Question about Wilson Electronics 811102 Direct Connect Cellular Amplifier (824 894 Mhz With 1900 Mhz Antenna Bypass) With Hardwire Supply For Cdma Gsm And Tdma Networks
Cell phone reception dead after using amplifier
Hi
After a few days of using the wilson dual band direct connect amp with my LG C1300 phone the Cell phone reception is now dead after using amplifier.
Anyone else experience this
I had this same problem with a motorola razr some time back. Some cell phones have a built in switch (such as the Razr) inside the external antenna connection. In the case with my razr, I
evidently pushed the adapter into the phone too far. I later had to jump out the switch inside the
phone to make it work with it's internal antenna again. Unfortunately, I could'nt use that same phone with my amp again. Just a thought on your problem.
Posted on Jan 22, 2009
How do I connects my lg phone to the loudspeaker
If you mean to the internal speaker, there should be a speaker symbol when making or receiving a call, which you press to activate.
If external loudspeaker, you can patch your earphone out socket to the line-in of your hi-fi / amplifier.
Do not connect an external loudspeaker directly to the phone - this will damage the phone.
If your amp /speaker / soundbar has bluetooth / Wi-Fi capable of pairing with your phone, then switch on both devices and pair them.
May 10, 2018 | LG Cell Phones
Best dual band router for hughesnet with a straighttalk phone line in a rural area
Biggest fan here of the Ubiquiti Line of devices.
The home model of this device is "Amplifi".
https://www.amplifi.com/
Nov 15, 2017 | NetGear WNDR3300 - RangeMax Dual Band...
FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Sep 14, 2011 | Denon DRA-37
It catches network when their is strong signal but in areas that are not having strong signals it says no network coverage
Keep in mind, poor reception is not something that your service provider will fix just because you want them to. It must be justifiably cost effective for them to put up new towers, which will ultimately be criticized by cities, home owners associations, etc. Most users think there is nothing they can do to improve their cell phone reception by themselves. This is most certainly untrue, and the following will explain what you can do to ensure great mobile coverage without waiting for a new tower to magically appear.
edit Steps
  1. 1Battery. Your cell phone uses a lot more power when connecting a call than when it is on standby. Often, your battery can be strong enough to attempt a call, but not strong enough to find a signal. If you find you are having signal problems, try to keep your battery charged to 2 bars or higher. Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9503394424+9665908481+3607312525+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); Ads by Google
    enclosure antennas 900mhz,2.3ghz,2.7ghz,3.5ghz,5ghz dual polarized microwave antennas
    www.itelite.net
  2. 2Landscape. Buildings and other large structures are very unfriendly to cell phone signal. Rather than making calls from deep inside buildings try moving outside or to a window to place your call. If you are having reception problems on the street try walking to the nearest intersection as they typically have better coverage. Cellular band radio waves do not effectively penetrate earth: if you are underground you will likely receive no signal.
  3. 3Install a cellular repeater. If you are having cell problems in one location, such as your home or office, then try installing a cellular repeater. Cell phone repeaters pick up low cell signal with an antenna, boost the signal and broadcast it over the coverage area. They typically need at least 2 bars of signal where the antenna is placed (usually outside or on the roof) but can substantially improve cell reception, as well as battery life and data download speeds. Some repeaters might need technical knowledge such as the frequency of your carrier, and only work for one service provider. For a less technical approach that improves reception on all carriers, use a dual-band cell phone repeater.
  4. 4Upgrade your antenna. A few cell phone manufacturers make a "Hi-gain" antenna for their handsets, which may be changed in-store or by the user at home. Although these won’t improve signal as much (or at all) as a repeater these antennas are relatively inexpensive and you are not confined to one location.
  5. 5Change networks. Most networks operate independently of one another, using their own frequencies and constructing their own cell phone towers. Chances are if the signal is bad with one network you can improve by switching. Most cellular networks these days allow you to transfer your phone number when you change provider.
  6. 6Hold your phone correctly. Mobile phone antennas are designed to project a signal outward, perpendicular to the long axis of the antenna. As such, mobile phones seek signals in a donut-esque shape around the antenna. Normally, when a mobile is held upright, this is not a problem. However, if you are holding your phone in a strange way, such as on its side or upside down, you will hinder the operation of the antenna. Hold your phone upright to guarantee that your phone can "see" your carrier signal.
  7. 7Host a cell site. This may take time, but where cell phone reception is inadequate property owners can host small cell sites on their properties for major wireless carriers. 3rd parties with Wireless Revenue Programs allow you to register your property to be eligible. Then when there is carrier interest in the area you'll be on the short list of places they choose from and will have optimal coverage. They may even pay your phone bill.
Aug 29, 2010 | Cell Phones
I bought a 32" conia tv and i cant get good reception! i have bought a amplified antenna and a hd set top box and still no good reception. my other tv's in the smae spot have had no reception issues....
well it's the same as the days of old, the antenna has a range of reception. the further the sations antenna, the lager your antenna must be. just because you bought an amplified antenna does not mean you will receive the deep fringe station. also the antenna must be UHF and VHF to receive the broadcast in digital. most of the braodcasters have gone with the UHF band because it is more stable for the bandwith of digital broadcast. the UHF band is very directional as well, so you must be pointing to the broadcasters antenna. no set top antenna will work if you are further than 15 miles of the broadcasters antenna. the roof top UHF/VHF antenna with a preamp is the way to go. I have tested every compact antenna and unless you live in the city that the broadcast generates you will get no reception with these. terks are junk, and any small amplified antenna does not work if you are in low lying areas. roof top, roof top,.....ROOF TOP!!!!!
Apr 24, 2008 | Televison & Video
PHONE RESTRICTED CODE
I have LG CE110 cell phone..it required a RESTRICTION CODE that i do not have..please help me to find it.
IMEI:011268008163537
thank you
Feb 14, 2008 | LG C1300/L1200/4010/4050/L1150/G4015...
C1300
can i get the restriction code for my L1150 LG phone? i cannot use it here in my country
Jan 30, 2008 | LG C1300/L1200/4010/4050/L1150/G4015...
Wilson Electronics 811102 Direct Connect Cellular Amplifier (824 894 Mhz With 1900 Mhz Antenna Bypass) With Hardwire Supply For Cdma Gsm And Tdma Networks Logo
152 people viewed this question
Top Wilson Cell Phones Experts
William Alequin
Are you a Wilson Cell Phone Expert? Answer questions, earn points and help others
