Question about Fuji FinePix A120 Digital Camera
Black Screen With Green Strip That Says DSC And The And USB Symbole And The Word USB
I D'ont Know What Hapended it Worked Fine Until I plugged it It Into The Computer.Does Anyone Have A Solution For Me?
  • 3 Answers
Try looking at http://www.fujifilm.ca/x3719.xml for firmware or software updates as well as new drivers for your camera. If you are using an upgraded XD card try putting the original back in.
Then follow the directions for doing the updates to use your new card. If all else fails time for a new camera.
Good luck and have a great summer.
Posted on Jun 20, 2008
Cannon penncraft cannon work
Get two short extension cords and cut the FEMALE end off each one. Strip back the insulation on that end. Connect the two green wires to each other, and connect the two white wires to each other.
Connect one black wire to a light switch, and connect the other black wire to a 20W appliance-type incandescent light bulb. Also run one short black wire (from a cut-off end) from the second terminal on the light bulb to the second terminal on the switch, like so:
plug -- black -- switch -- black -- bulb -- black -- plug
plug -- white ----------------------------------- white -- plug
plug -- green ---------------------------------- green -- plug
Turn the switch to the OFF position.
Start the generator. Plug one plug from your new rig into an outlet on the generator. Plug the other plug from your new rig into a wall outlet supplying 120V. With the generator running, turn the switch to the ON position.
The bulb should flash for a short while, then become steady. When it's steady, that side of the generator is flashed. Repeat for the other side of the generator if it makes 240V.
Jul 12, 2014 | Electrical Supplies
Black screen
It is bad ccd imager chip problem in your Sony DSC-T1 camera and ccd imager will be replaced to get live view to take pictures.
Sony will repair it free of cost, contact nearest Sony service center to get it repaired free.
Click Sony CCD Imgaer Support for details.
Thanks.
Sep 30, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
While deleting pictures from y Kodak MD853, the
That is completely normal, as soon as you hook up usb cord, the camera screen will be blank. It will function just fine and normal.
Sep 23, 2009 | Kodak EasyShare C613 Digital Camera
Blue lines in screen
Follow the steps below after verifying that the issue is occuring on other channels and other video sources.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved, service may be required.
Sep 22, 2009 | Sony KP-51HW40 51" Rear Projection...
Cyber Shot DSC-W55 " Will not Access "
smack it on something, i dropped mine after 30 minutes of frustration and it started working. the next time that it happened i hit it on my table on purpose and it worked. i dont know why but this worked.
Aug 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
LEXMARK 7350 IS NOT WORKING
HI,
Please follow the instructions given below to know exactly when the light is blinking:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer. We will replace the printer, only if it is under warranty.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
Next, lets try to print the self test.
Begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." This is essential. Then plug the printer back in and follow these steps:
1. Press the "Copy" button.
2. Press the "Menu" button.
3. Press the down arrow button once or until the screen displays "Maintenance."
4. Press the check mark button to select the "Maintenance" menu.
5. Press the down arrow button three times until the screen displays "Print Test Page."
6. Press the check mark button to select this. The Self-Test will start printing.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously.) Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let me know.
your's tech expert
Jeeth
Dec 28, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Screen goes black when a/v cord connected
I had a bad cable on mine. Once you plug the cord in the camera controls will appear on the screen. If you get a hold of Sony they can get you a new one.
You might be able to find a new one at a computer store depending on what connection goes to the back of you camera to get it to work (like a mini jack).
Jun 17, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
My Finpix A120 c'ant take pictures any more...
It's supposed to say that. When you plug it in, it says that, then once you are done uploading the photos and you eject the USB chord, those words will go away and you just turn off your camera and then turn it back on to take more photos.
Feb 07, 2007 | Fuji FinePix A120 Digital Camera
Fuji FinePix A120 Digital Camera Logo
42 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
