Question about Electric Door Light Switch
Pull on/off switch
I want to add the switch to a lone fluroscent fixture in my shop.
I put one lead to the white and the other to the black.
The fixture turns on but when I pull it off I blow the circuit??
Help
Gordy
  • gnlarson Dec 01, 2008
    Thanks for helping a novice in need!!!!!!!!
  • 61 Answers
Put one wire from switch to black wiring coming in and the other to the black going to the ballast.
If you do not understand please post back
Posted on Dec 01, 2008
  • Joseph Lillie
    Joseph Lillie Dec 01, 2008
    Make sure you vote on my rating and thank you very much
    Problem Solver:
  • 19 Answers
Instead of hooking up in that manner try this! I presume you Have a 14-2 or 12-2 wire either will work depends on cir. At Lt you should have wires for the fixture actually coming from fixture, A feed Hot and Nuetral(white), and the switch loop you added. Take the White from feed and tie to white from fixture. Your Done with those wire wirenut them together. Take the White From Switch loop and Tie it with the Black From feed ( This white is not a Nuetral but now a Hot)Tie together with wirenut. This send hot down to switch, Now Take Black From Switch Loop And connect to Black from Fixture. This completes the circuit, And sends Electric back to Lt. Put switch on the white and black. Your circuit blew becuase your mixed the nuetral with the Hot. I Hope this is clear let me know if you need more help
Posted on Jan 04, 2009
Replace a pull chain fixture with a switch on the wall?
Basic wiring.
When an off/on switch is added to any light or socket or whatever, you only use the black (hot) wire for the operation.
What you are doing is interrupting the current flow.
You would then take the "hot" wire from the power source, and put the switch in the line next, so that the other black wire goes to whatever you want controlled by the switch.
The white wire stays connected all the time.
God bless your efforts.
Jan 18, 2018 | Computers & Internet
Electrical/wiring for a pendant fixture
white - nuetral
black - zap the junk out of you positive
if you can test continuity then test for source power, check both black wires and the red. the white wire better be neutral
set your volt ohm meter to 200 VAC if you have a cheap dial one or if you have a nice auto range one, set it to AC volts and test. red to the three wires, black lead on white...
Dec 29, 2013 | Dryers
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
Apr 22, 2011 | Aloha Housewares (93645) Ceiling Fan
I am attempting to install my Hunter 21095 Westcott fan and am unsure of the wiring. Power is at the ceiling fixture which in turn feeds the next rooms fixture and the switch wire is also in the ceiling...
Black is for the fan motor which you connect to black(hot), black/white is for the light which you connect to the switched lead in the ceiling, the white lead from the fan goes to the neutral lead in ceiling, and tjhe green wire is earth ground and goes to the box screw in the ceiling
Jan 20, 2011 | Hunter (25417) Ceiling Fan
How do I wire a single light to a on/off switch
Add a comment and say what wires you have in case following answer misses your mark.
As a general rule, there is one cable that comes from breaker box.
There is another cable that goes to light fixture.
Each cable has 1 Black, 1 White and 1 Bare ground.
So you have 2 Blacks, 2 Whites and 2 Grounds.
White wires twist together and are covered by wire nut.
Black wires each connect to a different brass-colored screw on light switch. In any order.
Bare ground wires connect to green screw.
If light fixture has wires, then black goes to black and white to white, and ground to ground.
If light fixture has screws, then black goes to brass screw, white to silver screw, and ground to green screw.
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on circuit.
Jan 03, 2011 | Electrical Supplies
Chain to light does not work
Most paddle fans that come with a light kit (or provisions to add one via plug / jack later) provide at least 3 wires (most times 4 though) that will need to be connected to the house wiring. Those wires are:
1) Green, or Green with a Yellow stripe - this is the grounding wire and is connected to the grounded metal junction box or other ground wires.
2)White - this is the neutral wire and is connected to both the fan motor and light fixture.
3)Black - this wire connects to the fan motor. This wire along with the white wire completes a circuit for the fan.
4)Blue - this wire connects to the light fixture. This wire along with the white wire complete a circuit for the light fixture.
Ideally, the junction box in the ceiling has a neutral, ground and both an unswitched power source *and* a switched power source. An unswitched source is always on (regardless of any switch's position) while the switched source is controlled by one or more switch(es) near a door(s). Use a meter or tester to determine which wires are switched (probably black or red) and unswitched (probably black but may be red, too). Label them or orient them in such a way that you'll remember which is which. Turn the power off.
Connect the paddle fan's blue wire to the switched wire, the black wire to the unswitched wire(s), the white wire to the other neutral (most likely white wire(s) and finally, the ground wire to the rest of the ground wire(s). Turn power back on.
Wiring in this way allows the light fixture to be controlled by the wall switch(es) and the fan by the pull chain on the fixture. Turn the wall switch on and pull the chain until the light turns on. You can remove the long chain once the switch turns the light on and off so it is not accidentally shut off at the paddle fan later. Change the fan speed from high to low and eventually off with the chain.
If you only have a switched or unswitched power source in the ceiling, you'll have to connect both the black and blue paddle fan wires to whichever type power you have in the ceiling (switched or unswitched). If you're using a switched sourced, that switch will have to be left on in order for the fan or light to work.
If you have wired in any of these methods already, it could be that the switch for the fixture has failed, and should be replaced with a like-type switch.
I hope this helps!
May 20, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Light will not shut off on fixture (replacement of ceiling fan)
One of the two cables in the ceiling box is power and the opther is a switch leg .. what you need to do is connect the two black wires together at the ceiling, connect the white power wire to the white fixture wire ,.,. connect the white switch wire to the black fixture wire .. put some black tape on that white to make it legal .
Sep 27, 2009 | Hampton Bay 52 In. Black Huntington III...
Switch loop with mutiple fixtures
Here you go:
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 26, 2009 | Cooper Lighting Lighted Switch
Cannot turn off a pull-chain fixture
It sounds like you have accidentally by-passed the switch. The switch only needs one power leg to the pull-chain switch and the other 3 wires go on the other wire of the switch. The white wires get connected together as you have done.
Please turn off the power before you make a change.
Sep 19, 2009 | Kitchen Appliances - Others
Electric Door Light Switch Logo
135 people viewed this question
Top Electrical Supplies Experts
Steve
epangan29
Matt Olenzek
Matt Olenzek
Are you an Electrical Supply Expert? Answer questions, earn points and help others
