Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Connection where is the usb on this camara
When holding the camera with the lens pointed forward, the top right hand corner of the camera there is a small door about a half inch by a half inch that pops open but does not disconnect from the housing of the camera. there is the USB and another port for something else.
Posted on Jul 21, 2007
Pasar imagen a una tv
Si su TV tiene puerto USB solo tiene que pasar la foto al un USB y luego conectar el USB a la TV. Tambien si la foto esta en la camara, en mucho de los casos la camara viene con un cable para este proposito. Vea algunos ejemplos aqui
cable camara tv Google Search
Mar 12, 2014 | Gateway NE56R10u Laptop Intel Celeron...
I connect the usb into the computer but the camara isnt charging
USB is to download pictures and not to charge batteries - read manual
Jul 03, 2012 | Disney Pix Micro Digital Camera
Trying to copy photos to a folder using Microsoft Scanner & Camera Wizard. Camara is on and is connected to my PC with a USB cable, but the computer can not detect the camara.
First, check both ends of the USB cable to be sure that the ports and the plugs are properly seated so that the metal pins are able to transfer data. Restart Windows with the cables plugged in, and the camera should be recognized. You also MUST have the camera turned ON in order for the computer to read the fact that it is connected. If these suggestions fail, check your Microsoft Computer Management program to be sure that PlugnPlay devices are automatically recognized by your system.
Have fun with your photography!
Sciencewoman
Mar 31, 2011 | Samsung SL202 Digital Camera
How do i connect to computer
Check the camara out. If it has a usb or mini usb, then you can connect it to the computer. If not, then I guess you can't.
May 09, 2009 | Canon ES8600 Camcorder
I have a macbook and i connect the usb cable to upload my photos, but the usb is not recognized do i need to download any software. Its says that mac autmatically recognized the camara
the Mac normally recognizes the camera and launches iPhoto.
Try launching iPhoto, then plug in the usb cable. Make sure the connections are tight on the camera end of the cable.
Apr 22, 2009 | Fuji Finepix Z20fd Digital Camera
DCR-HC32E
You need a FireWire cable and a computer with FireWire port. I have same camara - it comes with a base unit into which you have to plug in the camara. From that base unit connect the firewire cable (4pin) and take that to your computer which may have a firewire port (either 6pin or 4 pin) - depending on what kind of firewire port you have on the computer, you have to get appropriate cable ... it is my understanding that the camara doesn't come with this cable. I purchased a firewire cable with 4 pin connecter on both ends to connect to my IBM laptop with Vista on it. It works great after all this setups. It does not work with a USB cable for some reason.
Jul 13, 2008 | Sony DCR-HC32E DV Digital Camcorder
Usb cord won't fit all of a sudden
Something could have broke off inside the connector. Try to look in side and see if there is anything blocking the connection. Tweezers can help out and pull out stuff that is blocking. Make sure that the camera is powered off. Better remove the battery to play it safe also. Check the condition of the USB cable that goes into the camera make sure it's not bent or dented. You can use a small needle nose pliers to fix that if it is.
Jun 30, 2008 | Kodak EasyShare M853 Digital Camera
Omg plzzzzzzz help
You text does not read true.
You are connecting to a Windows PC I assume
The camera plugs to a USB - what is special about it?
Remove all software associated with the camera.
Now plug the camera in and set it to upload.
Windows will put of the Scanner/Camera Wizard.
Let Windows do the work
Feb 11, 2008 | Cameras
Usb pc camera problem
Install your Usb pc camera under "administrator" user account means that all privileges should be i you so that you can install any driver and software to your pc. may this helpful to you.
In installing disconnect the pc cam to the computer and install the driver. after installing the correct driver connect back the pc camera. the computer will install it for you.
Dec 17, 2007 | Radio Shack VGA PC Camera Webcam
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
20 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
