Question about Formac Gallery 1740 Oxygen 17.4" LCD Monitor
Formac Gallery Monitor
While cleaning my monitor some of the liquid seeped between the screen and casing. Now there are three 1 pixel wide vertical lines from top to bottom. The colors of the lines vary. I thought the problem would fix itself over time after the liquid evaporated, but it's been over a month with no change.
  • 4 Answers
Looks like the water is getting in to the LCD contacts. Or corroding them. If the monitor can be opened safely open it and place in a warm dry environment for a few days. Silica dehumidifiers may help.
If the issue is not permanent this may fix it.
Posted on Feb 27, 2008
My ViewSonic monitor on my desktop has very, very thin lines of color running vertically all the way across the screen. Has been like this - according to former owner _ since he got it and sprayed th
I am under the impression of the following:
Some cleaning spray must have leaked in through the bezel and went on to a circuit board. In this type of case this would be a type of matrix screen drive problem. If any of the boards are damaged they have to be replaced. I have my doubts you can buy circuit boards and service the monitor yourself. It would be much more reasonable to replace the monitor.
When cleaning a monitor with liquids, dampen the soft tissue with the cleaner, and then do the cleaning on the screen. Make sure no liquid will run down to below and beneath the bezel.
Jerry G.
Jun 30, 2012 | ViewSonic Computers & Internet
I need a new power supply for a formac 1900 monitor
I've got two and you are welcome to one if you pay pp plus a sensible offerI live in South London UK
May 19, 2011 | Formac Gallery 1900 Oxygen 19" LCD Monitor
My formac dvi monitor wont work as a 2nd monitor for my laptop
Try a monitor that has a vga output only, sometimes these laptops can't recognize the difference when there is a converter involved. It doesn't see the signal properly.
Try that and if a regular monitor works with vga then you know that monitor may not be compatible with that laptop because of the converter. You could also try another converter as well to see if that fixes the problem.
May 07, 2010 | Formac Gallery 2010 20.1" LCD Monitor
Power button lights up but screen stays blank
First you check the problem with monitor or cpu.you can check it by other monitor.after replacing the monitor it gives not display. then your monitor has any hardware issue.then you can repaired it from service center.
Mar 24, 2010 | Formac Gallery 1900 Oxygen 19" LCD Monitor
Vertical band of green pixels 1-2" wide when monitor heats up
Sounds like you have some pixals going bad.
It could be heat related check to see if its under warrantee. Most screens have a 3 year on them.
Not sure about Dells.
Aug 21, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Backenlight inverter panel failure formac gallery 1900 oxyg
mine had the same problem, replaced the fuse with a T2.5 amp.
Ammeter gave a reading of 1.6A across the fuse pads so we shall see if its pops...
Aug 01, 2008 | Formac Gallery 1900 Oxygen 19" LCD Monitor
LCD vertical lines
hi, all the LCD cable contact pins to be cleaned, if still invain then u will need to replace the LCD..
Mar 16, 2008 | Toshiba Libretto 100CT Notebook
Formac Gallery 1740 Oxygen 17.4" LCD Monitor Logo
101 people viewed this question
Top Formac Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Formac Computer and Internet Expert? Answer questions, earn points and help others
