
  13. That should be it but if you are using MSN Messenger / Skype or other similar program you will need to start that program and click on the TOOLS button followed by SOUNDS and TEST AUDIO - follow screen prompts thereafter.
My laptop sound is not working after installing windows 7 home premium . I have a dell inspiron 6000.
try, going into control panel.
then click sound and audio devices
at the bottom of the next grey window click
speaker volume
then check that nothing is turned down or on mute.
I hope this was useful.
2answers
Hi iam having a problem with my sound card on a dell inspiron 6000 my head phones work but not the speakers
Pls go to control panel \ sounds & audio devices \ check & configure from audio tab. Also see if there is any switch on the headphones volume line control etc
If this don't work then ur headphone is faulty. Well Hphones are quite cheap!
My dvd r/rw drive does not work. it sounds like it is reading cds and dvds but nothing happens.
try to boot from some bootable cd/dvd (eg. windows cd) to check if it isn't software problem, if it won't boot, try to clean laser lens using small paintbrush and little alcohol. If it is only software problem, go to control panel > system > device manager and uninstall all cd drives and restart computer
3helpful
3answers
Can i use lifechat zx-6000 to play and listen to music played by GOM player?
Yea, you can, you need to co to control panel and under sounds set the 360 head set control which will be your microsoft wireless control to default....but the sound is crapy..it seems that the manufacturers never designed this device for that kinda sound, only those who are talking to you with another mic...so i suggest sticking with your speakers or a good set of ear phones
1helpful
No sound Dell inspiron 6000
hi
open RUN from start menu and type msconfig. On the "system configuration utility" open services tab and chk for windows audio and make sure its running, if not then select it and just enable it.
hope this solves ur problem.
No audio
Hi
Quite likely, drivers for the audio controller is missing/not installed.
You did not give any info on the Operating System you installed and the sound card in question; Onboard or PCI Sound Card. I am assuming you have Windows XP or 2000 and using the builtin/onboard sound controller.
If this is correct, you will need to download and install ADI Onboard Sound Driver (Windows 2000/XP) - http://ftp.us.dell.com/audio/R94481.EXE
Let me know how you get on
Mike
No sound from laptop
Ok you follow this step to check about sound under your device manager
1.Click start-->settings-->control Panel
2.open System
3.is system windows,click on hardware tab
4.Click on Device Manager
5.Check under sound,video and game controller to see that
your device is working properly or not.
** if device have problem normally it will be listed under "other devices", notice any device is in that group.
takecare.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
