Reset your router to it's default settings.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The setup page is 192.168.0.1, open it in a browser page.
The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
How do I enable uPnP on my belkin router so it makes my PS3 faster? Right now I am connected with...
(More)
How do I enable uPnP on my belkin router so it makes my PS3 faster? Right now I am connected with NAT type 3, and my connection is all laggy and junk.
D-link Extreme N network using DIR-855, DWA-160. Firefox plus Facebook Live Feed eats all memory,...
(More)
D-link Extreme N network using DIR-855, DWA-160. Firefox plus Facebook Live Feed eats all memory, freezes system, reboot brings MS bluescreen which says "wireless net problem". Where do I start?
when i ask if there is a firmware update available, the answer is yes. when I tell it to update the...
(More)
when i ask if there is a firmware update available, the answer is yes. when I tell it to update the response is firmware update failure, you have attempted to install an incompatible firmware version. yr router will now reboot. help
Network Camera BL-C111A (wired version of BL-C131A) problems: context: I setup the port FW to port...
(More)
Network Camera BL-C111A (wired version of BL-C131A) problems: context: I setup the port FW to port 70. I can access camera directly from laptop using 3rd party wireless connection. good. Problems: 1. I setup the viewnetcam.com account and it seems to tell me all is good (24 hours have passes). I used http://www.yougetsignal.com/tools/open-ports/ to check. but it just doesn't work. I go to my viewnetcam address from the same laptop that works when I use the IP:port address and I get nothing 2. I want to get email notifications, but I cannot get it to send me an email. I used gmail smtp setting. I am guessing this camera does not support ssl? (crazy! really?) so what can I do?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
