Question about Sanyo PLV 70 Multimedia Projector
No light being projected from unit,
Sanyo proxtrax multiverse projector. fan is running normal then high speed. on/off button is green then flashing red.
    President:
  • 1,073 Answers
I will guess that your lamp is dead, buy a new lamp.
And if u want to buy a lamp to the lowest price u can get, buy it from www.pricejapan.com
Good luck
Posted on Dec 02, 2008
I cant see my computer images on my projector
Assuming you are running windows 7: if you go into your control panel there is a menu for adding a display device, you want to choose connect to external display, when you get into that menu, there should be a dropdown where your computer will have auto detected the projector, select your projector from the list, then just below that I believe you want to choose the option to duplicate on both screens. Sorry if this isn't clear enough, but I'm on my older computer still running XP and I still havent been able to figure out how to use multiple display devices with this OS.
Aug 29, 2012 | Sanyo Proxtrax Multiverse Projector...
We have a Sanyo ProxtraX multiverse projector. We have used it a number of times but recently, it will not see the laptop. It turns on but cannot find the laptop signal. I have tried different laptops...
Have you tried the "Function and F key" trick? On most laptops it's the F6 key but on your unit look for a picture/graphic of a computer screen...or maybe text saying, "LCD/Monitor". To activate this function you must press and hold down the blue "function" key and also press the F6.
The F6 key has three states...1 - only laptop screen, 2 - only external monitor (video projector), 3 - both the laptop screen and the externally connected monitor and/or video projector.
Nov 08, 2010 | Office Equipment & Supplies
Projector frequently cutting out.
reset the lamp counter (menu-settings-lamp age-lamp counter reset-yes).
Oct 22, 2009 | Sanyo Office Equipment & Supplies
Can you connect a Mac ProBook laptop to a ProxTrax Multiverse?
Hello. There is no "device" needed to connect the units together...You'll need a cable that is"mini display port to vga". In order to connect the projector to the laptop, the cable has to have the special Apple connector which fits into a specific socket on the back of the laptop. The other end is just a standard vga connector which is plugged into the computer input on the projector. Hope I helped you!
Aug 20, 2009 | Sanyo PLC XU35 Multimedia Projector
No Signal
1. check cable make sure there is not bent pins on ether end.
2. check device with another computer if you get signal from other computer it may have to do with the computer your hooking it up to.
3. you can also try to in windows go to your video card properties and click on the secound display icon and activate the secound display.
Good luck please do not shoot the messanger and leave a good rating, thanks for using fixya.com
Aug 12, 2009 | Sanyo PLC XU35 Multimedia Projector
Sanyo LCD Projector
Hi smnheffernan
If there is no LED's switching on , then you can definitely rule out the lamp.
Try opening up the unit by taking out all the screws at the bottom and taking of the top cover.
Then repalce the fuse that is on the Powersupply Board ( the one that has the AC socket on it )
If the problem there after still exists , you will have to replace the Powersupply Board.
Hope this is of help and thanks for using Fixya !
May 05, 2008 | Sanyo PLC XU35 Multimedia Projector
Power Point Presentation Using Sanyo Pro Xtra X Multiverse Projector
Don't forget to select the Fn key and F4 on HP laptops. It could also be the Fn key and F8 depending on the laptop brand. It is the apple key and the F7 key on a Mac notebook. On Laptops this will toggle the video to the aux port where the monitor cable connects to the projector. There are 3 modes. video on the laptop screen, video on the laptop and projector, or video to the projector only.
Master Rod
Mar 11, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLV 70 Multimedia Projector Logo
270 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
